There was a paper jam, I took out the paper but the alarm light keep flashing.
  • 5 more comments
  • thepuglady Nov 17, 2008
    The printer is Brother Laser HL-1440. I removed paper from a jam but the alarm light keep flashing.
    This didn't help for once I went to step #5 the alarm button startrd flashing again.
    The door was closed correctly so no it didn't help.
  • thepuglady Nov 20, 2008
    Nothing helped the light is still flashing.
  • stevemc5 Jan 23, 2009
    I'm running into the same problem. Have opened all areas of the printer to make sure any paper is cleared. (Had 2 or 3 jams in a row.) Now the "Ready" and "Alarm" lights won't stop blinking. Have tried the factory reset as described in these answers. The lights continue. Cannot find any paper jam and cannot try printing again.
  • JDTec
    JDTec May 11, 2010
    What printer?
  • 4,338 Answers
Use the following steps to perform a Factory Reset:
  1. Turn the printer off.
  2. Hold in the circular button on the front panel of the printer.
  3. Turn the printer back on.
  4. When the DRUM light is lit by itself let go of the button.
  5. Hold in the circular button on the front panel again.
  6. Once the Alarm light comes on, let go of the button.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 17, 2008
  • 1 more comment
  • JDTec
    JDTec Nov 17, 2008
    let me research this.
  • JDTec
    JDTec Nov 17, 2008
    Front Cover Open:
    The front cover is open. Please make sure that the front cover is closed. Look at the door switch and make sure that it is not recessed or being obstructed.
  • JDTec
    JDTec Nov 17, 2008
    The door may be closed, but the switch is not making contact with it.. Open the door and look along the edge of the fram and you will see the switch. My guess would be that the switch is recessed.
The led light on my k-9 alarm keeps flashing
Check for paper jam. Also check to be sure you did not drop something down the paper track.
Mar 30, 2015 | Office Equipment & Supplies
Both lights are blinking and will not print
they call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
All the lights started flashing after fixed a paper jam
you have take out zamed paper from the printer from the back side of the printer by ejecting the try from back side if it present. or pull out your tonner and then pull out the zame paper.
Aug 22, 2009 | Digital Products Brother HL-2040 Laser...
My canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Alarm/error and paper jam when not jammed
Power up printer,then press & hold (STOP/RESET)button for 5 sec. Then restart printer.I think it fix your problem.
May 11, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Alarm light is flashing and can not print
Hi
Try this
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 12, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Nov 12, 2008 | Canon MP830 All-In-One Printer
E 2 problem
I've encountered that before, i cleaned that the printer for the paper jam. Then i turn on the printer, it shows an error and flashes green. What we are going to do is to uninstall the current driver, and reinstall it... After that, try to turn it on and wait for few minutes to run the printer properly... try it...
May 08, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
220 people viewed this question
jasbo
jasbo
