Question about Procom ML300HGA Heater
Pro Com QD250T can I install directly to a 4 gal. Propane tank
I bought a Pro Com QD250T dual fuel vent free stove. Can I just hook it up to a 5gal. propane tank? I really don't want to run hard lines into the house from another tank. We live in the Pacific Northwest and would just put it away for the summer months. Can I do this?
  • 4 Answers
You should not have the Tank in the house , it's like storing a bomb in the house . for more info call 1-866-886-5989
Posted on Jan 14, 2009
I bought an Insta Flame model FSDV 30 direct vent wall furnace, need a natural gas conversion kit. It currently is set up for propane and could use some help in finding the parts and installing them.
There is a ban on that particular furnace as they can explode!
You won't find parts or anyone that will work on it.
[PDF]TSSA Bans Series of Insta-Flame and Northern Flame Fireplaces www.dunnheating.com/.../TSSA%20Bans%20Series%20of%20Insta_Flame%20and%...
  1. Cached
  2. Similar
Oct 23, 2012 - (TSSA) has banned a series of natural gas and propane-fired direct vent ... 'FSDV22' or 'FSDV30' or 'FSDV32' in the model name or number.
TSSA Bans Series of Insta-Flame and Northern Flame ... - CNW Group
www.newswire.ca/.../tssa-bans-series-of-insta-flame-and-northern-flame-fireplaces-51...
  1. Cached
  2. Similar
Oct 23, 2012 - All Insta-Flame and Northern Flame natural gas or propane-fired direct vent freestanding fireplaces with 'FSDV22' or 'FSDV30' or 'FSDV32' in ...
[PDF]Fuels Safety Program DIRECTOR'S ORDER - TSSA
https://www.tssa.org/corplibrary/ArticleFile.asp?Instance=136&ID...
  1. Cached
  2. Similar
Mar 25, 2016 - Natural Gas Fired Direct Vent Free Standing Fireplace - Model ... Insta-flame or Northern Flame: Models FSDV22, FSDV30, FSDV32, D222.
Majestic Fireplace - - Recalls & alerts - Healthy Canadians Website
www.healthycanadians.gc.ca/recall-alert-rappel-avis/hc-sc/2012/15058a-eng.php
  1. Cached
  2. Similar
Nov 9, 2012 - Natural gas and propane-fired direct vent free-standing fireplaces ... Insta-flame or Northern Flame (Models FSDV22, FSDV30 and FSDV32, ...
TSSA Safety Order Ban of Majestic FSDV22, FSDV30 and FSDV32
www.fireplacegroup.ca/tssa-safety-order-ban-of-majestic-fsdv22-fsdv30-and-fsdv32/
  1. Cached
  2. Similar
Dec 21, 2012 - TSSA Safety Order Ban of Majestic FSDV22, FSDV30 and FSDV32 ... CFM Inc. (Majestic Fireplace) and bear the trade names Insta-Flame or Northern Flame ... (a) Natural Gas Fired Direct Vent Free Standing Fireplace - Model FSDV22, FSDV30 ... -Stove shipped as natural gas; LP Conversion Kit included
http://www.healthycanadians.gc.ca/recall-alert-rappel-avis/hc-sc/2012/15058a-eng.php
Dec 11, 2016 | Kitchen Ranges
Ven tfree propane fireplace will not stay running after being ignited
You may have one of several issues that can cause this ...
1. your pilot assembly could need replacing
2. you may not have enough ambient air flow and the oxygen sensor will shut it down
I suggest you have a qualified technician come out and inspect the system to see where the real issue lay. They will have to light it and see it burn to rectify the issue.
Jan 25, 2014 | Procom Dual Fuel Vent-Free Fireplace with...
Can a 20lb tank be hooked up to a Coleman 2 Burner Stove 5430A
Yes. There are multiple adapters made to fit this application. Your local walmart most likely will have them. http://www.walmart.com/ip/Coleman-5-High-Pressure-Propane-Hose-and-Adapter/19897422
Sep 18, 2013 | Coleman 2 Burner Propane Stove 5430E700
I have a wall mount vent free heater and a 10 gal propane tank how do hook it up so it will work
First off, Dave, the tank cannot be inside the house, motor home, camper, garage, etc. By the way, I believe your 10 gallon tank, is what's called a 40LB cylinder. Anyway, 10 gallons is not going to last very long, if the heater you plan to install is 20,000 Btu output or higher. If it's going in a bedroom, the maximum Btu output can not exceed 10,000 Btu's.
To install one, you'll need 1/2" flexible copper gas piping. An in-line LP Gas regulator, that has the capacity to carry whatever the maximum Btu output of you heater is. In addition, you will need a 1/2 NPT to 3/8" Flare nipple to go into the back of the heater. Assorted Flare Nuts in assorted sizes for the gas line connections.
Tools needed: Flaring tool, 2 adjustable wrenches, Phillips Head Screw Driver & Leak Detector Solution. To make sure it's done correctly, a Mechanical/Plumbing Permit from you city or county's Building Inspection Department. And last, but not least, a friend that has a lot of knowledge in the installation of Vent-free Supplemental Gas Heating Appliances.
If installed properly, these appliances are very safe. If installed improperly, they can be very dangerous.
Mar 04, 2011 | Heating & Cooling
Just had fuel delivered and the heater burner won't start. Probably a bubble in the line?
This is probably due to the fact that you will need to purge the line. Be sure to ventulate the area that the stove is around and make sure you have no open flames while doing so. Also, remember that if you fill your propane tank FULL then it will take a little while for the pressure to build up in the tank because its cold outside.
Hope that helps.
Jan 27, 2011 | Rinnai Toyostove Direct Vent Heater: Laser...
Procom ML300HGA Heater Logo
441 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
