For this job, all your work is going to be behind the machine. Tools you'll need is: 1/4 nut driver or drill with 1/4 adapter and a multimeter with ability to check continuity. With the machine unplugged, remove the back cover of the dryer. Once done, the heating element will be located on the right hand side with two fuses on the housing of the element. Test the element and each fuse seperatly by removing the wires and checking for continuity on each component. All parts should show continuity, so if one doesn't its bad and needs to be replaced
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
l;
properly.
if
no heat
tip....
heat.
check
out this electric
no heat
tip...
heatman101
