Question about Sony DAV-C990 System
Sony Proprietary Speaker Connections
Anyone know where I can find replacement speaker wire for the Sony STR-KS2000. Need to replace the proprietary wires that connect the speakers to the Multi Channel receiver
Cheapest ones (with great reviews) is on amazon. take a look here Sony Samsung Special made Receiver Wires for Black DVD Blue Ray Home... . cheers
Posted on Nov 25, 2014
  • 24 Answers
Yes I can help you with that. Most Sony or Samsung Home Theater systems come with speacial speaker connectors that only Sony or the manufactures sell and they are quite expensive and are not campatible with other systems. I work for a company called Bogue Engineering Group and we manufacture our own universal speaker wire connectors. Ours are better because they are compatible with every other system and the come in many different options such as; full size 12 foot cables in either 18 gauge or 16 gauge and even 14 gauge speaker cables (Sony uses 20 or 22 gauge) and you can also order them in 6 foot lengths or any other length if needed since we do make custom lengths. Or you can order the connectors with a short 4 inch wire that allows you to hook up your own speaker cable which then can be any length or gauge you choose. The best part is that they never break unlike the Sony brand. Because the Sony brand is a locking type connector, if you accidentally pull on the wire or trip over it, you will pull the wire out of the connector and it can never be fixed. Our universal connectors have a different design so that would never happen and they are made from a very heavy duty nylon, not plastic so they won't break if you step on them or if the dog chews them. Try our website www.BogueEngineering.com or you can email me at bogue-engineering@live.com and I will be happy to help you. My name is Gary and I hope the info helps.
Posted on Jul 22, 2009
2 Suggested Answers
gotgeek2
  • 565 Answers
SOURCE: Speaker cables are too short
Just go to Radio Shack and buy some RCA jacks, the length of wire that you need and a soldering iron. Those inexpensive extension cords (12 and 15 foot) at the dollar store make good speaker wire, as copper is better. Just cut off the ends. Speaker wire from an electronics store is expensive.
If you decide to go to Radio Shack or similar store, the clerk should be able to explain everything to you, if not, run, don't walk to another store. You will eventually find someone to help you. If you don't know how to solder, just go to google and type in "how to solder". I'm sure you'll get plenty of hits.
Post back here for any further questions.
Posted on Feb 03, 2009
What is wrong with my pioneer pdpro6u media receiver?it shut off and wont power up,and there is a blinking blue light what does it mean?
  • there might be speaker wires touching somewhere
  • check all ventilation slats in Receiver make sure dust free
  • Check all connections maybe cable connections mixed up
  • Make sure power cord plugged in all of the way. Also make sure that the cord does not have exposed wires (this could cause a short
  • Make sure the wall outlet you are using is not overloaded (Too much power being used)
  • If this problem persists call customer service
This is the link to the manual
https://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/276752973PDP5060HDOperatingInstructions.pdf
Jan 08, 2017 | Pioneer Audio Players & Recorders
Want to use my current speakers with a new surround sound system. Current system is 5.1 channels, rated at 100w per channel @ 8. Ohms. New System is rated 145watts, 5.2 channels at 6 Ohms. Will b ok?
Hi Ronald.
8 Ohm speakers will work just fine as replacements for the
6 ohm speakers. When fitting speakers you need to consider
The power handling capability. The impedance and the frequencies
involved. Power handling is expressed in wattage ie 100W.
Unfortunately this can be expressed in rms, max or peak music. The rms value (root mean square) is the only really relevant figure as this is the continuose handling power at 1 KHz. The impedance
is the resistance that the amp sees but is not a dc resistance and
varies with frequency. The lower the impedance the more power
will be drawn from the amp. In the event of a short circuit across
the speaker the amp will try to deliver infinite power into an infinitly
small load in an infinitesimal amount of time and will self destruct.
Using an 8 Ohm speaker draws less power than a 6 Ohm speaker.
Connecting speakers in parallel; results in the impedance beingreduced. For example two 8 Ohm speakers in parallel will result
in a 4 Ohm impedance load but in series will be 16 Ohms.
Incidentally the the .1 (5.1) is the sub woofer which only has
to handle the bass frequencies, a small percentage of the
amplifiers overall frequency response..
Connect your speakers and then power up the amp last
after double checking there are no shorts on the speaker
cables.
All the very best from Vintie.
Jan 07, 2017 | Audio Players & Recorders
I have a monsoon mh505 pc speaker system. i lost the power adapter.i need a manfacture phone number or the model number of power adapter.
We can provide one.
ELECTREPAIRUSA@ELECTREPAIRUSA or you can contact us at that address as we repair/renovate all items electronic and electrical old and new.
Mar 14, 2016 | Audio Players & Recorders
How do I remove the speaker that is held in place by plastic circle that has been melted in certain spots over the edge of the speaker.
You can just use some snippers carefully then when you replace it either use gorilla or a glue gun.
Feb 06, 2016 | Audio Players & Recorders
How do I open a UC-280 2.0CH USB Powered speaker system to reconnect the broken cable.
Once you open the speaker it will destroy the acoustic properties and make the speaker useless. The speakers are assembled with takp and glue and have to be pried apart.
Mar 14, 2015 | Audio Players & Recorders
How to connect speakers to sony dts receiver strde935
The front and centre speakers need bigger cable, so the 3 pair of connectors can take thick wires. The satellites need tulip plugs, because they need less power. c7118031-3f7f-4f21-84a9-bff8010fd3d2.png
Jul 09, 2014 | Audio Players & Recorders
I have a Rowe R80 jukebox and after moving it it has no sound through the speakers I am in New Zealand
Well, in addition to all the fine suggestions that are here, I would like to add the simple and easy things that may have happened during the move.
IF YOU ARE NOT GETTING A LOUD POP WHEN THE MACHINE IS POWERED ON.......
1) Make sure that the wires on the terminals below are still connected to the screws. There is one ground and one each for left and right. The lower the tap the lower the (max) volume of the jukebox.If they are not connected there will be no sound.
There is a jumpers on the terminal strip where the volume control connects. Make sure that these connections are correct and tight. Also make sure that the jumpers did not fall off.
If you are getting the loud pop in the speakers when the power is turned on .....
Check the plug on the side of the mechanism, just below the back of the tone are.(looks like a little tube socket) Check to see that it is connected to the mech and the CORRECT PLACE on the amplifier. It mat be possible to have this end in the wrong place. bf77613e-82a3-4e37-b8fe-cc80f4d4dbcb.jpg
Check all all your connections against the pic.
I hope this was helpful.
Mar 24, 2014 | Audio Players & Recorders
Every time I'm listing to music my bass speaker makes a poping sound
You have most. Likely blown the speaker, replacement I think
Oct 20, 2013 | Audio Players & Recorders
The feedback on my stereo is very muffled.
Does is sound this way with all audio inputs? You might have your speaker wires backwards Red to Black between the speakers and the Stereo, make sure they are red to red and black to black.
Oct 18, 2012 | Audio Players & Recorders
Front two speakers not working at all
Hit the the speakers A/B/Off button on the receiver. If you plugged the front channels speaker wire next to the center channel on the back of the receiver make sure its showing B. If you plugged them in the banana plug part, make sure its showing A.
Apr 12, 2007 | Audio Players & Recorders
Sony DAV-C990 System Logo
5,309 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
