Question about RCA P46924 46" Rear Projection Television
T.V. won't turn on???
Our 46" RCA Model #P46924 will not turn on. It was not plugged up through a surge protector. But I do not remember any electrical storms. We just tried to turn it on and it doesn't even click or anything. Possibly a fuse? If so, how do we change it? Thanks!
Take off the back of the t.v. look down where it plugs in for the fuse
Posted on May 19, 2007
Try unpluging it
Posted on Jan 09, 2007
SOURCE:
I have a 2001 RCA Home Theater Projection TV Model p46924, Chassis # PTK195M34A. The screen all of a sudden started going dark and then just black. I have had it unplugged for about a month. Plugged it in...
Sounds like there is a hi voltage problem. Those 3 tubes are the most expensive parts to replace if you can find them. I. You can get an estimate for the repairs, but most likely they will approach the cost of a new flat screen smart TV.
Aug 06, 2017 | RCA P46924 46" Rear Projection Television
Where is the reset button on an rca model#p46924 46" projection screen tv?
Hello
Reset button is on its remote control itsef. You can locate it at the bottom right side. Point it towards TV, and reset the setting you want to. OK.
Apr 22, 2011 | RCA P46924 46" Rear Projection Television
TV doesn't have picture
it could be several things..no high voltage..bad tube...crt board problem..suggest you take to repair shop...compare prices of new tvs...repair at least 150$
Mar 22, 2009 | RCA P46924 46" Rear Projection Television
RCA P46924 46 in rear projection tv will not turn on
More than likely it has bad solder connections on the circuit board. You could try tapping lightly on power supply/deflection boards to see if it makes contact. Usually I find bad solder on those right under where the power cord plugs in, on the bottom of the board. If you have a soldering iron and solder you could save a few hundred dollars in repair costs, but use caution and make sure all power to set is disconnected. Maybe mark each plug as you disconnect them. Hope this helps. Good luck, Russmann.
Jun 02, 2008 | RCA P46924 46" Rear Projection Television
RCA Home Theater (Model #P46924) No Picture, just sound
Sounds like a possible solder issue with the vertical output IC. Try resoldering the Vertical output IC connections
May 17, 2008 | RCA P46924 46" Rear Projection Television
No power
Yes could be several problem, the first one in my mind is burt horzirontal transistors, Q14401 or bad hight voltage block.
Could be convergence problem that is causing the system to shout down.
Hope this helps
What About Bob
Mar 01, 2008 | RCA P46924 46" Rear Projection Television
RCA P46924
If you cannot adjust the red or blue in all 4 directions in the conversion adjustment menu. Your Convergence ICs are bad and will need replacement. Let me know if you need any further instructions.
Feb 29, 2008 | RCA P46924 46" Rear Projection Television
P46924 46 inch rca television
HEEELLP My P46924 chasis ptk195M1A won't power on, started few months ago, on and off by itseft, then changing channels by itself and then it won't turn on at all
Jan 23, 2008 | RCA P46924 46" Rear Projection Television
Bad RCA 32 Tube TV
Bad IHVT ( HV transformer ) part # 257805 or ASTI 2078
......................................................T.
Dec 11, 2007 | RCA F32650 32" TV
Rca 46 in
The only thing I have ever found that would make one of the tubes go out while the others stay on is a small high value resistor on the CRT board itself. It has been a while since I had that symptom but I remember the value of the resistor as 100k or 120k.
Jul 02, 2007 | RCA P46924 46" Rear Projection Television
RCA P46924 46" Rear Projection Television Logo
122 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
