Question about Canon MultiPASS 800 InkJet Printer
Printer install problem printer is OKI c7200
Using windows xp SP2. wizard? says some files on windows XP CD rom needed
  • pmg2611 Nov 18, 2008
    thanks for tip, tried but no good. Any other ideas? thanks anyway
    Thanks Zukirider, have got this download. It is saying "need information from XP CD rom to install printer. Sorry about rating but 1st time on this site and tried to give a clear indication as to the result. I think they should change the wording. But help is always appreciated.
  • 300 Answers
Did it give you the file names? If so, you can search for the files on your hard drive and point the installer to the folder they are found in. If it doesn't show file names you can try pointing the installer to C:\i386.
Hope this helps. Please remember to rate this information.
Thanks
Posted on Nov 17, 2008
  • S C Nov 18, 2008
    I apologize for that information not working for you. Did it givr you the file names that it needs? If so list them here please.
    Have you tried downloading the latest drivers from the manufacturer? If not, you can download them here. Just choose Windows XP and click the PostScript driver. Then, on the right you will see a link for c79upsxe.exe, just double click it to start the install.
    I hope this helps. If not, please reply back with the requested information and I will try to assist you again. I was really hoping for at least a Thanks for trying rating. I wasn't expecting an Inappropriate. Did the last solution not work at all?
    Thanks
Windows xp is not install.install name is hidden. model no. c570ea(compaq).
hello sir,
Is it Windows Xp with SP2? Better you have to use Windows XP sp2 with bootable cd. for that you have to select first boot as your CD rom. and then try. it will work 100% sure.
Thanks
Sep 19, 2009 | Compaq Presario 5000 PC Desktop
Tip
How do I backup my files and folders in XP?
Windows XP comes with a backup tool called NTBACKUP (NTBACKUP.MSI from Windows XP CD-ROM). In Windows XP Home Edition, this tool has to be installed manually from the CD-ROM, whereas in Windows XP Professional, this tool is installed by default.
Double-click the Ntbackup.msi file in the following location on the Windows XP Home Edition CD to start a wizard that installs NTBackup: X:\VALUEADD\MSFT\NTBACKUP
X:\ refers to the CD-ROM drive-letter
Note: Usually, OEMs such as Compaq, DELL won't ship the Windows XP CD nor they include the NTBACKUP utility by default. You can download a copy of NTBACKUP.MSI here
Backing up your files using NTBackup Utility:
Click Start, Run and type NTBACKUP
Select Backup tab at the top
In the left pane, scroll to the file/folder which you want to backup and put a checkmark on it.
At the bottom, mention the output filename (the backup output)
Once set, click Start Backup button in the right, and again click Start Backup in resulting dialog
NTBACKUP does not have the ability to write to CDs directly. You will need to save the backup to hard drive, then transfer or burn it to a CD-ROM. Also, while backing up several files, make sure you backup the files in separate sets of each max 650MB (so that it fits on a CD-ROM)
See also FREE Windows Backup Software add-on for NTBackup
Enhanced Windows Backup uses Windows' built in backup engine called Windows Backup (ntbackup.exe) which provides state-of-the-art core backup technology. Enhanced Windows Backup substantially extends the capabilities of NTBackup, providing an effective integrated backup solution.
on Mar 24, 2008 | HP Compaq Presario V2000 Notebook
Xp recovery
You need to download all the drivers installer files from manufacturer website first, and also all the software you want to install automatically with Windows. Then you build a Windows Xp boot CD with all the software setup embedded.
See the links below:
Build an XP-SP2 Recovery Disc - Solutions by PC Magazine
Geek Repair: Create Your Own Ultimate Recovery CD :
Bart's way to create bootable CD-Roms
Slipstream a Windows XP SP2 Recovery CD
Build your own XP SP3 Recovery Disk -
Build an XP SP3 Recovery Disc
Apr 18, 2009 | Microsoft Computers & Internet
Needed to reinstall xp home-sp2 with my recovery cd-rom
Try changing the CD, if that dosn't solve the problem :
1. Format the whole hard disk using the default partition manager.
2. Install XP freshly.
Mar 13, 2009 | Microsoft Windows XP Home Edition
No autorun on usb devices or cd rom
run AutoFix.exe
download clik here Windows XP autorun repair wizard
Applies to:
Windows XP with Service Pack 2
Requirements
Windows XP with SP2
window.google_render
File Size
0.1MB
File Name
AutoFix.exe
Author/Supplier
Microsoft
Description
Windows XP was designed to make it simpler to identify content on CDs or DVDs, and assist in launching the correct program to open or view the files. For example, insert a movie DVD and Windows XP should show options for programs that can play a DVD. Unfortunately things can go wrong - settings get altered and the autorun no longer wants to be your friend. This free tool can help diagnose and repair autorun problems in XP. It is a tiny download and doesn't require installation. Simply double-click the exe file, click a few buttons (OK, some options are a little cryptic) and you can change or repair your Windows XP autorun options.
Jan 10, 2009 | Microsoft Windows XP Home Edition
Integrate SP2 in WinXP CD
Step 1
Create 3 folders - C:\WINXPSP2 C:\SP2 and C:\XPBOOT
Step 2
Copy the entire Windows XP CD into folder C:\WINXPSP2
Step 3
You will have to download the SP2 Update, which is 250MB.  Rename the Service Pack file to XP-SP2.EXE  Extract the Service Pack from the Run Dialog using the command:  C:\XP-SP2.EXE -U -X:C:\SP2
Step 4
Open Start/Run... and type the command:  C:\SP1106\update\update.exe -s:C:\WINXPSP1
Click OK
Folder C:\WINXPSP2contains: Windows XP SP2
How to Create a Windows XP SP1 CD Bootable
Step 1
Download xpboot.zip  Code:  Code:  http://thro.port5.com/xpboot.zip
( no download manager !! )
Extract xpboot.zip file (xpboot.bin) in to the folder C:\XPBOOT
Step 2
Start Nero - Burning Rom.  Select File > New... from the menu.  1.) Select CD-ROM (Boot)  2.) Select Image file from Source of boot image data  3.) Set Kind of emulation: to No Emulation  4.) Set Load segment of sectors (hex!): to 07C0  5.) Set Number of loaded sectors: to 4  6.) Press the Browse... button
Step 3
Select All Files (*.*) from File of type:  Locate boot.bin in the folder C:\XPBOOT
Step 4
Click ISO tab  Set File-/Directory length to ISO Level 1 (Max. of 11 = 8 + 3 chars)  Set Format to Mode 1  Set Character Set to ISO 9660  Check all Relax ISO Restrictions
Step 5
Click Label Tab  Select ISO9660 from the drop down box.  Enter the Volume Label as WB2PFRE_EN  Enter the System Identifier as WB2PFRE_EN  Enter the Volume Set as WB2PFRE_EN  Enter the Publisher as MICROSOFT CORPORATION  Enter the Data Preparer as MICROSOFT CORPORATION  Enter the Application as WB2PFRE_EN
* For Windows XP Professional OEM substitute WB2PFRE_EN with WXPOEM_EN  * For Windows XP Home OEM substitute WB2PFRE_EN with WXHOEM_EN
Step 6
Click Burn tab  Check Write  Check Finalize CD (No further writing possible!)  Set Write Method to Disk-At-Once
Press New button
Step 7
Locate the folder C:\WINXPSP2  Select everything in the folder and drag it to the ISO compilation panel.  Click the Write CD Dialog button.
Press Write
You're done.
Oct 19, 2008 | Computers & Internet
When I click on the Windows Backup icon to start the backup program nothing happens
You may need to re install it............
Using your Windows CD :
To manually install Backup: 1. Double-click the Ntbackup.msi file in the following location on the Windows XP Home Edition CD-ROM to start a wizard that installs Backup: CD-ROM Drive:\VALUEADD\MSFT\NTBACKUP 2. When the wizard is complete, click Finish.
Jul 14, 2008 | Computers & Internet
HELP ME
hi there my friend,
we have the hard way and then we have the easy way...
the hard way is to bootup with your bootable xp cd .follow the installation guide ..then.put in your key when you get the chance to ..and finish the installation. then apply service pack 2 to your installation .. and you're done...
the easy way would be to make a Slipstream Windows XP Service Pack 2 CD....which you can use each time you need to fix your system.
1 - Download the (full) "Network Install" of the Service Pack (English version [266 MB]), and save it to a directory (folder) on your hard drive (in my case D:\XP-SP2). Other languages can be downloaded from the Microsoft Download Web site.
Note: do not use spaces in the folder name!
2 - copy your Windows XP CD to your hard drive. Just create a folder (I used \XP-CD), and copy all the contents of your Windows XP CD in that folder.
3 - , open a Command Prompt (Start > Run > cmd), and go to the folder where you downloaded SP2 (cd \foldername). Type the command: servicepack filename /integrate:drive/path. In my example the command is WindowsXP-KB835935-SP2-ENU /integrate:D:\XP-CD.
Extract SP2 files
If you get the error:
This service pack can't be integrated error
This is caused by the fact that your Windows XP CD contains updates that will be automatically installed when you run setup. This type of CD's will usually be from larger OEM suppliers (like Dell, HP, or others).
You cannot use this type of CD to create a slipstreamed SP2 install.
First, the files will be extracted, and next they will be integrated in your Windows XP files:
Updating Windows Share
When ready, you should get a confirmation. Windows XP Service Pack 2 has now been Slipstreamed into your original Windows XP files.
Slipstream Completed
Creating a Bootable CD
For this part I used IsoBuster and Nero Burning ROM 6
After you install IsoBuster, you can choose to use only the product's free functionality for what we want to do, IsoBuster will look like the image below (you need to have your original Windows XP CD in the CD-ROM drive).
Start to extract the boot loader from the original Windows XP CD. Using IsoBuster, select the "folder" Bootable CD, and right-click Microsoft Corporation.img. From the menu choose Extract Microsoft Corporation.img, and extract it to the folder on your hard drive where you have your Windows XP files (D:\XP-CD in my case).
Extract Boot Image
Next, start Nero Burning ROM, and choose CD-ROM (Boot) in the New Compilation window. On the Boot tab, select Image file under Source of boot image data, and browse to the location of the Microsoft Corporation.img file. Also enable Expert Settings, choosing No Emulation, and changing the Number of loaded sectors to 4 (otherwise it won't boot!)
Nero Boot Settings
The ISO tab should be configured correctly as shown below:
Nero ISO Settings
If you have an older version of Nero you won't have the option Do Not Add ";1" ISO file version extention under Relax ISO Restrictions. You won't be able to boot your new CD, so update Nero!
You can configure the Label tab to your liking, I would however recommend that you keep the Volume Label the same as on your original Windows XP CD. Here are some (English) Labels:
* Windows XP Professional: WXPCCP_EN
* Windows XP Home: WXHCCP_EN
* Windows XP Professional OEM: WXPOEM_EN
* Windows XP Home OEM: WXHOEM_EN
Nero Label Settings
Next press New, and from the File Browser window, select the files and folders from your slipstreamed location (in my case D:\XP-CD). Now drag & drop the selected files in the ISO1 window.
Copy Files
Next, burn your new CD.
Burn
You now have a Bootable, Slipstreamed Windows XP Service Pack 2 CD!
Apr 28, 2008 | Computers & Internet
Computer doesn't recognize camera
Remove previous all installation/ file if any. Insert the Driver CD in the CD ROM again a wizard interface would be active, from that wizard complete the installation by clicking Next - Next. Do not plug the camera before fresh installation complete. If wizard ask to plug your camera, then plug it.
Jan 21, 2008 | Canon PowerShot SD850 IS Digital Camera
Boot cd-rom type:cd-rom/non-emulation booting
No, it's because Microsoft changed the way boot CDs work with SP2. You need an old CD (Windows XP SP1). I had the same problem here, notebook without floppy, it won't boot from the newer XP version CDs (SP2 or SP3) - but an old SP1 CD works!
(Those were all original Microsoft CDs, and the SP2 / SP3 CDs boot just fine on several other PCs I tested. It's just that some old hardware has a problem with the boot mode used on newer Windows CDs.)
Sep 20, 2007 | Computers & Internet
Canon MultiPASS 800 InkJet Printer Logo
48 people viewed this question
old marine
old marine
