Question about Gaggia Titanium Espresso Machine
Gaggia Titanium stuck on RINSING CYCLE
The machine is stuck on the Rinsing Cycle which I cannot find a way of stopping / breaking. Often pressing buttons / button combinations at switch-on will cause various test modes to be started. Pressing buttons 24 & 26 at switch on will cause a button / component test mode to be started, but none of this helps. I suspect that a sensor or similar is stuck / broken. I am still left with a Rinsing Cycle which is continous and will empty a full water tank if left on.
Also the central coffee dispenser unit (fig22) cannot be removed, strongly suggesting something is stuck and preventing its removal.
Can anyone help with this ?
David, Bolton, UK
  • Gaggia Expert
  • 109 Answers
Let it rinse it may run for some time.
you will not be able to remove the brew unit as it is engaged to be rinsed.
Posted on Feb 22, 2010
  • redwan Feb 09, 2012
    have tried the above with no joy, also left the water running for more than 60 minutes, didnt help, tried switching on and off.. none is working.
    any help please
Titanium stuck in rinse cycle and brew unti can't be removed. Customer service is not answering the phone.
Try going into the menu and selecting rinsing. Push the enter button and use the up down arrows to chose "off". Push the enter button again to make this your selection, then the escape button. That should take it out of rinse mode.
Oct 29, 2010 | Gaggia Titanium Espresso Machine
Rinsing cicle is not stoping.Mashine not responding to any baton.How to stop Rinsing cicle and go to normal mode? Thanks Radan
If its is only the rinsing cycle at start up you can go into the menu and turn the rinsing cycle off.
If its the rinsing cycle for the descale, it has to run out of water to finish. Then reprime the machine and it will start to heat again.
Oct 28, 2010 | Gaggia Titanium Espresso Machine
Cannot solve "Ventilate" problem - weater circuit is broken
Turn the knob on after you press the hot water button, run the cycle until the message is gone takes a few seconds or about 2 ounces of hot water.
May 02, 2010 | Gaggia Titanium Espresso Machine
Our Gaggia Tianium is stuck on rinse cycle, water pouring out
Just let it run the cycle,don't press any buttons.
When it runs out of water refill it and let it continue.
I get this problem a lot,
Dec 26, 2009 | Gaggia Titanium Espresso Machine
Rinsing cycle won't START
After all, I turned machine off with power switch, waited 30 seconds and turned it back on. It displayed "RINSING CYCLE" message, but this time went through regular rinsing cycle, then rinsed thoroughly (I counted several cups of water) and RETURNED TO NORMAL.
Halleluiah! Now I can get my morning coffee again!
Aug 30, 2008 | Gaggia Titanium Espresso Machine
Titanium plus stuck on rinsing cyle
go in the menu remove rince cycle after it say ventilate put water in container start machine open valve it should ventilate if it doesnt remove water container take turkey blaster put water in it put the blaster in the hole were the water container goes force pressure with the blaster at the same time open valve you vented by now put cointainer back fill with water enjoy thanks for using fixya pierre
Feb 10, 2008 | Gaggia Titanium Espresso Machine
Gaggia titanium
John, The duration of the rinsing cycle is equal to the amount of water you have in the water tank. I don't believe they tell you this anywhere in the manual! I own a Titanium SS and it rinsed and rinsed and rinsed the first time I performed it! I figured out it will just keep going until the water tank sensor tells the machine it is out of water which is equal to saying to it: "Thanks for using all the water i wanted you to use to rinse, now you're finished." Hope this helps, Tony.
Dec 08, 2007 | Gaggia Titanium Espresso Machine
The rinsing cycle stays on and DOES not pump water
Try first to continue filling up the water resovoir (UP TO FOUR times) to see if the machine completes the rinse cycle on its own. If that doesn't work contact Gaggia Customer Service in the US at 888-389-4123. Sally there was VERY helpful and should be able to resolve your problem.
Jan 03, 2007 | Gaggia Titanium Espresso Machine
My machine was stuck on rinse cycle now on ventilate...
Dec 31, 2006 | Gaggia Titanium Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
2,193 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
