Question about Garmin Nuvi 660 GPS Receiver
Nuvi 205 dead
My nuvi 205 is dead after having some problems in charging the unit with the car adaptor.....any suggestion?
looks like the battery is dead...when I connect it with the USB notheing happens and the PC does not recognize anything....txs
  • Anonymous Nov 18, 2008
    Antenna Issue - Garmin needs to replace thisdefect at no cost.
  • Anonymous Nov 27, 2008
    My Battery does not take a charge. No matter how long I charge it. It has always been this way. I thought I was doing something wrong.
    Master:
  • 638 Answers
Garmin support center----tomtom support center
http://www.gpscentral.ca/contactus.htm
all the gps information for 660 number model
http://gpsinformation.info/nuvi/660/660.html
Posted on Dec 08, 2008
I cant get sat nav to stay powerd on in the car.willpower up on computer but wont stay charged
Any time the unit will not stay powered after an external power source has been removed is an indication that the battery is failing. A Nuvi 205 is a pretty old unit. If the battery has never been changediast2 years, I would recommend having it replaced. info here:
http://www.sharc.net/gps_battery_repair.htm
Oct 02, 2013 | Garmin nuvi 205 GPS Receiver
Garnin 260w slide switch will not turn off unit.
Try resetting the unit and also charge it using only the wall charger overnight. Here's how to reset -it just puts everything back to factory settings - 1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture. 2-Select YES PLEASE Take the time to vote me up this is my only reward for trying to help. Thanks
May 01, 2010 | Garmin nuvi 205 GPS Receiver
My garmin nuvi 205 will not power on. I have plugged it in to charge the unit and it updates maps and shows the charging screen. Afterwards I unplug the unit and slide the switch over and it will not power...
This is likely a failed battery.
The battery on these units is not user-replaceable (soldered to the PCB) and must be returned to Garmin for repair.
CLICK HERE to see more about their FLAT RATE repair service.
Your nuvi 205 is listed as a $79 flat rate repair.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 16, 2010 | Garmin nuvi 205 GPS Receiver
Garmin won't charge or turn on.
Hello :
How old is your battery ? I think that the battery life is ended [ can't be recharged anymore ] . Just replace it and problem will be solved .
please rate !
Apr 14, 2010 | Garmin nuvi 205 GPS Receiver
Yesterday my Nuvi 205 worked fine, today it will not turn on. I have verified with another unit that the charge cable is fine and the other units charger will not activate my Nuvi
If your Garmin NUVI 205 can be recognized by your computer when plugged in, I recommend you backup your favorites.
Then I suggest attempting a hard reset.
Finally, replace the firmware and system software using webupdate. Your Nuvi should not need to be able to power up for a firmware update to be possible - replacing the firmware should allow it to power up successfully after the update.
I hope that helps.
Mar 27, 2010 | Garmin nuvi 205 GPS Receiver
My mains charger exploded and now 205 does not charge also no comms. Unit worked normally till battery went flat. When plugged into PC usb, Unit gets warm in area around mem card but does not charge.Any...
This is a new set of symptoms to me, but whenever these devices start acting up, I recommend performing a hard reset of your Gamin Nuvi 205. Also, use Garmin's WebUpdater service to make sure you have the latest software on your device.
I hope that helps.
Feb 11, 2010 | Garmin nuvi 205W GPS Receiver
My Garmin Nuvi doesnt charge
I've received many units for repair where the customer thougth that the battery was bad because the unit would not turn on or stay on long.
The problem was really caused by broken connections on the mini-USB jack. Please see this link for more info, specifically look at the section dealing with the mini-USB connector.
http://www.sharc.net/gps_charger_repair.htm
- Jim
Oct 22, 2009 | Garmin nuvi 205 GPS Receiver
Garmin Nuvi fails to work after firmware update
When a Garmin Nuvi 205 stops working or behaves strangely, there are two steps you can take yourself to try and get it going again:
  1. Perform a Hard Reset,
  2. Run WebUpdater to reinstall the firmware.
I hope that helps.
Sep 29, 2009 | Garmin nuvi 205 GPS Receiver
My Garmin nuvi 1300 brightness problems
I spoke to Garmin Support about this issue. There are 2 settings for contrast on the nuvi 1300. You need to set the contrast while it is plugged into the vehicle, and also while it is unplugged from the vehicle. The reason for the 2 settings is to save the charge of the battery while it is not plugged into the vehicle or power source.
Sep 14, 2009 | Garmin nuvi 1300 Car GPS Receiver
Garmin 205 will not turn on or charge.
Have you tried to plug the unit into another car lighter socket? The battery may be dead in the unit and the charge cable could have a blown fuse or the cigarette light socket may not be working. Try plugging something else into the car and see if it works. If it does then try to plug the gps cord and gps into another car to see if it works. If not you may have a blown fuse in the plug. Unscrew the tip of the plug and change the fuse. Good luck.
Apr 03, 2009 | Garmin nuvi 205W GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
439 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
