Question about Philips 27PT8419 27" TV
The picture is stretched horizontally loosing about 30% of the image area.
I assume my 29PT8419 is just a larger variant of the 27PT8419. Problem: The picture is stretched horizontally loosing about 30% of the image area.When text scrolls on screen bottom to top it looks concave, sucked in towards the center. Trimmers at the back only allowed vertical size and position adjustment. I did not find any but the above two. Also, when forced to 16:9 mode, the image is slightly rotated clockwise. Please advise.
4 Suggested Answers
SOURCE: Overscan is off a bit
Does's the set have a repair history? If it was previously serviced , the capacitor which is connected between the emitter and the collector of the horizontal output transistor transistor might have been changed with the wrong value, which would cause and overscan situation.The service menu for this set is even hard for technicians to use. It' my opinion if the service manual will not correct the horizontal width, the wrong capacitor was probably installed. Scrivitron (also these sets are known for the forementioned capacitor to short , flame or open.
Posted on Jul 09, 2007
SOURCE: Philips model 27MS5402/17, chassis A02U AA - horizontal adjustments
may be the mamery is defective
Posted on Oct 11, 2007
  • 281 Answers
SOURCE: Picture slants right to left
Hope you have fixed this problem by now, if that tv is unserviced, I mean if nobody has ever opened it, it could be a problem with the positioning of your tv, just tilt the tv in different positions and find out the position in which it will show the right fit. If it is serviced, especially yoke is changed, this is rare, it could be because the position of yoke is not aligned properly.
Posted on Feb 09, 2008
  • 518 Answers
SOURCE: White horzontal lines on the top of screen
Typical symptom of a faulty screen voltage capacitor. You'd need a schematic to locate the cap and then change it out.
Posted on Mar 10, 2008
0 characters
1 Points
Trapezoid picture
Keep in mind I do not know how much skill or knowledge you have about TV sets:
One of a few areas---This is a crt or picture tube model----The deflection yoke on the picture tube is number one suspect---if it is bonded to the crt you are done----not replaceable without buying the tube/yoke combination.
Only other area is the Pincussion circuit which should consist mainly of some caps for width and horizontal geometry.
A faint other cause can be indicated if you see a wave MOVING up or down in whatever picture you have= indicates the INPUT filter cap in the main power supply has opened or come loose from the board.
The wave is a 60 cycle indication of AC getting past the power supply and will cause a wave and could be mistook for a trapezoid issue.
Easy to spot the cap as it is larger than any other in the set.
if follow up question or more information press the make a comment button on this page.
Mar 25, 2012 | Sanyo DS32224 TV
How do I change it from wide screen to regular? I have a black area above and below the picture.
You can set the picture size by remote control itself.
You can vide 480i format programmes in three picture sizes. 4:3, 16:9, and ZOOM
You can change the picture size by pressing the PICTURE SIZE button on the remote control.
4:3 Picutre size
To fill the screen, the top and bottom edges are extedted more widely, although the center of the picture remains near the former ratio.
If receiving a 4:3 programme, the image size is displayed in its originally formatted proportion.
16:9 picure size
This image displays the size of standard 16:9 with black bars at the top and bottom.
If receiving a 4:3 programme, the image is displayed with black bars at the top and bottom and stretched wider.
NOTE: If a fixed bar remains on the screen for a long period of time, the image can become parmanantly engrained in the screen and cause subtle but permanent ghost images. Never leave your TV for long periods of time while it is displaying these images.
Zoom picture size [for 16:9 formats]
The entire picture is uniformly enlarged --it is stretched the same amount both wider and taller (retains its original proportion). The right and left edges of the picture may be hidden.
Dec 14, 2010 | Insignia NS- 27" TV27 TV
Picture is larger than display area
Check the aspect ratio settings you may have it set to 14:9 movie expand
Jan 30, 2010 | Samsung HL-P6163W 61" TV
Horizontal image is stretched beyond the screen borders
the problem is inside your TV , check the capacitor in vertical section of the TV.
Jul 31, 2009 | Apex Digital PF3220 32" TV
Image too large for the screen
you need to replace filter capacitor from vertical section area and horizontal section area. i already encounter tha kind of problem and fix replacing vertical section capacitor.
Apr 19, 2009 | Sony KV-13M42 13" TV
My sony tv problem is that the picture is stretch horizontally..
If you have a DVR too, there is a pound (#) button on the beside the zero on the DVR remote that stretches my screen off and on. Try that.
Jan 14, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
SONY KV-DZ29M61 horizontal deflection problem
You cannot use sub parts on sony use sony parts only. Same with hori output transistors. USE SONY PARTS ONLY.
Dec 01, 2008 | Sony FD Trinitron WEGA KV-30XBR910 30" TV
Picture stretched on CRT 32"
the problem is that your flyback and also your power supply circuit. check the B+ of your supply.
Apr 24, 2008 | Standard (CRT) Televisions
Picture larger than screen...
If you go to 4:3 mode and the picture is still cutoff then i would assume the tv has a problem with the horizontal or the pinchusion correction circuit . This would be the only two areas that would cause this problem . Check the format section of your menu to make sure it is not in zoom mode or otherwise if it is not then you have a problem with one of two above mentioned circuit problems . Good luck
Feb 01, 2008 | Sanyo DS31520 31" TV
Philips 29PT8419-79R
the problem in power supply. if its output is ok than you will have to check horizontal section.
Sep 15, 2007 | Philips 27PT8420 27" TV
Philips 27PT8419 27" TV Logo
Top Philips Standard (CRT) Televisions Experts
Sp Gupta
Jim Evans
Are you a Philips Standard (CRT) Television Expert? Answer questions, earn points and help others
