Question about RCA F32650 32" TV
Remote, menu button, volume up buttons dont work anymore
The remote sensor wont work, the volume up doesnt work but the volume down does, and the menu button doesnt work either
  • case2001 Dec 15, 2008
    I got the tv from a friend who called RCA and told her the remote sensor in the TV was bad. I ordered and replaced the sensor on the board and the TV still does not respond to the remote. Any suggestions?? (It is a large TV and not easily transported.)
  • 26 Answers
You need to open the remote unit and clean the touch pad contacts and the circuit board contact points with pure isopropyl alcohol.
Grease may have worked itself into the remote an has caused those button contacts not to produce the data signals.
Posted on Nov 17, 2008
Accidently pressed the FDA button on my RCA TV and now its locked and wont turn on and i dont have a remote to it
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Jun 19, 2012 | RCA Televison & Video
Where is the reset button ?
on most tvs you have to reset through the menu with the remote! If you dont have a remote you can press the volume up and down buttons at the same time or the volume up and down buttons at the same time and the menu should pop up.. Hope this helps.
Dec 23, 2010 | Televison & Video
My canon powershot SD280 sound wont work.. The sound turn on Okay, but the Video doesnt = It DID work and i dont know what happen to it !
hey boss- just figured this one out.
while the video is playing, you can increase the volume by pressing the button above the Func. Set center button and decrease the volume by pressing the button below the Func. Set button. Think we both accidentally turned the volume all the way down.
Too bad you can't tell this by going to the volume menu! Would have been nice to know I was still recording audio while shooting video. Hope this helps!
Jan 24, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
Menu keeps flashing remote control wont work, cant change channel or volume.when i hold down channel up andmess with remote sometimes it changes channel. channel down button is only one that doesnt change...
U have 2 situations:
1st U have a tv Key stucked or internal control board defective.
2nd U have a broken tv remote control.
Note: Check for stuck pressed keys on TV, if not send to repair shop, for checkup.
Nov 29, 2009 | Insignia IS-LCDTV32 32 in. Television
I need to re tune my samsung tv but have no remote any ideas?
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Cheers Little Dish Fitter
Sep 21, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
TV Volume goes up by itself and remote wont work
There are 2 reasons that this is happening in respect to the problem commencing after your daughter has cleaned the tv. Either your daughter has sprayed the volume button with cleaner and fluid has got into the the graphite pad under the button and conducting as though the button is being pressed continuously..or she has put too much pressure on the button if it is a metallic plate contact switch.One way to find out is by pressing the down volume button.does it it click ? if it does.try the up volume..If that doesnt click the problem is the metallic plate is dented in making contact hence a new switch. Another cause ive seen is cleaning the remote control with cleaner and fluid has got into the remote and it sends signals to the tv all the time..If the remote control is hidden under a cushion and the problem stops, then the remote control is at fault and needs drying out..Hope this helps :)
Aug 04, 2009 | Apex Digital PF2025 20" TV
My buttons on my 2005 honda accord 4 cylinder car wont work
I assume this is the only remote you have? If not does the other have the same result? Have you changed the battery in the remote? If yes, is it installed with the right polarization?
Feb 28, 2009 | Vehicle Parts & Accessories
Nu tec crt 54cm tv
the problem is the volume/sound
Oct 28, 2008 | Televison & Video
RCA F32650 32" TV Logo
199 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
