Question about IBM NetVista PC Desktop
No image but only two bright white horizontal lines in the middle
When i turned on my computer, there is no image to be seen but only a two white horizontal lines in the middle of the screen, i tried turning it on and off but it did'nt work, i even tried tapping it on sides but it didn't work either.....i don't what else to do.....can you help me with my problem experts?
Thanks in advance to those who will help/reply.......Tnx
Let me have your e-mail too for contact....Tnx!!!
  • lordspark_19 Nov 18, 2008
    -leecom72-...my monitor is CRT ( cathode )......
    -jazzyboy11-.....i already tried it on other computers, but still does'nt work.....the bright white lines are still there...with no image....connections are ok and i'm sure co'z i have my friends monitor to be test in my computer....is there anything else that i can do besides replacing it??..or you think that my monitor is not usable anymore...
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    is the monitor a cathode ( CRT ) or LCD?
  • IBM Master
  • 4,806 Answers
If the monitor is cathode then chances are that the tube has gone, they work just like old TV's and break down eventually
Posted on Nov 17, 2008
  • Lee Hodgson
    Lee Hodgson Nov 18, 2008
    DO NOT OPEN THE MONITOR UP!!!
    The monitors capacitors carry a massive amount of electicity and some is stored in the tube, if accidently touch this the electric shock you would recieve would possible kill you, even when it is switched off!! this is not recomennded at all!
    CRT monitors are cheap as chips anyway
    regards
  • 728 Answers
Try checking the monitor and monitor cord to make sure they are working properly. Try it on another computer and see if the lines are still there. If they are, then you will need a new monitor and if they are not, then you may need a new monitor port for your computer. You will need that checked by a professional to be sure. If you can, open the computer and check the connections from the monitor port to the motherboard and make sure they are ok.
To contact me, just re-post and I will try to answer any questions or comments immediatley.
  • Jazz Boyce
    Jazz Boyce Nov 20, 2008
    You will most likely have to get a new one. But first, try going through the menu settings using the button on the front of the monitor. If when you try to pull up the menu screen and the white lines are still there, then you will need a new monitor.
My moniter screen go's dark with a bright horizontal white line in center ..it flickers
the driver board is bad in the monitor. Has it been in a place that is super hot like in a car? If the verticle driver chip disconnects from the matrix driver array, it will all squish into a single line in the middle of the screen like you are describing.. might try opening and blowing where the driver board connects to the LCD matrix (bunch of connectors on a plastic flat cable/bus connecting to the end of the LCD panel.. heating them could allow them to reconnect.. Its worth a try, right? It has worked for me about 60% time.
Feb 03, 2014 | Envision Computers & Internet
I have owned an emerson tv for two years now. All of a sudden the picture has become very blurry and white. It is not the cable connection and a DVD is also white and blurry. Even the input channels are...
you must open the back cover of tv, and then things you should do is set "SCREEN" adjustment on the flyback transformer. you must turn it counterclockwise to reduce and decrease the level of screen brightness. turn screen adjustment gradually until the horizontal blanking lines disappear from the screen. and blurred images will be sharp again
Aug 11, 2010 | Emerson EWF2004 20" TV
No image but only a bright white horizontal line on the middle
Be it a LCD or CRT monitor, in either case, the screen is gone. Either service or replace.
RDO
Nov 17, 2008 | Compaq FS 7550 17" CRT Monitor
Picture/image problem
Bad solder connection in the horizontal pincussion circuit.have someone resolder.God luck.4tune
Jan 09, 2008 | Televison & Video
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
It sounds to me like you're describing the re-trace of the unit. It is repairable, and more so the sooner you get it to the repair facility.
Nov 21, 2007 | Sony FD Trinitron WEGA KV-27FS120 27" TV
White horizontal line down middle of TV screen
caution whenever you see horizontal line please reduce brightness of your tv for safety of crt. your problem in vertical section only mostly due to loose contact in connector,print or loose components.
Sep 20, 2007 | Mitsubishi CS-35505 35" TV
Horizontal white lines on top of screen
try to adjust the screen control in the flyback transformer. good luck
May 04, 2007 | Panasonic CT-27G14 27" TV
I have a thin bright white line,horizontal,no picture
i have panasonic sophia tv 29" i have white horizontal line on middle of screen i know i have to solder ic but where is the ic located on main circuit board. thankx
Aug 22, 2006 | Jensen TS2750J TV
IBM NetVista PC Desktop Logo
245 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
