Question about Kenmore 24032\24036 Top Load Washer
F1 error on Kenmore Oasis HE Quietpak 9
Ugh, we keep getting this error at the start of each load and then in the middle of a load. Do we need to call someone out do you think? I saw the eprom comment, our washer is properly grounded. And if someone does come out to look at it do you know if it's even repairable?
  • caesar123 Dec 04, 2008
    Same issue here. We had someone come out and they recommended a new control board. Something like $300 plus the $150 for his visit already. Wondered if I can put the control board in myself and how much it might cost online.
  • Anonymous Dec 07, 2008
    Yep - same problem here. We've had the washer and dryer for almost two years and this is the first problem we've had. It started yesterday with the F1 error at the beginning. I lighten the load by a couple of pieces then it seems to be okay. I'm concerned about what the real problem is. Seems as though from searching for an answer several people are having problems!! Any solution would be helpful! I hate to think I spent all that money on these two appliances and they are faulty! msbreaux@comcast.net
Same F1 issue after about 18 months. I spoke with Kenmore and they don't acknowledge there is any problem. After reading posts online I ordered the motor control board from Sears just under $200.00 with shipping.I noticed when I ordered the new board that it has a new part number. So they must know there was a problem and replace the old board with this new part number. It took me about 5 minutes to install it and it seems to be working fine.
Posted on Jan 09, 2009
    Genius:
  • 1,028 Answers
Question is not is it repairable but is it under warranty ..most likely bad control bd under console
Posted on Nov 17, 2008
Toploader kenmore elite oasis is showing F1 code for error. I do not have an owners manual. What does F1 mean?
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
Gene
Aug 21, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
When I start my Kenmore Elite Oaisis HE washer, I keep getting an error, "F1". What does this mean?
Hello & Welcome to FixYa
Error Code F1 means that the control is either bad or the wiring harness to the control has some issues. Please check the control board for any bad components as you might need complete replacement of the control. Please get back to me if you have any other questions.
Kevin
Dec 11, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
What does F1 code mean
A Sublime Master at the Samurai School of Appliantology recently did battle with one of these newfangled Oasis washing machines. The F1 error code was intermittent, which made it impossible to troubleshoot. Turns out there’s a service bulletin out on this problem. Come, feast your bewildered eyeballs on the wisdom of the Masters.
Read more: Recurring and Intermittent F1 Error Code on a Whirlpool / Kenmore Oasis Washer | Washer Repair | Fixitnow.com Samurai Appliance Repair Man http://fixitnow.com/wp/2009/01/25/recurring-and-intermittent-f1-error-code-on-a-whirlpool-kenmore-oasis-washer/#ixzz0vdcTKwJA
Get appliance parts at http://parts.fixitnow.com
Aug 03, 2010 | Kenmore Oasis HE 27082 Top Load Washer
F1 error
yep electronis control board in the console is bad.
Apr 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
F1 & F51 error on my Kenmore Elite Oasis HE washer
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the bad board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
Feb 08, 2010 | Kenmore Oasis HE 27082 Top Load Washer
F1 error code on Kenmore Oasis He
I think there might be a recall on your washer call to see. I am not for sure that there is a recall but I a m pretty sure there is. So don't quote me on that. the f1 error code usually means that you have a bad board. f1 means that your pressure switch line is failing and this is all in your board. check your owners manual if whirlpool is not going to pay for this repair sometimes there are extended warranties in your manual
May 29, 2009 | Kenmore Oasis HE 27082 Top Load Washer
My kenmore elite oasis washer will not turn on. I
its the power button its a common prob use a soldering iron and switch it with the load sinal button this happpens as the washer alallows moisture to get on the board as its not protected it will save u a ton of money and anyone can do it
Apr 26, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Moister can get in between the contacts,is it in a high moister environment? Try using a hair dryer on the panel to dry it out.Also unplug it to reset.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
95 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
