Question about Whirlpool Duet GHW9150P Front Load Washer
Control locked light is on
Controls are locked up , need help with resetting the controls
  • vickybecerra Nov 17, 2008
    I am getting a DL failure code along with a f 11 code and the machine will not work unless we reset it and hit it to make the lock relock? what should I do we are lost
    President:
  • Whirlpool Master
  • 2,651 Answers
If the control lock is on there is a button to the far right last button on the bottom marked control lock. hold for 3 secs to unlock. F11 and F DL are independent issues all together, for this i would remove the top panel and check the wires ont he control board located across the back wall( focusing on the far right harnesses ( these are the door lock(DL) wires, as well as the wires connected to the door lock which can also be access reaching down the front panel while top is off
Posted on Nov 17, 2008
  • simpsoncurly Feb 17, 2011
    It worked! Now I can do wash!
    Thank you very much!
I have a Maytag MSD2351 side by side and just replace the water filter. When I attempted to reset the filter light, the control locked and I can not get it to unlock. I pressed the lock and water button...
If the Control Lock feature has been enabled, the Control Lock light will flash 3 times indicating that it is activated. To turn off Control Lock, press and hold the Options key that says "Control Lock Hold 3 Sec" under it for 3 seconds. If the dishwasher has a dedicated Control Lock button in the Options selections, press and hold CONTROL LOCK for 3 seconds.
NOTE: You may need to disable Sleep Mode by pressing either Start/Resume or Cancel, or by opening and closing the door before you are able to turn Control Lock off.
NOTE: If your model requires you to press and hold PROSCRUB UPPER, 4 HOUR DELAY or BOTTLE WASH to lock the controls, the Control Lock light will be on when Control Lock is active.
Nov 03, 2017 | Maytag Refrigerators
Describe your Whirlpool Duet GHW9150P Front Load Washer Problem the control lock button is on
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washer however; your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Aug 15, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Control lock light is on and nothing else will respond, and this continues even after unplugging/replugging. help!
This is a common issue with Whirlpool Duet washer however; your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE /CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Jul 31, 2011 | Maytag EPIC MFW9700S Front Load Washer
Maytag dryer epicz says "controls
controls locked
This feature allows you to lock your settings to prevent
unintended use of the dryer. You can also use the Control Locked
feature to prevent unintended cycle or option changes during
dryer operation.
To enable the Control Locked feature:
Press and hold AUTO DRY LEVEL for 3 seconds. Control Locked
glows and a single beep tone is heard. To unlock, press and hold
AUTO DRY LEVEL for 3 seconds. The indicator light turns off.
Jul 15, 2011 | Kenmore Elite HE4 Electric Dryer
Lost original car alarm control... need to reset a new one...
programing a Nissan remote , is hidden secret by Nissan Dealers. As a Nissan Technician i will share it.
Just get in your vech , close all doors. Using your power lock switch , lock all doors. After doors are locked take your Ignition Key and insert it and remove it from ignition switch in a slow fashion , but consitant pace. (97 and earlyer are fast) When you see the hazzard lights flash, put key in ignition switch and turn to the On postion .. Do NOT CRANK or you will have to Start over .. After in the On postion .. Hit the Lock button on remote... Hazzard lights should flash..( note..you have to reprogram all remotes when adding a new one , if you don't your old remotes will not work ) If your doing just the one , turn igntion switch off and unlock door and get out and try it. If you are doing more than one. While still in Vech with Key on . After you hit the Lock button on Remote and hazzard light flashed .. with key still on .. use master lock switch unlock doors and relock and then hit Second Remote, Lights should flash again , repeat if adding a 3rd remote.. after done just turn key off and unlock door and get out and try.
Oct 29, 2009 | 2002 Volvo S40
Control panel
select and hold END OF CYCLE SIGNAL for 3 seconds untill the CONTROL LOCKED status
light turns off. The button you need to hold down is under the louder, softer, and off volume
control buttons.
May 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control lock light
control lock light ? have you got any blockages or dirty filters you may have to clean them.
Jul 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control Locked
look closely at the machine console, the most right set of buttons, the lowest possible one is the control lock button, youll need to hold it in for 3-5 seconds to unlock the control panel(child lock)
May 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control lock light
someone has enable the child lock feature. One of the buttons should say hold 3 secs for control lock under its normal function description. Hope this helps
Jan 01, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
134 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
