How do you get the mp3 player out of recovery mode
  • 1 more comment
  • Anonymous Nov 17, 2008
    MY SANSA FUZE WON'T POWER ON
  • perezcheli08 Jan 25, 2009
    i had bought the mp3 anot too long ago and the scrfeeen is black and the computer cant read my mp3.:(
  • mjmix May 08, 2009
    load main image failed switsh to recovery mode
    New Friend:
    Problem Solver:
  • 13 Answers
Try using a file recovery software to find deleted mp3 files of your mp3 player . Just connect the player with your pc and using the tool and the procedure you can able to get back your mp3 files easily..
Posted on Mar 19, 2013
ctf1800
  • 4402 Answers
SOURCE: Getting out of recovery mode
Detach your player from the PC if it is connected, and turn off the player.
If the player stops responding, you can reset the player. To reset the player, gently
insert a thin object into the Reset hole located below the power switch.
2. Press and hold the Play button while powering on your player.
3. When the player displays the Creative logo, release the Play button.
do a Clean Up
this Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Reboot the device.
it it continues to boot into revcovery mode see below:
Booting straight to the Recovery menu
I decided to open it up to check out the hard drive to see what kind I would need so I could try replacing it. The data plug that attaches to the hard drive itself was partially unplugged. So, I pushed it back in all the way, put it all back together again, and turned it on just to see if something different might happen. (I had it set in my mind that the hard drive failed and I would need a new one, so I didn't expect anything different to happen) And to my surprise, it worked just like new again.
Before you go off and invest in a new hard drive, I suggest opening it up and make sure that plug is in all the way. Since you'll be opening it up in any case, it wouldn't hurt
Posted on Feb 11, 2008
  • 9 Answers
I have the sleek photo and mine bugged out yesterday. It would go to the splash screen and then go blank and just sit there. Nothing would respond. I tried reset, reboot and other things too. My pc also would not recognize the player. To make a long story short, I tried other suggestions I found on the web. They didn't work and my player would now only go to a garbled splash screen and go right to the recovery screen.
I had the new firmware, but I couldn't use it because the pc wouldn't detect the goofy player. Then I ran across a site that mentioned that Windows Media Player can cause player recognition problems. I removed both WMP (mine was 11) and WMP runtime using the add/remove programs option on the control panel. I restarted the pc and BAM! the player was now recognized. I ran the new firmware application and the player works fine now. The key for me was getting rid of WMP and the WMP runtime.
Posted on Aug 19, 2008
TheGadgetDr
  • 65 Answers
SOURCE: Creative Zen Touch stuck in "recovery mode"
Have you tried to load the firmware? First you'll need to download the firmware to your PC from Creative's website: Click here. After you've downloaded it, connect your Zen via USB to your PC and open the firmware icon, then click "Upgrade."
For more detailed instructions on how to troubleshoot your Zen, click here
Posted on Aug 20, 2008
  • 9 Answers
The recovery tool mentioned above is not designed for the sleek photo. You need to download the firmware for the sleek photo from creative's site. Now we need to get your player recognized to get the firmware loaded. If you have Windows Media Player 11, it needs to be removed. Also remove WMP runtime. After that, restart the pc and your player should be recognized. You can then double click on the firmware program to run it. It might say something like, this firmaware is already installed...do you want to reload it? Click yes to reload.
I had the same problem with my sleek photo. Once I got rid of WMP and the runtime everything worked like a charm.
Posted on Oct 06, 2008
SOURCE: creative zen micro stuck in recovery mode
To Fix any problems with broken firmware form attempted “playsforsure”
firmware updates etc where your pc finds it as a 20mb drive and it sits
in recovery mode and does bugger all:
1. Uninstall all creative software & drivers
2. Uninstall Media Player 11 and Media Player 11 runtime (will require a
reboot for each thing). This is done by going to add/remove programs and
uninstalling (this will put your pc back to wmp10).
3. Re-install the Zen Driver from the creative website and reboot (I just reloaded Media Explorer using my ZMP install CD).
4, Plug Zen in.
5, Make sure you have the firmware update ready, run it but don’t click
the language bit yet), leave the mouse hovering over your language
selection. (for ZMP, just start firmware exe file, there is no language selection. You can get the firmware update from Creative’s site, go to SUPPORT and then DOWNLOADS).
6. On the Zen- select “reload OS” (on ZMP I believe it is Erase or Reload Firmware, something like that, don’t have it in front of me).
7. As soon as it flashes up “reload new firmware now via USB” click the
language button
8. Now the pc should find it and allow you to re-load the
firmware. (it may take a few attempts)
9. Once complete, click close and restart the pc. Everything should now
be fine.
10. Once all is working, you can re-install WMP11 and it will work fine.
Posted on Jan 14, 2009
Creative zen v plus. when i turn on it says its in recovery mode thats all it will do i reformated it but it does not allow me to put music or anything else on it
Connect you player to your computer and use the recovery tool provided by creative labs.
Recovery tool: download here
You'll have to reflash te firmware with this tool.
When the firmware is lost on a zen or any other creative labs mp3 player, the mp3 player boots into recovery mode.
Note when doing this, all data on the mp3 player can get lost.
Aug 27, 2009 | Creative Labs ZEN V Plus MP3 Player
Recovery mode
hi buddy... there is nothing serious about this...it shows that message in recovery mode.. otherwise format the player and tr to load the songs again :)
Sep 08, 2008 | SanDisk Sansa e200 MP3 Player
Load main image failed Switch to Recovery mode
Use the Sansa Recovery Tool on the Sandisk website
Jun 01, 2008 | SanDisk Sansa e250 MP3 Player
Recovery mode for Zen V plus
The step-by-step process for doing the recovery mode is at Creative's website:
http://193.95.171.83/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=107,E=0000000000366987556,K=3577,Sxi=5,Kb=ww_english_add,VARSET=ws:http://us.creative.com/,Case=obj(26219)
May 12, 2008 | Creative Labs ZEN V Plus MP3 Player
Recovery mode
plug the player into a computer that has zen software and it should then come back out of recovery mode , try to stop player playing when you are finished with it so it doesnt keep going to recovery mode
Mar 10, 2008 | Creative Labs Zen Micro MP3 Player
Switch to recovery mode...
go here
good luck
please mark the post with a fixya!
Feb 12, 2008 | SanDisk Sansa E280 MP3 Player
Rockbox Firmware not installing after recovery mode on player
The firmware instal intructions quite clearly tell you NOT to attempt to instal Rockbox in recovery mode. You must have it in MSC mode.
Aug 02, 2007 | SanDisk Sansa e260 MP3 Player
Refesh
try going to recovery mode and upgarade the firmware of the player. Recovery mode = enable hold switch press the record button and press the menu button until it shows welcome to recovery mode on the player.
Jul 25, 2007 | SanDisk Sansa e250 MP3 Player
50 people viewed this question
 Grubhead
Grubhead
