Question about Kenwood KVT-617DVD Car DVD Player
I cant turn my sub on
I had just baught the kenwood ddx512 and i am having trouble unlocking the subwoofer contron so mu subs work right now they are turned off i was told that i have to put the park brake on to activate the park brake switch controle in the deck i did that an i still cant unlock it
I had the same iss and what I finally figured out through the use of the book and just messing with it is- go to the menu seletion screes should be the upper right button on the screen or what would be a main menu of all the options - then scroll down to the next menu page there should be one button listed as standby- click it- then go back through your menus and adjust where needed for the sub. Then just adjust all you things to max- it worked for me. the lables for audio nad interface still had a lock on it but after hitting the standby button to can then change your settings that were previously locked up. then once done just go back to your tuner or dvd etc.. to get out of set up menu.
Posted on Dec 05, 2008
I had a similar issue with my 512. I reset the unit and was able to get the sub control to function. Check your zone controls and make sure they are in single. Dual zone will disable the sub....Hope this helps
Posted on Dec 02, 2008
Kenwood radio rca sub outs. How do I hook up a sub and will it work without an amp
You can't, unless it's a sub with a built-in amplifier. A subwoofer pre-amp output is meant to be connected to an amplifier, not directly to a subwoofer. You must have an amp to drive a sub.
Aug 27, 2015 | Kenwood Car Audio & Video
I have a velodyne sub woofer needs amp power source I have a kenwood eq and a sony reciever trying to figure out how to hook it all up right
So, you don't have a powered Velodyne sub (with a built in amp?)
Without model numbers - I"ll guess that there are speaker in and out connections on the back of the sub.
You simply connect the left and right speaker wires from the receivers to the subwoofers input speaker wire connections.
Then connect your main speakers from the sub's Out (or "speaker"} connections so that the sub is in line with the speaker path.
Use the sub's crossover settings on the back till you hca a seamless blend of the sub to the speakers where it is hard to tell you have a sub other than you your music now has deeper bass.
Why do you need the Kenwood EQ? This is not a necessary piece as nobody really knows how to use it properly and it realy complicates how you use your system. Flashing lights look cool though, right?
If you really must complicate the operation of your system then connect the Tape output of your receiver to the tape input of the Kenwood EQ, Then connect the Tape output of the Kenwood EQ to the Tape input of your receiver - assuming your receiver even has tape ins and outs.
You can engage the Kenwood EQ by inserting it into the audio path when you select the appropriate Tape input as the source on your receiver.
Hope this helps.
May 31, 2014 | Audio Players & Recorders
I have 3 Kenwood 12'inch subwoofers need to know how to wire them up to a Kenwood KAC-9105D
Follow the link and use the first diagram which illustrates wiring the subs to 2.66 ohms http://www.the12volt.com/caraudio/woofer_configurations.asp~Q~3~I~42
Remember that that amp is one ohm stable so you will not be getting the most out of that amp with that subs set up. The subs will only see 650 to 850 watts total...so each sub will only see about 215 - 275 watts a piece. Find out what the RMS wattage of your subs are each an determine if the wattage I mentioned above meets those requirements.
Sep 27, 2012 | Kenwood 12" 4-Ohm Single-Voice-Coil...
Hi, I have the Kenwood Subwoofer KS-201-HT, my question is how do I connect it to my receiver?
usually subs have outputs 4 ur monitors however if ur sub is active @ ur monitors are passive then you need 2 connect sub 2 ur tape loop with rca connections,usually you use the send signal from ur reciever which would norm connect to ur tape input , if the sub is passive then u connect direct to speaker output on amp then monitors to the sat connections on sub
Oct 12, 2010 | Kenwood SW36HT Subwoofer
For The Kenwood ddx512, I put Reset on it and asked me for a Code Set. What Do i Do ?
If you have the manual check for it in there. If not listed then I would call Kenwood to see if they will help you over the phone which shouldn't be a problem.
Sep 19, 2010 | Kenwood Car Audio & Video
Kenwoodxw1000f shut off after 10 sec
the problem sounds like your new sub is drawing to much power and your amp can not handle it. bridging the amp is a good way to get the full power out of your amp. But it isnt always suggested, my solution is to get a bigger amp. I install stereo systems for a living, and i tell my customers that it is smart to get an amp about 100 more watts then the rms rating of your subwoofer.
Feb 13, 2010 | Kenwood eXcelon KFC-XW1000F Car Subwoofer
I have a Kenwood KFC-W3514DVC and its hooked up to a Valor Multimedia VPA402 500 watt 2 channel amplifier. If i want to optomize my system the cheapest way should i buy another subwoofer or should i buy a...
find the rms rating of the sub and compare it to the amp.if the rms of the amp is higher than the sub you have enough power to push the sub.if its lower look at the rms of the amp if it can be bridged.you would like to see the rms matched to the sub or subs if you have enough power.
Sep 06, 2009 | Kenwood KFC-W3514DVC Car Subwoofer
Subwoofer trouble
does your deck have a sub control on it sub on or sub off are your rca jacks plug in to the right one are your rca cables in good shape speaker wires hooked up properlly amp is set on low pass filter
Jul 06, 2009 | Car Audio & Video
Kenwood KVT-617DVD Car DVD Player Logo
1,098 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
