Question about HP V70S 17 in. CRT Monitor
My monitor will not turn on.
I havn't used it in a while and it just might be cold. But I want to get it out and use it but it won't turn on. WHAT DO I DO?
  • grandk2 Nov 17, 2008
    Thanks but it is my aunt Christles. I will try this and if it don't work I will write back. Also I couldn't get the cover off. I will check and see if anybody has a solution for this. Thanks again.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Champion:
  • 214 Answers
First try checking the cables and check also for corroded contacts. For corroded contacts, you can clean it w/ a blade cutter or a fine grade of sand paper, if it doesnt turn on accompanied by a hissing sound, contact your local technician to help you.
Posted on Nov 17, 2008
    Sergeant:
    Champion:
  • 274 Answers
Since you just reconnected it to a computer, double check to see that all connectors, power and signal are well plugged in. Make sure you have not bent a pin (normally 15 pins) on the signal cable connector, where it connects into the computer video port. Make sure there is only one video port on the back of the computer, if there are more try them too. You may have to reboot after switching the cables over.
Electronics do not store well in high humidity. If this is a CRT monitor, it is probably not worth the money to mess with, since you can buy a used replacement very cheap.
RDO
Canon EF-S 18-55mm f/3.5-5.6 USN Lens won`t auto focus
Try cleaning the electronic contacts on the lens and camera.
Jun 30, 2017 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
I HAVN'T USED MY 5000 WATT GENERAC GENERATOR FOR AT LEAST TWO YEARS AND NOW IT WON'T START WHAT SHOULD I DO?
When you stored it, did you drain the fuel out of it or run it "dry"? If not then the gas has most likely turned to varnish and needs to be cleaned out. There is no real easy way to clean the junk out of the carb without taking it apart. You MIGHT get lucky if you put fresh gas in the tank and then use some starting fluid SPARINGLY and see if the new fuel might dissolve the residue.
Sep 11, 2011 | Vacuums
I havn't hi-speed usb 2.0
USB 2 devices will work on the older USB but you won't get the fast speed of USB 2.
Aug 12, 2011 | Computers & Internet
My acer g205h Monitor is not picking up the signal from my Dell. All wires are properly attached. I havn't used it for 8 mo., but it worked fine when I last did? I moved, is there something I need to...
Did you try this monitor with another PC yet to find out if it is the PC problem or the Monitor problem? We need to narrow down the problem first.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jul 12, 2011 | Acer G205H Monitor
My 2002 Trailblazer is blowing cold air when I want heat.
well it could be several problems. first could be a bad thermostat that is stuck open or a possibly your heater core is plugged. also could be the switch that changes it from cold to hot. hope this helps but if your not mechanically inclined take to a shop
Dec 28, 2010 | 2002 Chevrolet TrailBlazer
Havn engine overheating issues. raidator is not the issue bleive it may be the hoses or thermostat cooolent leaking from back of engine
Fill the water to the proper level with it cold. Start car and look inside overflow can. If as it warms up you see bubbles in the tank the chances are very good that you have a blown head gasket. Good luck and have a great day.
Nov 06, 2010 | 1995 Subaru Legacy
Computer bots up-yellow light on Mobo on-all fans power all seems normal,BUT i have a Nivida 8800GT with 2 22 gateway Hd moniters useing HDMI cords and it has run without issue..got a blue warning sign...
"no signal" means computer not comunicating with monitor. Either a graphics card, or driver issue. I would have to know what mother board and power supply you are using. Even though your graphics card supports the use of two monitors, you may not ahve enough power to support it, either by means of your power supply not havning enough wattage, or *********** board may be burned out. Try unplugging one monitor at a time, and then try, one at a time, using each monitor alone in each of the HDMI slots, and see if you can run alone. Pay special attention to the bios POST (power on self test) and see if it gives any indicaiton of motherboard status. If you are saying you got a BSOD (blue screen of death) ...you should have a long error message to post that has a filename. It helps if you know what crashed it. Take that filename, and google it on another computer, and see what probable causes of it are.
Jan 06, 2010 | Microsoft Windows XP Professional With...
Hot water only front loader model wcvh6260fww
It could be an open circuit coil on the cold inlet solonoid or a faulty diaphram in the solonoid.If you havn,t got a tester try changing the coils over from the hot to the cold.Hope this helps Cheers.
Jul 28, 2009 | GE WSXH208A Front Load Washer
HP V70S 17 in. CRT Monitor Logo
71 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
