Question about RCA HD50LPW175 50" HDTV
Projection TV No power at all' Suddenly stop try to turn on only hear clicking sound. No light on switch too. Thabnk you Sergie
    Brigadier General:
  • 6,966 Answers
Hi again,
it would seem that you posted multiple times. Please see your "Ask Me" post for a proposed solution to your concern.
Hopethis be of initial help/idea. Pls post back how things turned up orshould you need additional information. Good luck and kind regards.Thank you for using FixYa.
Posted on Nov 17, 2008
Akai rear projection tv suddenly stopped working.
This set with Akai is actually made by Samsung (they own and use the Akai name).
If lamp light etc and you have heard a cracking sound it may be the color wheel.
You can remove the lamp and look where it faces--look and the wheel can be seen----is it shattered or missing plastic pieces?
The wheel commonly fails in this fashion and is turning at over 12,000 rpm. The set will detect if the wheel is stopped or moving too slow and just what you describe will happen.
Wheel is widely available and You Tube has video instructions for replacing them by model number.
Questions?
Mar 28, 2012 | Akai PT5492S 54" Rear Projection...
My HL-P5063W won't power on. I replaced the Digital Video Board and the lamp. When I power up the the TV, there are several clicks and never a picture. The lamp does not appear to getting any...
Did u ever replace the Ballast board for this tv?No?,that ur tv problems.The Ballast board only job are to ignite the tv projection lamp to make it work.U hearing multiple clicks,lamp never ignite up the Ballast board.
Jul 29, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
While we were watching Sony KF60WE610 TV suddenly a loud noise came from the back of the TV,. Sound and picture were gone, and the red light started blinking. We waited 2 minutes and turn on the TV . Sound...
Tv now,have a LED light indication "LAMP" on the frame are blinking or flashing.Metallic sound are clicking noises?Yes,sound like the board that call the Ballast board it is dead.This Ballast board only job are to ignite the tv projection lamp only.U have some mechanicals skills like take things aparts and putting it back together again?Yes,tries websites like Partstore.com,Ebay.com to buy a new Ballast board for the replacement.The tv projection lamp might have to be replacement change too,because,when the Ballast board has died and exploded the voltages and current high voltages could have more than the tv projection lamp now could take.
Jul 21, 2011 | Sony Grand WEGA KF60WE610 60" Rear...
I turn the power buttin on....after about five
When was the projection lamp last change?If the tv,projection lamp inside the tv at last change was 1/ 1/2 or 2 years ago,and the tv is on,an in use at lest 4 or 5 hours day.The projection lamp life,it over should be change the projection lamp.Now tv turn on LED light "LAMP" indication light up or flashes?Yes,the projection is dead,hear alot of clicking too?The Ballast board it also dead,should be change too.The Ballast board,this board job,it help to ignite the projection lamp.
Jul 23, 2010 | Toshiba TP61H60 61" Rear Projection...
Whenever i plug the unit in i hear a clicking sound from the back of the television it is for about 3 seconds and it usually takes 2-5 seconds before it starts the noise. The power light only comes on for...
Ur tv turn on now,hear alot of clicking?The tv LED light "lamp" on front panel flashes or light up?The tv projection lamp is dead.The Ballast board dead too,if hear alot of clicking?The ballast board help to ignite the projection lamp.
Jul 16, 2010 | JVC AV-56P575 56" Rear Projection...
Heard clicking sound then pictures suddenly disappear and the tv keeps turning off and on by itself
The tv have a board call the Ballast board,that help to ignite the projection lamp.Tv power on hear alot clicking.That mean the Ballast board is dead,must be replaced.
Jul 13, 2010 | Samsung HLP5085W 50" Rear Projection...
My 1080p Mitsubishi television suddenly stared to switch itself off and then a red light would flash for a minute. When I turn it back on I am geeting sound for a few minutes and then it switches itself...
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php But if you don't hear any strange noises,tv is around 4000 hrs,1-3 yrs it could be time to replace the lamp.The lamp you need is 915b403001 .Have a blessed one!
Mar 29, 2010 | Mitsubishi WD-60735 Projection Television
Tv will not turn on
its a clicking of switching relay. cannot power on due to power supply failure.
May 30, 2009 | Sony KP-48S70 48" Rear Projection...
Standby/timer light stays on red. no picture or sound on tv.
my sony red light flash.but it will not turn on just clicks
Nov 26, 2008 | Sony KP-48S75 48" Rear Projection...
Projection TV
Appreciate the direct "Ask Me".
Initially, the clicking sound is the relay inside that is engaging. In some instances, this symptom could indicate that the relay contacts have corroded or burned and are no longer providing electrical contacts. Normal course of repair would be replacing, but some have known to work with even just cleaning/scrapping.
That above was the easy probable fault. At other other times, the relay clicking indicates the the Mitsubishi is triggering off, meaning its built-in protection has kicked in. This is indicative of a hardware fault. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Nov 17, 2008 | Televison & Video
RCA HD50LPW175 50" HDTV Logo
59 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
