Question about SanDisk Sansa m230 MP3 Player
Not recognized by the computer
When I plug in my Mp3 player. It dose not show in my computer. Also It will not show up in the media player so I can transfer songs.
  • 5 more comments
  • Vic_Portugal Jan 04, 2008
    Hi, I have a mp3 player (Ekon). Don't know why my WinXp system stop recognize this device. When I plug it, it simple doesn't appear on screen (despite on the device you can read "starting") the truth is that I can't do nothing. I've tried the Windows update without success and as far as I remember when I bought this device it didn't come with any CD. So you you have a similar problem and find a solution I would appreciate you let me know. Thank you.
  • Anonymous Jan 09, 2008
    yea im having the same problem, my friend asked me to put music on her sansa mp3, and wen i plug it in it doesnt show up on my laptop. idk why it doesnt work
  • Anonymous Feb 10, 2008
    having same problem with sansa 230 and gpx mp3 player. Used to work before but now using itunes. wonder if that is creating a problem.
  • cherylgirl71 Feb 14, 2008
    my m230 is stuck in the initializing mode. It will not do antthing. PC will not recognize it. will not go thru any mode. Tried to format nit but since PC will not recognize it nothing can be done. I can't even turn it off, I have to take tha battery out to turn it off.
  • Anonymous Oct 16, 2008
    my mymusix mp3 player is stuck in initializing mode it won't be recognized by my computer and it won't go through any other modes
  • Rbecca Hernandez
    Rbecca Hernandez Nov 08, 2008
    i just received my sandisk sansa mp3 refurbished...it came with the usb cord so i plugged it in and tried to download music but my comp dont recognize it...it didnt come with a disk or anything...do i need some sort of software to download?
  • Anonymous Nov 12, 2008
    i have the same problem.
My mp3 says not enough DM space and it wont show up on the computer
Posted on Oct 17, 2008
Tht was me
who said its  a powered USB port.
Posted on Jan 24, 2008
    President:
  • 2,961 Answers
If you are connecting it to a non powered USB you may have problems connecting it(by non powered I mean a usb hub that is not AC/DC powered; only powered by your usb port), but if it has worked before, try swapping usb ports and see if it's recognised. Sometimes USB can have a power issue with certain hardware.
Posted on Nov 30, 2006
SOURCE:
USB Port Not Recognized
Here Two Reason for USB Port Not Recognized:
1. Check you USB cable properly connected to the you computer, If cable break or not connected properly, It will show your cable not recognized.
2. If again these problem shows. go to,
My Computer - right click - Properties - Hardware - Device Manager - and Unistall you USB drivers - then again scan new hardware.
Jan 29, 2010 | Emerson BAR900 MP3 Player
Computer wont recognize the mp3
Try plugging your device to the USB port in the back of the computer. On older computers, the front USB ports are USB1 while the ones in the back are USB2, and I've seen it happen when some devices would go completely unnoticed if they were plugged into USB1.
If that doesn't help, try plugging it into a different computer. If that computer also doesn't recognize it, the problem may lie in the device.
Aug 06, 2009 | SanDisk Sansa e250 MP3 Player
When mp3 is plugged in, computer won't recognize it-so won't sync
try resetting it to factory settings.if that doesnt work you have to generate a system file. you can do this by recording your own voice in the player and saving it. this generates the system file and the computer will be able to recognize the player.thanks for using fixya!. please dont forget to rate my solution!
May 30, 2009 | GPX MW-3847 MP3 Player
Won't recognize my mp3
I recently purchased the Sandisk e260 Mp3 player but my PC is not recognizing the mp3 player & i can't transfer my music to the mp3 player. I tried connecting to 3 different PCs & they all don't seem to recognize the mp3 player. any ideas what else i can try?
Nov 11, 2008 | SanDisk Sansa e260 MP3 Player
Sansa scan disk mp3 player
put the songs in the removable drive.... it will work...'
for all mp3 player.. there will be any data storage device...its real..
thank u
Aug 11, 2008 | Electronics - Others
Comp not recognizing mp3 device
to gabby, some computer may not even recognize mp3 player from a removable disk, i would suggest that your mp3 player will serve as a back up...
tranfer all your music to a folder to a fixed drive like drive c: then change the format w/c suits for your pc's media player compatibility like mp3 formats then, after your done transfer again all your songs to your back up mp3, or better yet scan all your music w/ an anti virus like kaspersky, hope this would help
Aug 01, 2008 | SanDisk Sansa m230 MP3 Player
Computer doesn't recognize MP3 player -
I think I have a solution. First you turn on the MP3 Player and then go to the menu. Go down to settings. Then, go to USB. Go down to "MSC" and hit the middle button. It should take you back to the settings menu. That means you successfully changed that setting. Now plug the MP3 Player back into the computer and open up "My Computer." It should show up. I hope this helps!
Jul 24, 2008 | SanDisk Sansa m240 MP3 Player
Sansa e250
I am running a Sansa and an Ipod simultaneosuly with no conflict, so the problem is definitely with the Sansa.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Jun 11, 2008 | SanDisk Sansa e250 MP3 Player
Mp3 cendyne 128mb wont be recognized
What services is it not showing up on? Windows Media Player? Try downloading Media Monkey (they have a free version) - it will recognize the player, and you can use Media Monkey to view, transfer songs.
if you have a Windows-based computer, you may have to reformat the iPod by going to My Computer, right-clicking on iPod logo, and then selecting "Format" player (only do this as a last resort - iPod's are generally so good that you just plug n play). The apple website has good info if you need Vista-related support for this.
May 17, 2008 | Apple iPod nano
SanDisk Sansa m230 MP3 Player Logo
431 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
