Question about Kenmore Refrigerators
Freezer freezes, fridge below will not cool
Recently the fridge part of our 6 year old Kenmore/whirlpool fridge w/top freezer stopped getting cold. The freezer is still freezing fine but the fridge is almost warm. I've vacumed the coils and fridge and freezer is almost empty so I don't think it's an air circulation problem. Several places on the net suggest possible circulation fan problems. While cleaning I noticed the fan at the bottom back running just fine but I cannot find a diagram that shows me where the other fan is located in the freezer. I would like any DIY repair uggestions and where I can find an online diagram and information. Thanks much for any help
  • 1 more comment
  • kenbink Nov 17, 2008
    If the fan is not blowing what is the next step for testing?
    What kicks the fan on. Is there a relay or thermostat or could the fan just have gone bad?
    Thanks! I'll check the voltage. If it's there I'll replace the fan. Any suggestions on where on the net I can find a "picture" or diagram of the Kenmore model 106-61194101.
  • Kenmore Master
  • 2,651 Answers
If your freezer is still freezing fine, except for perhaps a slight softening of ice cream. this is a good sign. the second fan you are looking for is located behind the back wall of the freezer, emptying the freezer will gain you access to the screws to remove he panel. you should be able to hear the fan blowing when the freezer door is opened.if indeed the fan is blowing you may have frost building up on the rear panel, this would indicate a defrost problem( unit not self defrosting) and so much frost has built up that the air flow has been restricted to the refrig compartment
Posted on Nov 17, 2008
  • Ron Coons
    Ron Coons Nov 17, 2008
    you can check the fan at the connection point for 110 volts, if you have power there the fan should be spinning if its not spinning and you have volts there replce fan, theres your issue. so long as your refrig is runnning the fan should be spinning,it may shut down when the refig is cold enough and is in a resting( but cold enough mode). however since your refrig is not cold enoughthe fan should be prompted to run all he time
  • Ron Coons
    Ron Coons Nov 18, 2008
    try this::: evap fan number 10, in liner section**.shcapp3105?modelNumber=106-61194101&pop=flush
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Kenmore fridge not cooling
check for your freezer fan running properly
then check to make sure you have air flow into the freezer this model has a habit of freezing ice in the air channels
Oct 07, 2009 | Refrigerators
Refrigerator not cool, freezer ok
Either the freezer continues to freeze up (most likely due to low refrigerant, due to a leak), or there is an obstruction between the freezer and the refrigerator (refrigerators get their cooling from the freezer).
Given that it works after you defrost it, I'm going with low gas. Call a professional to see if the leak can be fixed. If the unit is more than 10 years old, just get a new one.
Aug 22, 2009 | Kenmore Refrigerators
check to make sure that there is no ice build up in the went in the freezer, best way to fix is to shut off fridge for about 8 hours to defrost and then plug back in, this will help the fridge start cooling again.
Jun 15, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge not cold
my freezer is over freezing and my fridge is not cold. I have a whirlpool where the freezer is on top and the fridge is on the bottom. I need guidence in trying to figure out the problem.
Sep 29, 2008 | Kenmore 64802 Top Freezer Refrigerator
Kenmore Side by Side Refrigerator too cold
On a fridge freezer only the fridge temperature is monitored. In a cold location the fridge might not even need cooling and the freezer would get too warm but the thing won't care.
If the fridge sensor sees it as too warm then it will keep the motor running and the first thing to get really cold is the freezer.
Remember the freezing part is not temperature controlled ion a fridgefreezer.
Apr 28, 2017 | Refrigerators
Refrigerators Logo
278 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
