Problem with Sony Handycam DCR-HC42 Mini DV Digital Camcorder
reinsert cassette
when I insert a tape, the screen flashes "reinsert cassette". So I guess the camera has a problem recognizing the tape. What might be wrong?
Posted by avatar on Nov 30, 2006
    • By avatarMarta1907 Feb 28, 2009
    • I had the same problem and the smack attack worked. I **** you not.
    • By avatarGuest Feb 17, 2009
    • I also have the same problem. I've always been very careful with my camera because it wasn't cheap. I have a bikecam attachment for my motorcycle and had the camera mounted to the gas tank. The error started appearing after a few hours of recording. I thought that the error was a result of the vibration, which it very well may be.
      Anyways, I'm very glad I found this site and you folks. Reluctantly, I gave the unit a whack on both sides, turned it on and got the same error message. I ejected the tape, re-inserted it and have not had any problems since. Everything is working fine now on it. Gooney. I was just about to go drop it off at the shop. Thank you all!!
    • By avatarGuest Dec 23, 2008
    • Thank you so much!! I smacked my dcr trv480 around and now it works again!
    • By avatarkassukissa Dec 15, 2008
    • I have same problem ?
      My Sony DCR-HC42 said that "insert the casette´"
      What i must to do ?
      Help Me !1
    • By avatarGuest Dec 05, 2008
    • I've smacked it over and over and it keeps saying it. It's about to get stomped on. Any other ideas?
    • By avatarwawdem Oct 04, 2008
    • I also have this problem, with a SONY DCR-TRV480E PAL. The problem is when I insert the cassette it reads on screen that "re-insert the cassette"
    • By avatarGuest Oct 01, 2008
    • I too was a disbeliever when I read about the smacking solution, but with nothing to lose, I gave my TRV480 a good whack on the left side of the unit (battery in, tape in), turned it on, and it worked! I don't know how long it will last, but I know what to do next time it happens. I only wish I had found this site before I bought my new camcorder. Oh well. At least I can record in Hi Def with my new camcorder.
    • By avatarted_k Sep 27, 2008
    • Unbelievable! Smacking the thing really works!!!
      Thanks for the helpful advice.
      TK
    • By avatar9ppel Sep 26, 2008
    • I also have this problem, with a SONY DCR-H96. I've tried to smack the camera as described, and it seems to work sometimes, but not always, by far. But it seems that this problem occurs only (so far) when the tape is near the end. So, what I have started to do, is to rewind the tape manually with a pencil (remember to push down the little "button"/tag between the wheels), not all the way, but only some rounds (maybe 30-40 or so). After I've done this, it usually works allright. I use DV-tapes from TDK, btw, considering to buy SONY-tapes next time.
    • By avatarGuest Jul 10, 2008
    • Hello, i had the same problem but noticed all worked fine when the unit was running on the adapter. I replaced the Lithium Ion battery and the problem was solved.
    • By avatardudack Jul 10, 2008
    • I also have the same problem I just want an answer so I can also change the tapes to dvd I tried reinserting the tape many times? What can I do? Is it worth getting fix?
    • By avatarGuest Jun 10, 2008
    • rgg
    • By avatarRandiNReed Apr 24, 2008
    • I've smacked the camera and smacked the camera.... and it's still insisting that I reinsert the tape!! Please help!! I just want to be able to get my videos off Hi8 and on to DVD before buying a new camera!
      Any suggestions on how to fix this problem?? GOing craZy here!!
    • By avatarplumcass Apr 13, 2008
    • When inserting tape some times it will not close all the way and when it does close and i hit the record button it flashes the reinsert tape message
    • By avatarGuest Mar 28, 2008
    • Suddenly, my camera shows a signal: reinsert the cassette. What should i do?
    • By avatarGuest Dec 30, 2007
    • i hav same problem & i had already removed battery & smack it for 3 to 4 times. its comes in normal situation but when i take a picture again the same problem is happaning. kindly send me another solution.
    • By avatarshahil Dec 29, 2007
    • when i insert the cassette the screen is flashing & message on the screen is reinsert the cassette. so pls send me the solution.
    • By avatarTglass Dec 28, 2007
    • IT WORKS!!! I can't believe it....IT WORKED! Thanks
Solutions (78)
Best Solution
Trust me on this one....with tape still in unit and battery removed, smack both sides of unit firmly 3-4 times with the heel of your hand. It works 9 out of 10 times on all Sony cameras. I was quoted $170 to just look at the camera and then a probable $290 to replace the cassette loader mechanism. I told them it wasn't worth it. I checked other Sony blogs addressing the same issue and with out fail smacking the ...cking thing is the only way around it. Apparently it frees up a stuck part. Give it hell.
    • By avatarJulie Gosse Feb 15, 2011
    • You are awesome! It worked :) Thank You Thank You Thank You! I was ready to blame my 13 yr old son for the "broken" video camera! You saved the day!
I believe I have found the real answer to this "Re-Insert Cassette" problem. My own DCR-HC42 had the same problem. From the Sony Tech I learned that the camera is not recognizing the cassette. From another website, I discovered that the electrical connection between the cassette and camera are 4 gold metal fingers that press against the 4 small notched sections of the cassette shell. FIRST open the tape loading compartment allowing the tape cassette to spring open. SECOND, remove the battery and then SLOWLY remove the cassette and look for the 4 notches in the shell as you remove it from the camera trolley. With a small head flashlight look carefully in the same area of the trolley camera compartment. They are off to one side and a bit tricky to view. Get a Q-tip and soak it in Isopropol Alcohol.
Very carefully and slowly without bending or distorting these fingers, wipe each one with the wet swab to clean off the dirt build up on each. Allow a few minutes to dry. Then put your battery back in first and then the cassette. Load as normal. This is what I did instead of beating up the camera and it worked perfectly. Hitting the camera is a crude way of shifting the position of the 4 electrical fingers to make a better cassette shell contact. Professionals don't beat up equipment to get it working. They find the underlying cause. CLEAN FIRST. One more thing you can try if the cleaning alone doesn't work is to reset the electronics to default settings. On my specific model, there is a small rechargeable battery inside the camera. You cannot get to it. This is the correct discharge method. Remove your regular camera battery. Switch on the camera to playback mode (three shifts of the rotating switch). Then look for the small hole on the body of the camera called "reset". Hold that reset button in for at least 10 seconds. Hit the record button on the camera while you are depressing the reset button all at the same time. What this does is deplete the voltage of the internal battery. Then put your regular battery back in the camera so it can exchange voltage to the internal battery. You'll have to reset your date and time in the camera memory and perhaps other features which you may have altered from their default settings but this method brings the motherboard back to all factory settings. If the cleaning alone didn't cure the first problem, then reset the electronics. If my method doesn't work you can always get physical but hitting a delicate electronic device with a sensitive transport mechanism just can't be a good idea in the long run.
    • By avatarjoeduboisblo Feb 06, 2011
    • I have had the same problem everyone else here has had with the tape refusing to load. I had been using the smacking method and the shaking method, but I was never really comfortable with it because I knew from troubleshooting that it was NOT a problem with the mechanism. I cleaned the connector per nimsgame's suggestion and I cleaned the tape case and it worked consistently!
      These cameras are getting old now, please don't keep whacking your camera, at the best you look silly, at worst you will eventually break it.
    • By avatarAl Miller Feb 06, 2011
    • Thank you for sharing your experience on the site and especially with your good experience with my method. I hope others will be able to update their own experience as you and I did and not keep smashing their cameras. Let's face it, if your out in the middle of nowhere and need a quick fix, that's one thing but if your at home why not do the right thing?
      Have a nice day.
!!!!!!!??????? i dont know how it worked but it did and i am so amazed! well thank you for writing that tip because i had a movie i just filmed and was upset that my camera was not working. THANK YOU THANK YOU THANK YOU!!!
  • By Author imagecoltsta Sep 07, 2007
Hai,
Please Insert Head cleaning Cassatte & play it. After this Please Insert new cassatte & record the picture & check play back. If the picture is good. check with old cassatte. If it is not worked Please press reset button if it is mechanical problem it will adjust.
Thank you & best of luck.
Udupi
This was amazing! My Sony Handycam DCR-HC28 was saying "Reinsert Cassette" and I spoke to Sony and they wanted me to pay over a hundred dollars to send it to them to get it repaired on top of the $400 I paid for it. I have used my camcorder twice and always kept it in its bag and taken excellent care of it. I was not going to pay to have it fixed. I came across this posting and I figured, sure, why not? What's a little smacking when I will probably end up throwing it against a wall anyway if it doesn't work? So...I beat the sh*t out of it...and...absolute perfection. It works just fine...Thank you so much to whoever it was that figured this out! Works like a charm.
WOW! I was very aprehensive about "smacking" my miniVD, but it works like a charm! Thanks!!!
My Sony DCR-HC21 had this problem and I hit the reset button on the side while it was on, and now it works. - I will smack it if it does it again though :)
After my DCR-TRV280 camcorder fell off a bedroom dresser, where it was mounted on a mini-tripod (guess what I was taping?...), I started getting the "reinsert cassette" error message. I tested it with another tape that I knew was fine and got the same message, so I knew it was a camera issue.
I tried various things including disconnecting the power supply and whacking the camera soundly on both sides according to the instructions on this forum. But what finally solved the problem for me was hitting the reset button near the LCD viewfinder control panel, removing the power, and then powering up again. Once I did that it worked fine and no more error messages.
2nd Aug 08. Seattle.
perfect solution
1. Fully charge the battery
2. remove and put the battery back.
3. remove and put the cassette back
4. smack on all sides. Moderate force :-)
it works !!!!!!!! Smacking does the job actually
Thanks to whoever did it first
mine works just perfect now
Thanks
jon
I didn't have anything to loose, by smacking my DCR-HC42 so I did it. I would never try and fix an electronic device by smacking it. The camcorder is now working, I am very curious as to how long this resolution will work.
I fix things, cars, outlets, what ever is broken. but that little bugger with all its gizmo's and gadgets in it... that I have on loan from school pulled the "reinsert 1 million times" trick. freaked me out cause it not being mine I cant take it apart, and the school would definitely bill me!!! So if their going to bill me they might as well bill me for something legit! so I lightly whacked a few times on the bottom and cassette case side with batt out and cass in. I don't have words to describe how amazed and dumbfounded I am that worked. like the russian in armegedon banging on the ship!
Oh my god i can't believe that worked! I called the sny helpiline and they didn't know what i was talking about! thanks youve saved so much hastle! xxx
it's true...smack it..thanks
i just tried the smacker solution.. held it between my knees and smacked both sides at same time around ten times...brilliant... thanks a million..camera has been out of action for a year, you saved me buying a new one.. many thanks..bridget ..dublin
    • By avatarcraigc266 Dec 19, 2010
    • Wow thanks mine is working like a dream pity I bought a new one a week ago but thanks any way
I really dont know how smack the camera please advise, im really scared i will destroy it.
I don't know what kind of recreational drugs the rest of these people are on, but I've hit it plenty of times and done just about everything that's been said here, and nothing fixes it. I refuse to believe anything is "stuck" because a camcorder without a tape behaves as normal.
OMG!!!
OMG!!!
OMG!!!
i cannot believe this tip worked
i was soooo amazed!!!!!
  • By Author imageGuest Sep 17, 2007
    • By avatarAl Miller Jan 30, 2011
    • It's actually an electrical connection between the cassette and the camera. If you take out the cassette
OMFG!!! This freakin works! I went to Best Buy and they told it'd be $70 to look at it to see what was wrong and offered me to look at what they currently have and see if I find an 'opened' cam that I can use temporarily and return it when I'm finished and receive no restock fee. Anyway, I googled troubleshooting reinsert tape and came here.Smacked my cam up, down, and sideways and reinserted the battery. With little faith, turned on my cam and low and behold! IT WORKED!! I just started chuckling. Thanks a lot! I had a lot of capturing work to do and now I won't have to rely on my older Sony cam.
Oh, and I had my tape inserted when I smacked it too.
-Rodlfo
  • By Author imageGuest Aug 30, 2007
Hey,
Thanks for the tip. Gave the camera a few good whacks, and everything seems to be working nicely. Hurts your hand, but a sore hand is worth two or three hundred bucks in repairs, I guess.
  • By Author imageGuest Jul 06, 2007
There is NO good explaination for this, but hey... it worked, so I won't ask questions...
  • By Author imageGuest May 22, 2007
Can anyone tell me if this smacking idea will also work on a Sharp ViewCam?
I have a problem were the Insert a Cassette icon is always on the screen and the camcorder doesn;t work because of this?
Could it also be caused by moisture?
If so, what is the best way of drying it our - airing cupboard perhaps?
Haha! I just had the same thing happen with my camcorder. I Googled up reinsert cassette and found this site.
Smacked the camera a couple times and low and behold, it works again. Amazing.
  • By Author imageGuest Apr 14, 2007
it really works thanks,
We're media students in Wales and the 'smacker' solution saved the day!
  • By Author imageGuest Mar 02, 2007
UNBELIEVEABLE but true, smacking the living daylights out of it does work!!! Can't tell you how thrilled I am, thank you!!
  • By Author imageGuest Feb 26, 2007
Hey smacker..ur a real techie man...i did exactly as u said n lo!...there are no error messages now and my cam's working perfect...thanks for saving the effort n ofcourse the cash!! Thanks..manoj,india
  • By Author imageGuest Feb 17, 2007
Ignore the hoity toity guy above. The smacking totally works. You don't hit it that hard. Just a little smack does it.
After you smack it, you need to eject the tape. Then when you turn it on, it must reset something, but it should work.
Thrilling but worked Just followed smacking instructions. I cannot beleive that just worked!! Oh godThank you so much!!
I have a handycam and I though it was broke from the reinsert cassette pop up on the screen. That was until I found this site, and deciede what the heck do I have to loose, I was hesitant but in the end I'm very glad i decided to smack my camcorder. This trick really works I smacked like 9 times then turned it on it still beeped to reinsert the cassette so I poped the tape open put it back in and closed the camcorder and to my supprise it was ready to record with no beeping of reinsert cassette. Amazing how something so simple could fix the problem! Thank you everone who posted this trick, my regards to you.
its been 2 year i didt use my camcoder cuz of this problem and didt go anywhr to fix it cuz of cost..i just googled my problem first time.. and fund this solution ..i cant belive..my cam start working now..
you are best mate..thanks for ya help
xxxxxxxxxxxxxxxxxxxxxxxxxx
Same problem giving up on it did reset worked again and stop! looked up problem. Smacked it hard 5 time with no cassett on side of cassett and top wife looked at me like !@!@!! Turned it on and works fine.
thnX ! cant believe !
we have been trying to fix our cam for a while now basically did what everyone else said and smacked the camera on both sides with the battery out and the tape in and it worked perfect. no more error!!! And to think my wife suggested this a while back and i told her she would break it. how was i supposed to know she was right.....
Well, I'll. Be. Damned. The very thing I was stopping myself from doing was the very thing it needed. It worked. THANKS!
I was getting the error "C:31:22 Re-insert Tape" after the dropping my TRV480 camcorder. I did a few smacks on the right side of the camcorder, but it did not work right away. I had just done a reset of the camcorder prior, but that had not worked either.
Once I took the tape, that it messed up on, and rewound it in my 8mm tape rewinder, said a prayer, and put it back in the camcorder, the error "C:31:22 Re-insert Tape" stopped. I was able to play the tape and other tapes that it would not accept at the time.
I am currently transferring all my Digital 8 tapes to DVD before it acts up again.
    • By avatarknightlight7 Feb 27, 2010
    • I had the
      "C:31:22 Re-insert Tape" on my Sony TRV480 camcorder after dropping it during recording. Even trying other tapes still showed this error and would not record or play.
      I tried reseating the battery and resetting the camcorder with the reset button. It still showed the error. I tried smacking it, as suggested, but still got the error. So I put the tape that was recording in my 8mm tape rewinder, rewound it, said a prayer, put it back in the camcorder, and it started working again - no error! Praise God!!!
thanks a lot friend! ;) unbelievable but true!! Respect!!!! I smaked it and it's working fine!!
HOLY COW! Its so weird. Being an IT pro I actually did not trust it. But then noticed that it worked for each and everyone here, hence gave it a shot. Smacked hard on sideways only. And VOILA!!!! It worked for one more person! Now I think we are more smarter than Sony techies, who would ask $100+ just for checking.
Before reading here I actually smacked it few times mildly, but the problem persisted. Now when smacked harder, it seems ok at least since last few hours. THANKS MATES FOR GIVING CONFIDENCE TO SLAP THE THING. lolz....
this is the truth try it and you will **** yourself! I promise!
At first I could not believe this quack medicine trick. I have a Sony DCR HC42 that give "Reinsert Cassette" message. But 60 people cannot be ignored. I did the whack according to Solution#48. It worked. From time to time the problem comes back but I know how to fix it with a whack. Til it really breaks. Thanks.
  • By Author imagejsodust Dec 19, 2009
OMFG DUDE! HAHA
I HAVE BEEN MISERABLE BECAUSE MY DAMN CAM HAS BEEN DOWN FOR 5 MONTHS.
SMACKED IT RIGHT NOW 3 TIMES
AND IT WORKED..
WHO EVER FOUND THAT OUT.
I LOVE YOU LOL
    • By avatargsxr60017 Dec 12, 2009
    • OMFG THIS WORKED.
      AND IT'S BEEN DOING THAT FOR 6 MONTHS..
      I LOVE WHO EVER THOUGHT OF THAT.
Camera has been sitting for a year because I did not want to spend the money to have it fixed. Damn.....wish I had Googled this a year ago.......
Works great now!!
My Sony Handycam TRV 138 had the same problem--"reinsert the cassette" in both record or playback mode. It also ate the tapes and snapped a brand new tape at the very first try. I discovered that cleaning tapes are no longer available in stores and no one repairs these "old" cameras locally. When I read the posts on this site, I was skeptical about smacking my camera, so I first tried resetting the camera as recommended by one post. It didn't work. So I removed the battery, left the tape in, and gave a very conservative smack to each side. The tape is currently playing fine...I just hope it lasts!
I thought the suggestion to smack the thing was probably submitted by Sony techies trying to drum up more business. BUT I tried it anyway. I gave it a couple of good whacks while it was still dinging at me to reinsert the cassette and it just kept blinking the error. So, then I shut it off and powered it back on and it worked- it actually worked! Thank you for the brilliant idea!
  • By Author imageESP77 Jan 07, 2009
we were really apprehensive before trying this smacking tips, but trust me guys it really works. This is the best and cost effective way to resolve this technical problem in Sony handicam.
thanks a lot.
My uncle has DCR - TRV285E PAL camera recorcer which has the same problem. We did not want to spend much money on it as it is very old. I smaked it too and after reading comments on net. It really worked. I think SONY should write this method in there troubleshooting manual.
  • By Author imagesherval Oct 24, 2008
Smack the camera on either side and try it ....this would solve the problem.
  • By Author imagehems7dl Sep 29, 2008
very good thanks alot man
  • By Author imageGuest Jul 31, 2008
hahaha smacking it works
  • By Author imageGuest Jul 18, 2008
I'm sure you can see by now that this works, at least it did for me! I'm now going to smack everything before taking it to a repair center.
  • By Author imageGuest Jun 28, 2008
Smacking worked great. Thanks for the tip. I had the same problem where it would display "Reinsert the tape". I followed this thread. Removed the battery and tape. Closed the tape compartment. Smack it lightly a few times. Keep it aside. Reinsert the battery and tape after 30 minutes. Worked like a charm.. You guys rock!
  • By Author imageGuest Jun 25, 2008
I have to give it up to the person who thought of this. My camcorder was reading error message to reinsert the tape and I checked alot of sites who recommended some tips but I cannot believe this one actually works. Just smack it on both sides and wha la, tape read like magic. I thought I had to spend money to fix it but the problem is solved. Thanks so much
  • By Author imageGuest May 18, 2008
WOW WOW WOW SMACK IT!!!! IT REALY DOSE WORK!
And to think i was going to pay 120 quid to get it fixed! thanks!
  • By Author imageGuest May 12, 2008
the smacking does work!!! incredible!!!!!!!!!!!!! thanks so much.
  • By Author imageGuest Mar 25, 2008
unbelievable! a few smacks, not even hard ones. and it works again.
  • By Author imageGuest Mar 20, 2008
On vacation right now, Sony TRV480 failed with same problem, :reinsert tape" error message, oh no, but googled and found this solution and it WORKED!!! Took out battery and tape, hard whack a couple of times near top and bottom, reinserted tape and battery, everything now back to normal. Thank you!
  • By Author imageGuest Mar 19, 2008
WOW. I cannot believed that actually just worked. but thanks.
  • By Author imageGuest Mar 11, 2008
I have a Sony DCR-HC100 that I bought for $1,300 and I have this problem after having about 20 or so hours of use. I called Sony and they would charge me $300 for fixing it. I have suffered a lot from resetting the camera and reinserting the tape trying to get the workaround. Today I found this website and give the camcoder some good smacks and it works!
What a brilliant idea to fix Sony problem!
  • By Author imagelynhnn Feb 12, 2008
Initially I thoght ..someone is trying to fool...
but IT ACTUALLY WORKS...
wow!!!
Thanks
Manoj
    • By avatarmanu707_in Feb 03, 2008
    • It Works!!!
      Amazing!!!
      wow!!!!
      -MAnoj
WOW, can't believe it worked!
  • By Author imageGuest Jan 19, 2008
Unvelievable. I started getting the error on my DCR-HC42. I couldn't get a tape it as it would get stuck. When it did go in, I got the error to reinsert the tape. I removed the battery, smacked it around a little bit, and now it works!
Thanks for the post!
  • By Author imageGuest Jan 10, 2008
I am a Sony DCR-HC42E owner had the re-insert cassette error gave it a good old smackarooney as suggested and its now behaving, brilliant thanks a million!!
  • By Author imageGuest Jan 07, 2008
It worked for my sister in Argentina also, she says thank you very much! She was upset because she couldn't use the camera and now it is fixed...I love it ! thanks!
HAha, thats crazy. Worked for me to! Thanks a bunch!
  • By Author imageGuest Dec 29, 2007
I love you.
  • By Author imagesabian1 Dec 09, 2007
It worked, thanks a mil.
  • By Author imageGuest Dec 02, 2007
insert the cassette. remove the battery. smack the camera a couple of times up, down, sideways...behold and lo....it works!!!!!!!!!! the greatest mantra....all credit to the originator of the solution in this very site... you are awesome man...you should be cheif solution designer for Sony...!!!
I thought, what do I have to loose here, smacked it 4 times each side and wow it works???????????????
thanks for the tip
odd what but its ok again
  • By Author imageGuest Nov 21, 2007
Hey!! Amazingly the slapping solution works man !!! Great !!
Now my cam works.....
Wow- it worked*****thanks for actually being helpful unlike the BestBuy Folks.....
  • By Author imageGuest Nov 16, 2007
Smacking works!!! Just do it and dont ask questions.
LOL
Mike M
  • By Author imageGuest Nov 07, 2007
I have the same problem.
  • By Author imagehaohao Nov 04, 2007
    • By avatarhaohao Nov 04, 2007
    • I did, but doesn't work.
omg this is weird just smacked my camera in the booty and it worked!!!!!
  • By Author imageGuest Sep 22, 2007
thanks you guys, smacking it really worked. Im so relieved right now.
  • By Author imageGuest Sep 03, 2007
Smacking my Sony DCR-TRV480 fixed the problem when it started prompting me to "please reinsert cassette." I hope this isn't a sign of bigger problems, but it did the trick for now.
  • By Author imageGuest Aug 20, 2007
Oh My God! You are a life safer....how the hell does that work? Saved from being killed for braking my dad's camera!
Thanks alot
  • By Author imageGuest Aug 09, 2007
Great! Got our camcorder in Australia over a year ago and thought we would have major hassle and expense getting it fixed - just smacked it a few times and now its working again!Brute force saved the day!! Thanks :)
  • By Author imageGuest Aug 08, 2007
Just followed smacking instructions. I cannot beleive that just worked!! Thank you so much!!
  • By Author imageGuest Jul 20, 2007
    • By avatarcopperhead11 Jan 29, 2011
    • smacked mine out of frustration and it worked LOL but i fogot that i smacked it and it done it again. So i let my cam sit for months then googled this LOL smacked it again on the tape side with batt out and works perfect , this is almost a brand new cam.
      There is a smack test in electronics to see if a short is or loose connection is the issue. and its just like that smack a tv on the sides , smack your vcr hell smack your wife when she dont work LOL no just kidding that dont work.
Add Your Solution
See all Sony Handycam DCR-HC42 Mini DV Digital Camcorder Problems
