Question about Nyko Charge Station 360 For Xbox 360
Can't connect xbox controller with NYKO batteries.
I got this charge station for my birthday, and after I got it all ripped out of the package and charged it, I plugged one of the batteries into my controller, and all that happened was the ring on the controller blinked as if it weren't synced. I tried syncing it, and it would star tsyncing but then just go back to blinking. please try to help me.
I had the same problem, asked Nyko's support department about it, and they told me that Microsoft updated their controllers at some point in the past, and this update rendered the version of battery pack I had useless. There is an updated version, but you will have to ship your old one back to Nyko and wait a few weeks. Hope this helps.
Posted on Jan 28, 2009
  • 146 Answers
After reading this -the reviews-
http://www.gamestop.com/Catalog/ProductDetails.aspx?product_id=61147
It seems the battery packs do not fit into the controller so I suggest using your original back piece and use the others for the charging --hope this helps--
Posted on Nov 25, 2008
My Xbox one controller won't connect even though the nyko charge base shows the controller are fully charged. Is this a controller problem or a charge base problem (both are new within the past 2 months)
Xbox One's have been having issues with their controllers for quite some time, usually in the bad batches that they send out to retail stores...My recommendation is to contact Microsoft support, and see about getting new ones shipped from them. The other option is to buy new controllers, but I'm sure you don't want to spend another $120 :) Best bet is to call their service line, though.
Feb 01, 2015 | Nyko Video Game Consoles & Games
Nyko charger won't charge
Had same problem with blinking lights and not charging.
Plug charger base in (blinking lights), remove controllers, and plug USB cable into front charge slot (behind hinged panel). This reset charger base and lights stopped blinking. As FYI - the USB was connected to other device (charging it). Add the controllers and correct charging lights show up - including the controller 1 and 2 symbols. Controllers now charging.
Feb 07, 2012 | Nyko Charge Station 360 For Xbox 360
HOW TO CONNECT NYKO XBOX REMOTE TO THE XBOX
There will either be a button on the controller....usually pretty small circularthat you will need to press along with the "sync" button on your xbox console. Sometimes aftermarket sync buttons are very small "pen tip" like.
There may be a usb stick needed as with some Logitech products.
Nov 20, 2011 | Nyko 81435 Airflo Wireless Controller For...
Hi. We have a NYKO Charge Station for the XBox 360.. What do the indicator lights.. Green? Red? Thanks.
Hello
The red light means its charging, then when its done charging it turns green briefly then the lights and charger turn off and the controller is ready.
Please rate.
Aug 17, 2011 | Nyko Charge Station 360 For Xbox 360
What does flashing red light on wii dock charging station mean??
Make sure that when charging the battery pack it must be attached to a wii-mote otherwise this may cause a flashing red light. If the battery pack is attached to the wii-mote and you still have a flashing red light this may indicate that there could a problem with the battery pack itself.
Mar 30, 2011 | Nyko Charge Station for Nintendo Wii
The lights on the charge station are both blinking quick flashes of green without a remote on it - when I put the remote on it, there is no change in the blinking lights. I have no idea what's wrong - can...
Try contacting Nyko company to see if they have any solution. www.nyko.com I have the same charge station and discontinued using it because it would not charge my controllers after only a few months of use.
Mar 02, 2011 | Nyko Charge Station for Nintendo Wii
What to i need to do when the wii charger is green
If your controller is still sat in the charger then that is fine when the green light is on. The chargers have what is called smart charge technology. This means that when the controllers reach full battery capacity the charger stops sending charge to the controller until it drops below a certain charge level again. Leaving the remotes in the charger when the green light is on will not damage them in any way at all.
Hope this helps
Dec 19, 2010 | Nyko Charge Station for Nintendo Wii
I cant get a connection with the xbox and the standard controller
The usb ports are soldered onto the mainboard and would require quite a bit of technical knowlege to replace. You are stuck with wireless controllers and batteries. There are charging stations for xbox 360 controllers on ebay. Most 360's have a USB port on the back above the network port. You could charge with that one. Good Luck
Nov 23, 2009 | Microsoft Xbox 360 Console
Non microsoft battery won't charge on a microsoft charger
Well... try to stick with 2 brands of batteries not seprate if i don't inform me my address is addisonswim@hotmail.com
Oct 03, 2009 | Nyko Charge Station 360 For Xbox 360
Alkalines won't work in my 360 controller.
there are units designed to run on rechargeable batteries and some that run on alkaline batteries
the difference is the current draw required
alkaline batteries have a high discharge rate available but for short duration while the others have a smaller discharge rate but over a longer period of time
you should only use the type of batteries recommended for the unit
Apr 12, 2017 | Nyko Charge Station 360 For Xbox 360
Nyko Charge Station 360 For Xbox 360 Logo
603 people viewed this question
Top Nyko Video Game Consoles & Games Experts
Douglie007
Bill Boyd
Kevin Liu
Kevin Liu
Level 1 Expert
Are you a Nyko Video Game Console and Game Expert? Answer questions, earn points and help others
