Question about Drills
BOSCH HC8531 CORE BIT
I NEED USERS MANUAL FOR THE BIT. DO YOU USE WATER WHEN DRILLING INTO CONCRETE?
  • 50 Answers
No u dont need water when drilling into concrete with a concrete bit.
Posted on Dec 05, 2008
How do you drill through ceramic tile
Go to Lowes, Home Depot, Menards or reasonably good Hardware store. buy a ceramic bit. They are usually with the wood, steel and concrete bits. Small bits arent to pricy. If you need a larger hole like the on the shower pipe goes through, you will need a ceramic hole saw. Hole saws are coated with diamond chips and will probably cost $40 or more. good Luck
Oct 08, 2015 | Porcelanosa Ceramic Wall Tile: : Mosaico...
What speed would i need to set my cordless drill at to put hole in wall
Your drill will drill a hole at any speed, the drill bit needs to be sharp to drill the mateirial.The type of wall material is important.Drywall is soft but a masonry bit should be used.A masonry bit has a flat bar accross the point and slower speeds are best.Wood walls / studs you need wood bits that are sharper and medium to high speeds are used.Concrete or Block walls again require Masonry bits.If very hard concrete as in foundation walls or filled block the use of a Hammer drill will work much faster.Good Luck
Jul 29, 2011 | Drills
How to adjust the part that holds bit
what do you mean adjust the bit? either its tight on the bit or it isn't. not tight it will slip!
Oct 18, 2009 | Bosch 11258VSR Factory-Reconditioned 5/8"...
New bosch psb 550 re with hammer action. Hammer action does not seem to engage. even with 5mm bit progress is non existent. The bits were bosch masonary bits and I was drilling into concrete blocks
your pin under the selector switch my have broken off. also the hammer rod could have broken too. if its drilling and not hammering that more likely. you may be under warranty call bosch or log on and go to dealer locator's for the closes dealer to you. hope this helped
Oct 09, 2009 | Bosch Power Tools Hammer Drills
Bit or chuck type for a Skil 717 hammer drill
I have a Skill 717, too. It has a hex shank. Here are a couple places that I've located that carry (some) parts:
www.icscuttingtools.com (pages 155 & 157)
www.bamanufacturing.com/page_15.htm
also try:
www.ereplacementparts.com
www.toolpartsdirect.com
Sep 12, 2009 | Skil Drills
Bosch 11222EVSG hammer drill not turning
Couple things to look at, First is the selector in the hammer/rotation mode? Without a bit in it does the collar turn when in the rotation mode. Are you using the right bits for this tool. If yes to all of these I would look down the spindle and make sure that the pawl are in place (they lock to the bit for rotation) Let me know and we will dig deeper.
Mar 06, 2009 | Bosch 11222EVSG 1 1/8 Inch Grounded Sds...
BOSCH 11236VS HELP ME WITH A PROBLEM
I order parts for my Bosch tools at WWW.toolpartsdirect.com. They have the parts lists also so it is easy to find what you need. Don't forget to order some bosch grease for your tool because you will need to carefully wash-out all the old grease with metal bits. Good luck with you repair. Enjoy
Nov 25, 2008 | Bosch 11236VS Rotary Hammer
Drills Logo
261 people viewed this question
Top Drills Experts
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Drill Expert? Answer questions, earn points and help others
