Question about RCA Universal Remote Control
I need the RCA remote code for Durabrand tv
I need the RCA systemlink5av code for a Durabrand tv, model DCT1903R. The Funai code (064) does not work.
  • Anonymous Feb 03, 2009
    i need the code for my universal rca remote controler on a durabrand television
  • 26 Answers
Since the Funai code does not work, you have to use the CODE SEARCH feature.
The remote may already be set up to operate your brand of TV, VCR, Laserdisc, Satellite Receiver, Audio Equipment, or Cable Box. It is pre-programmed with the following codes: TV-000, VCR1-000, AUDIO-003, and SAT•Cable Box-000. For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using CODE SEARCH
1. Manually turn on your device (TV, VCR, Laserdisc Player, Satellite Receiver, Cable Box or Audio Equipment).
2. Press and hold CODE•SRCH.
3. Press and release the device button you want to set up (TV, VCR1, VCR2•LD, SAT•CABLE, or AUDIO).
4. Release CODE•SRCH.
5. Press POWER repeatedly until the device turns off (you may have to press up to
100 times).
6. Once the device turns off, press and release ENTER.
7. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond,
repeat steps 1-7.
Programming Your Universal Remote
Posted on Nov 17, 2008
I need codes for Durabrand model CR130DR8 RCA remote
I did not find one specifically for the remote, but I found one for the actual tv with remote:
I hope that helps,
Jun 14, 2016 | RCA Televison & Video
I am trying to reprogram my Duraband tv with my RCA remote(RCR312WV R20052 3934EW
I do not find an RCR312WV remote from RCA. The code finder list is here: . The site works with IE 8 but not with my Firefox browser.
Most Durabrand TVs were made by Funai; so try the Funai codes. For the RCR311W, the codes are 1038, 1046, 1047, and 1189.
Please note that the remote will only have codes for TVs released 6 months or more before the remote was programmed. If your TV is newer, you may need a newer remote.
I hope this helps.
Dec 08, 2010 | Televison & Video
I have durabrand tv dwt1304 and magnavox CL403 remote, I need a code
There may not be a code set that applies to your TV' there is no such thing as a 'universal' remote and the farther apart the two are in time, the less likely it is that you will find a code set that works. A new remote is more likely to have a code set for an older TV but the reverse is not possible.
Your Durabrand AND the Magnavox are both made by Funai so check their website for info on both.
You might also try the brands listed below to see if any of their code sets work, all are made by Funai:
Funai, Symphonic, Sylvania, Emerson, Aventura, Durabrand, ESA, Magnavox, Insignia, Philips and Misakai
BTW, when buying one of the remotes claiming to be 'universal,' check the remote manufacturer's website by model number BEFORE buying it to see if they have those devices listed you want to control.
Good luck-
Mar 22, 2010 | Durabrand DWT1304 13" TV
Durabrand TV stuck on AUX mode
You can program a Comcast remote to work with the TV. Press the "TV" button on the Comcast remote. Then, hold down the "Setup" button until the red light blinks 3 times. Enter a 5 digit code:
These are the Durabrand codes: 10171 10463 10180 10178 11034
The 10171 code worked for my Durabrand DWT1905. Then use the TV/VCR button located beneath the "7" to switch inputs.
Jul 30, 2009 | Durabrand DWT1905 TV
Need a remote. or need the universal codes to use another remote.
try 032 or 132 or 11034 or 694.
These have all worked on various remotes including Dish Network remotes for the Durabrand DWT 1304 color 13" TV. Look at the Funai Corp codes and the Orion codes. Sometimes they work, Funai Corp makes Durabrand.
May 19, 2009 | Durabrand DWT1304 13" TV
I have a durabrand and none of the codes supplied work
I have durabrand codes, 10463, 10180, 10178, 10171, 11034, 10003
Nov 21, 2008 | RCA Universal Remote Control
Durabrand tv's were made for Walmart by Funai, Haier, and Orion. Look under those names for codes.
Aug 08, 2008 | Durabrand DWT2405 24" TV
Durabrand tv codes
It might help to find out what company made your Durabrand(walmart) tv. Try the codes listed under their name. Model numbers starting with DTV or DU are Orion, BH Haier, IWT or DWT Funai.
May 09, 2008 | Televison & Video
Durabrand tv codes
I seem to be the only person on the net with the 3 digit Durabrand universal remote code which works for 13' and up Durabrand TV's and TV/DVD TV/VCR combos. The culprit is 3 digit code 189 for a Funai and Emerson. I only know this because I have like 4 of these TV's haha.
Feb 06, 2008 | Durabrand BH1304D 13" TV
Televison & Video Logo
3,931 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
