Question about Maytag MZD2766GES Side by Side Refrigerator
Water/freezing to ice at the bottom of the freezer MZD2766ge
After Hurricane Ike here in Houston and being out of power for 12 days, my freezer is now accumulating ice on the very bottom inside. I have slowed the water spigot to try and slow down the water pressure to the ice maker, but it is still just as bad. I'm having to chip the bottom wire bin out of the ice every 3 days or so... I'm afraid if I'm out of town the thing will accumulate so much, I won't be able to open the freezer door as the ice will be so tall the door will be frozen shut! The icemaker is still making plenty of ice. Please help! Thanks!
  • cyoung166 Nov 17, 2008
    I have a maytag wide by side and it does exactly the same thing. I've chipped the ice out of it numerous times. I was suspecting the ice maker - but I've never seen water run out of it and it makes ice just fine. It takes about a week to build up the ice in the bottom. I've searched on-line for a fix to this and I suspect a plugged de-frost drain tube or frozen one. Going to check that out and post back if that fixes the problem.
  • vihstadt Nov 29, 2008
    Ok I removed the freezer back (finally) and it was indeed clogged at the bottom. I used hot water and a long handled baby bottle nipple brush (a fat pipe cleaner would work also) and pulled some gunk out of the tube. I did open the back also and pulled the tube GENTLY out of its drain pan and using the same brush made sure all clogs were gone. Thank you SO MUCH for your help, I was ready to give it the boot as I've already had two compressors put in this thing since I bought it new in 2002 and didn't want to spend anymore $$. I will buy an LG next time....hopefully I can wait a few more years though. THANKS again!
    President:
  • Maytag Master
  • 2,651 Answers
Sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all that ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youll melt everything) or by pouring hot water down the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Posted on Nov 17, 2008
Ice on bottom freezer
What is the model number of the unit?
Nov 05, 2012 | Whirlpool Refrigerators
We have a LG bottom freezer refrigerator we bought in 12/08 and the ice maker is not making ice but still sounds like it is and the water line is open. Freezer is freezing foods ok and the top of...
Make sure water is gettig to solenoid vale on back. If so make sure screen is not plugged and solnoid is real opening. May need to test coil on valve. If it is not opening or froze off Ice marker will cycle several times a day as it is temp actuated.
May 08, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Moldy taste from Whirlpool side by side
The problem can still be in your lines, or in the dispenser itself. If you run hot water with a little bit of vinegar in the lines and let it sit for about 30 minutes and then flush the whole system this should take care of your problem
Apr 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
System was off
Hello. Did you try running the water through the door until it becomes room temperature? This will completely flush out the water resouvior in the fresh food section. When it comes to the ice tasting bad, a lot of the time it is from something that has gone bad in or behind the crisper drawers. Take the drawers out and check. You may be thinking how can something in the frig compartment effect the ice? The frig is cooled by the freezer by a opening in the top and bottom of the center divider. Hopefully this helps.
Dec 03, 2008 | Estate TS25AFXK Side by Side Refrigerator
Freezer section not cold enough/fridge ok
sounds as if you might have a compressor related sealed system problem, youll have 5 year war on such an issue from the manufacture
Oct 29, 2008 | Maytag MSD2758GEW
I lost power for several days during Hurricane Ike. When the power came back on, I cleaned out the ice maker bucket and let it make new ice. It makes ice and the light comes on when you press the...
when you repl the filter it has to be purged to bleed all the air out just keep askig for wtr until you purge all the ait out dispence at least 15 large glases of wtr
Oct 14, 2008 | Whirlpool Refrigerators
Freezer not freezing
Check to see if the fan motor in the freezer is running. Most likely it is not circulating the cold air Also make sure the defrost drain line is clear and has drained out. A frozen sheet of ice will restrict airflow also
barneyluc.
Sep 28, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice maker stopped after electric shutoff
You may have a problem with the computer control board in the ice maker.  Try this.  Turn off the icemaker for about 2 minutes.
Turn on the ice maker and press the clear button.  Press and hold this button for 12 seconds to get it to force extract.  This will confirm that the motors will work and push the ice cubes out.  Afterwards, let it run by itself.  If it still doesn't make ice, you will need to replace the icemaker.
Sep 19, 2008 | LG LSC26905TT Side by Side Refrigerator
Roper Refrigerator - manufactured 12/99 - RT18DKXH W00
tata75,
Happy to assist you,
you said,
For the past three days, water has been leaking/freezing at an alarming rate. The freezer had about 2 inches of ice built up and the bottom of the refrigerator is holding water, too. Both crisper s were FULL of water. I don't know if the ice maker connection is broken or what. Looks like I have to cut off the cold water completely to the sink to get it to stop.
Sounds like the ice maker or its line is leaking the water to me. And obviously it will freeze in the freezer.
You need hands on service.
Our site provides service companies in your area.
bless you,
Please give me a good rating before you sign off
Thank You
Sep 08, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Ice maker trobleshooting
We lost power due to hurricane Ike and now that the power is back on the ice maker is not working. Is there a reset button or what needs to be done to get it working again?
Aug 10, 2008 | Kenmore 22.0 cu. ft. Side-By-Side...
Maytag MZD2766GES Side by Side Refrigerator Logo
325 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
