Question about Systemax (036052) PC Desktop
Cannot restore to factory settings because lost system administor
Also when I boot up to bios/cmos page I do not have password
  • paisans Nov 19, 2008
    Technotech was close. he forgot to mention that there is a jumper that needs to be removed and replaced near the battery. Battery does not have to come out. Thanks anyway.
    Sergeant:
  • 237 Answers
Your question was not quite finished...I will assume you lost your reinstall disk. No problem...go to the Start menu, All Programs, Accessories, System Tools, and System Restore. Follow the directions through thye system restore wizard. You will get to pick a day and time for your system to restore back to. If you have a XP, there should be many days to pick from...you may not even need to go too far back. If you know what you are trying to avoid( as in the reason why you are trying to restore your system...virus? software loss? etc) just go back to the day of or the day before for your restore. Just remember you will lose any of the information after that date, so be sure to make a backup of everything you need or want!
Posted on Nov 17, 2008
  • zabrina liang Nov 19, 2008
    glad it worked out!
    Novelist:
  • 183 Answers
Open your computer and on the motherboard there is a Battery which looks like a Coin, Take it Out and Turn on and Turn Off your computer once,Put the battery back on motherboard and Tur on your coputer you will be able to go into BIOS without password. Then you can try recovering your computer to Factory Settings.
Can't find the reset Password pin near the Battery
If you are prompted for the Windows password, this would mean that your Windows user name is password protected. This is separate from the BIOS password. Resetting the BIOS password on your computer will not reset your Windows password. If you are unable to recall your Windows password, or if you do not recall setting up one, try to leave it as blank and see if it works. If not, your other option is to restore your operating system through a previous restore point. **WARNING: Be sure to try to backup important files before you proceed as this can cause data to be lost.** Try to boot using your Windows Disc and perform a repair install or a full operating system reinstall. Another method is to use the factory restore option on your dell computer if it is still available. To do a factory restore, restart the computer and as soon as the Dell logo/screen shows up, hold down the CTRL key on the keyboard and press the F11 key a few times and release both keys. once you get to the screen where you can choose to restore to factory settings select Restore then press Enter. Let it go through the process and select FINISH once you get the message that it is completed .
Mar 16, 2015 | Dell Dimension 8250 PC Desktop
Tip
Problem: You do not have access to change the settings in BIOS? . Have bought a...
There are two passwords in BIOS. One is start up password, the other isBIOS setting password. If you have forgotten the start up password thatmeans you cannot open computer at all. Then the first method is theonly thing you can do. Other methods can use to clear setting password.
==①:Motherboard Battery Discharge==
The common way toreset start up password is discharge Motherboard Battery. Most of thecurrent motherboard BIOS is using the button batteries to provideelectric power.That means if there is no electricity, the informationit contains will be lost. When it’s on power again, BIOS will set backto its original state, of course, there will be no BIOS passwords. Butyou will lose your setting at the same time.
What we need to dois to power off computer, open the computer box, and then unplug thepower plug of the computer to make sure that it is no electricity atall. Then locate the white silver button battery on the motherboard.Remove the battery carefully. Perhaps 30 seconds later, put back thebattery.
After put back the computer box then power on, thesystem will prompt “CMOS Checksum Error-Defaults Loaded”. That meansCMOS errors detected during inspections, had been included in thesystem default, BIOS password cracking success!
On somemotherboards, the battery is soldered to the motherboard, making itdifficult to remove. If this is the case, you have another alternative.Somewhere on the motherboard you should find a jumper that will clearthe BIOS password. If you have the motherboard documentation, you willknow where that jumper is. If not, the jumper may be labeled on themotherboard. If you are not fortunate enough for either of these to bethe case, you may be able to guess which jumper is the correct jumper.This jumper is usually standing alone near the battery. If you cannotlocate this jumper, you might short both of the points where thebattery connects to the motherboard.
==② : Backdoor BIOS Password==
Eachmotherboard manufacturer has set a backdoor password in order tofacilitate the provision of technical support. The backdoor password isa BIOS password that works, no matter what the user sets the BIOSpassword to. These passwords are typically used for testing andmaintenance. Manufacturers typically change the backdoor BIOS passwordsfrom time to time.
AMI Backdoor BIOS Passwords
Reported AMIbackdoor BIOS passwords include A.M.I., AAAMMMIII, AMI?SW , AMI_SW,BIOS, CONDO, HEWITT RAND, LKWPETER, MI, and PASSWORD.
Award Backdoor BIOS Passwords
Onereported Award backdoor BIOS password is eight spaces. Other reportedAward backdoor BIOS passwords include 01322222, 589589, 589721, 595595,598598 , ALFAROME, ALLY, ALLy, aLLY, aLLy, aPAf, award, AWARD PW, AWARDSW, AWARD?SW, AWARD_PW, AWARD_SW, AWKWARD, awkward, BIOSTAR, CONCAT,CONDO, Condo, condo, d8on, djonet, HLT, J256, J262, j262, j322, j332,J64, KDD, LKWPETER, Lkwpeter, PINT, pint, SER, SKY_FOX, SYXZ, syxz,TTPTHA, ZAAAADA, ZAAADA, ZBAAACA, and ZJAAADC.
Phoenix Backdoor BIOS Passwords
ReportedPhoenix BIOS backdoor passwords include BIOS, CMOS, phoenix, andPHOENIX. Backdoor BIOS Passwords from Other Manufacturers Reported BIOSbackdoor passwords for other manufacturers include:
ManufacturerBIOS Password
VOBIS&IBM merlin
Dell Dell
Biostar Biostar
Compaq Compaq
Enoxxo11nE
Epox central
Freetech PosterieI
Will iwill
Jetway spooml
Packard Bell bell9
QDI QDI
Siemens SKY_FOX
SOYO SY_MB
TMC BIGO
ToshibaToshiba
Remember that what you see listed may not be the actual backdoor BIOS password,this BIOS password may simply have the same checksum as the realbackdoor BIOS password. For Award BIOS, this checksum is stored atF000:EC60.
==③: Software Crack==
There are a lotsoftwares to test systems or start up password, but they need to run onWindows. So it is only used to reset BIOS setting password.
!BIOS will recover the BIOS password for most common BIOS versions, including IBM, American Megatrends Inc, Award and Phoenix.
CmosPwd will recover the BIOS password for the following BIOS versions:
•ACER/IBM BIOS
•AMI BIOS
•AMI WinBIOS 2.5
•Award 4.5x/4.6x/6.0
•Compaq (1992)
•Compaq (New version)
•IBM (PS/2, Activa, Thinkpad)
•Packard Bell
•Phoenix 1.00.09.AC0 (1994), a486 1.03, 1.04, 1.10 A03, 4.05 rev 1.02.943, 4.06 rev 1.13.1107
•Phoenix 4 release 6 (User)
•Gateway Solo - Phoenix 4.0 release 6
•Toshiba
•Zenith AMI
Ifall else fails, you might be going to lose some money for technician.But they will use these same methods, try hard by yourself.
on Jan 29, 2010 | Computers & Internet
Acer aspire one kav60 restore asking for a password.
how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard some motherboards cmos batteries are soldered in
Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased
or if using XP
Restart your computer during the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer Advanced Boot Options screen appears.
Select the Safe Mode option using the up and down arrow keys, then press the ENTER key. Choose "Windows XP Home/Professional", depending on the version of the operating system.
Press ENTER. Shortly, the welcome screen should show.
Log in as "Administrator". Click Yes to not use System Restore Mode.
Click the Start button. Choose Run and type in "control user passwords" (without the quotes). Click OK.
Select the "Administrator" user. Click Change my password. Enter a new password in the corresponding text boxes. Click OK. Write this password down and store it in a secure place Close the User Accounts window and restart Windows.
if still no luck
click start type cmd press enter
At command prompt type debug
you will get a - prompt where you can type the following (<enter> means press enter, not type enter*)
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
<ENTER> just hit enter on this line
G <ENTER>
Q <ENTER>
Basic BIOS password crack - works 9.9 times out of ten hope it helps
Apr 27, 2012 | Acer Aspire Computers & Internet
ACER ASPIRE ONE KAV60 AOD250-1198 RESTORE AND NO PASSWORD
or if using XP
if still no luck
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
G <ENTER>
Q <ENTER>
Apr 27, 2012 | Acer Aspire One PC Notebook
How do i restore my dell INSPIRON 1525 to factory settings if i cant remember MY BIOS PASSword
factory setting mat not remove the password,open the laptop and remove the CMOS battery,on the system and then replace back the CMOS.
Aug 29, 2011 | Dell Inspiron 1525 Laptop
I have a hpcompaqdx2200 with password protection and no recovery cd to reformat to facory settings and no f11 function to restore via system set up - can i restore to factory settings via safe mode command...
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
Sep 18, 2010 | HP Compaq Business Desktop dx2200 - P4 524...
My laptop keyboard not work at booting time
I would first try to reset the CMOS according to the manufacturer's instructions provided on the manual.
Try that, and please report back the results.
You might wonder what is CMOS?
Complementary metal oxide semiconductor (CMOS)
is a type of semi-conductor chip that holds data without requiring an external power source. In a personal computer (PC), CMOS holds the basic instructions the computer needs to initialize its hardware components and boot up. These settings are known as the basic input output settings (BIOS), also referred to as CMOS settings.
Steps to Reset CMOS - BIOS Setting.
Turn on your computer and press the key on your keyboard to enter the BIOS. This is typically the Del (delete) key. Pre-built systems from major manufacturers may use a function key such as F1, F2, or F10. Go to the last tab or page of your BIOS. Select an option similar to "restore factory settings". Save your changes and confirm your selection if necessary. This will often be combined with the process of exiting a BIOS. Some BIOS types may have this as a separate option such as "F10: Save Changes".
Please let me know if you have any further questions or concerns.
Thanks.
May 04, 2010 | HP Compaq Presario C500t Notebook
I NEED A PASSWORD TO OPEN MY DELL SYSTEM LAPTOP
You need to find a BISO/CMOS password reset tool, try googing them.
Apr 27, 2009 | Dell Latitude D600 Notebook
OUt of warrenty and need to restore settings/computor.I cant log on in administor account. cant even create an administor account. can you help?
If this is Windows XP, have a friend download and burn the Ophcrack bootable CD. Boot it and follow the directions. If your password is no longer than eight characters, then it will recover your password for you. Results head south when passwords are both longer and more securely structured, especially in Vista, but I've had only one "lost XP password" it could not locate for me in quite some time.
http://ophcrack.sourceforge.net/
Jul 19, 2008 | E-Machines Computers & Internet
Rebbot to factory settings
Hi bgreenejr,
Are you referring to the BIOS or OS?
If you’re referring to the BIOS settings, you can do this by accessing it and selecting "set to factory default" from the menu. The most common way to access it is by pressing the DEL button upon boot up; there are however, a lot of branded PC and laptops may use a different button like F2 or F12, etc; if you’re BIOS is locked, of course you’ll need the password to log-in.
Another and common method of resetting it to factory default is by shorting the CMOS reset jumper located in your motherboard, usually it’s the closest jumper to the battery or the CMOS chip. This does not require any password, actually this is the method used if you forget your BIOS password. I would suggest that you consult your motherboard or computer’s documentation on how to locate the CMOS reset jumper on it.
If you are referring you your operating system, the only sure way to reset it to default settings is if you do a clean install, that means re-formatting your pc and re-doing everything again, kinda messy, unless you can do a system restore that would revert it back to the original date and time when you first install the system, . Hope this helps
Cheers and best regards,
May 06, 2008 | Computers & Internet
Systemax (036052) PC Desktop Logo
574 people viewed this question
Top Systemax Computers & Internet Experts
pankaj rautela
pankaj rautela
Abhinandan  Patil
Abhinandan Patil
Mike
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
