Question about Motorola Talkabout T5420 (14 Channels) 2-Way Radio
Can't make the T5420 operate without the beeps!
I was told there is a way to make this radio operate silent last year. They worked fine last year, but then I replaced the batteries, and now they beep again. I cannot make them do it again. Does anyone know how to make them operate silent?
  • Motorola Master
  • 1,654 Answers
I have not looked up the T5420 user guide, however, on most Motorola TalkAbouts you hold in the minus (-) button while turning the radio on. Post back if this doesn't work, and we'll find the manual for you.
Posted on Nov 17, 2008
Motorola T5420 won't transmit to each other.
Since you say the frequency is set the same, you possibly have the code set differently. Check your interference eliminator code. It must be set the same on all radios. For basic operation turn the code off (zero).
Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5300_T5400_User_Manual_E.pdf
Best regards.
May 16, 2010 | Motorola Talkabout T5420 (14 Channels)...
How do I change the beeper noise (call beep) to vibrate for quiteness
Here is a link to the user guide : http://www.giantintl.com/ContentManage/manuals/Moto/T5320_T5410_T5420_User_Manual_E.pdf Refer to pages 18-19 for instructions on Call Tones and Roger Beeps. It does not mention vibrate as being an option, but you might walk through the 5 call tones and see if one of them is vibrate.
Dec 28, 2009 | Motorola Talkabout T5420 (14 Channels)...
Lost tranmission capabilities on one of the units, is there a way to reset. Last night it worked fine, turned of at night, tried to use this morning - no output!!! Any suggestions? Model T5420
The only way to really reset this is to remove the power/battery for 8 hours, press power button for 3 seconds, then wait 1/2 hour. Then try it again.
If you need a manual for this radio, you can view it here:
http://www.motorola.com/mdirect/manuals/T5320_T5410_T5420_User_Manual_E.pdf
Nov 15, 2009 | Motorola Talkabout T5420 (14 Channels)...
I have a Motorola Talkabout T5419 not receiving
motorola has extra security and will not operate with other radio makes very well. It must be locking out the uniden radios.
Oct 27, 2009 | Motorola Talkabout T5420 (14 Channels)...
T5420 unable to transmit or receive. Please help!
Here is a link to the user manual: http://www.giantintl.com/ContentManage/manuals/Moto/T5320_T5410_T5420_User_Manual_E.pdf
This unit does not have a reset button. While troubleshooting you might check the batteries. Be certain they are in correctly and the contacts are free of corrosion. You can use a pencil eraser to clean the contacts.
Walk through all the programming instructions in the manual, double checking both the frequency and interference eliminator codes. A quick setting back to zero on the code would alleviate any problem with that section of the radio.
As far as your "paging" this operates on the same frequency and code as the rest of the radio. If the radios are not working correctly in this relm, the paging will not work either.
Apr 24, 2009 | Motorola TalkAbout T5000 2-Way Radio
Here is a link to the T5000-T5500 user manual. 'http://www.motorola.com/mdirect/manuals/T50-T55_UserGuide.pdf'
From what you have stated, I can discern the radios will power up. You might try setting your interference eliminators to zero (off) to see if you are able to transmit at all.
You do not mention if you are using AA batteries or rechargeables. Either way a fresh set of charged batteries would be best for a test. It is clear you were getting power. However, it does take more energy to transmit than to receive. If your batteries are low or bad, pressing the PTT could us all the energy the radio has, and yet not transmit to the other units.
You might also check you VOX settings if any and be certain they are turned off.
It is not likely 4 radios would fail all at the same time. So it is probably a programming problem. Hope the user manual helps you find the solution.
Aug 23, 2008 | Motorola Talkabout T5420 (14 Channels)...
Motorola Talkabout T5420 (14 Channels) 2-Way Radio Logo
209 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
