Question about Zanussi FS1155W Front Load Washer
Zanussi FS1155W won't start
Door interlock keeps trying to engage (solenoid click). Have fitted new door interlock part but the problem still persists. Any ideas what to try next please?
  • lorenco Feb 12, 2008
    same problem washing machine when put onto any washing cycle solenoid starts clicking from door area, then a beeping noise and then [led end] lights up obviously a common problem for this machine if theres a simple answer would be grateful
I had exactly the same problem and replaced the door-locking mechanism to no effect. When I removed the main printed circuit board I also found that a single track on the board (leading to a capacitor) had also burned out. I soldered a piece of wire over it to reconnect it and it's now working perfectly.
Posted on Mar 07, 2010
Found out its the printed circuit board has burnt out behind the front panel two tracks on the panel leading to a green capacitor on the circuit board overheated so i resolded the tracks put the washing machine back together and so far its done several washes [touch wood its a sucess] the circuit board brand new from zanussi 135.00 pounds [so new washing machine if it fails] so hopefully theres a solution
Posted on Feb 14, 2008
E40 fault on zanussi washing machine is it worth repairing or to buy a new one 8-9 yrs old ?
A Zanussi E40 error usually indicates "Door open.Check interlock and associated wiring check door latch,check module and connections." However, what most people don't know is that most manufacturers route the poser to the door interlock through the same curcuit that powers up the carbon brushes on the motor. So if your motor brushes are worn down, the door won't lock. Your machine is about the right age for its brushes to be worn out, so I would check this out first. Motor brushes are cheap, easily available on Ebay and fairly easy to fit. Take the current brushes out, if they are less that three quarters of a centimeter long, changing them is a highly likely fix for your problem
Oct 31, 2015 | Zanussi Washing Machines
Have e40 fault showing whats the problem
It thinks the door is still open.
Try pushing door closed harder.
You may need a new interlock fitted.
Feb 06, 2011 | Zanussi FJS1225W Front Load Washer
Fitting new door seal
Hello,you mean you have a door gasket. A good, step-by-step article on this pesky concept of "panel-screw" gasket installation is found on this handy page:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Appliance_Zone_Refrigerator_Install
Thanks
May 28, 2010 | Zanussi FS1155W Front Load Washer
E40 error door light flashing and clicking noise
E40: Door open, Interlock, wiring or main PCB most likley going to be faulty door interlock.
Turn the power off, unplug the machine and take the top off your machine and on the front right of the machine there is a plastic case with lots of wires.
Put the wires out one block at a time, keep putting them in and out, this will help the connection to seat.
Try the machine again and the problem should be solved.
If not you may need a new board.
Mar 10, 2010 | Zanussi IZ161S Front Load Washer
Error codes E40 andE70 showing on model zwf1640s(zanussi)
E40 is an error from the door locking mech (interlock).this is the bit behind the port hole door frame at approx 3 o clock pos,where the door striker pin goes through hole.
Held on with 2 screws and you need to remove plastic clamp from door gasket to gain access.
Check the Door Switch/interlock or the WIRING for failure in this case and repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 06, 2009 | Washing Machines
Zanussi nexus washing machine
almost certainly the door interlock faulty. fairly cheap part and easy to replace.
remove plastic clamp holding door boot to cabinet and peel back in the area of the door interlock. door lock is held in by 2 screws from outside which undo and withdraw lock. disconect electrical plug and small diameter tube at bottom. fitting new one is just the reverse
Oct 18, 2008 | Zanussi FJS1225W Front Load Washer
My zanussi Aquacycle 1100 wont start. A clicking noise starts after I try and start a wash. I heard it could be a door interlock that requires replacing. Is this easy to replace?
door interlock is easy to replace.
undo the plastic clamp that holds door gasket to cabinet. peel back in area of door lock. door lock is held by 2 screws on outside. undo these ans lock comes off. there may also be a small diameter hose as well to door lock which take off as well.
reassembly is just the reverse
Jun 30, 2008 | Washing Machines
ZANUSSI ZWF1437W WASHING MACHINE
yes sounds like door interlock cheap and easy diy job goodluck and unplug regards jason
Jun 14, 2008 | Zanussi ZWF1430W Front Load Washer
Door not closing Zanussi FX1265W 1200 Auacycle
Further to my previous posting, I have now got a new Bosch but I have removed the PCB from the FX1265W. I found that the printed circuit track between the edge connector and the triac has blown. The triac (BTB16) was tested and faulty. New triac is on order (£1.03). I will post again when it has been fitted and the track is repaired and if the machine works.
Mark Allinson
Feb 15, 2008 | Washing Machines
Fjs1225w machine wont start
If its not the door interlock then the only other possible thing is the control module has failed ....
it does happen on zanussi machine.. is it making a cliicking noise the door interlock.... when you press start .... like click click....
if so then most likely its the control board inside the machine
Jan 20, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi FS1155W Front Load Washer Logo
290 people viewed this question
Top Zanussi Washing Machines Experts
shaun taylor
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
