Question about Kenmore 63942 Dryer
Dryer wont stay on
My dryer will run when I press the Press to Start, but when I let go, it turns off. Do I need a new Timer or Electronic Control Assembly?
  • Anonymous Nov 17, 2008
    I have the same problem.
  • 1,028 Answers
Before replacing control bd look for relay with blue wires switch it out with relay with red wires if unit starts after switch replace relay the relays are identical the one with red wires is for heat..if relays ok probably bad electronic bd
Posted on Nov 17, 2008
I have a Kenmore gas dryer model 97591220. wont
Disconnect power to the dryer and remove the screws attaching the console rear panel to the console and pull the panel off.
Inspect the wires connected to the timer and ensure a snug fit connection. Clean the connectors and terminals then reseat it several times to ward off dirt within the connectors.
Reconnect power to the dryer and start it; replace the timer (part number 3398195 ) if the dryer still won't stay running. Unplug the dryer and pull the timer knob off the console. Remove the screws securing the timer to the bracket and remove it. Secure the new timer in place then disconnect the wires from the old timer one at a time and connect it to the corresponding terminal on the new timer.
Push the timer back into position on the console and secure the console rear panel in place.
Apr 14, 2010 | Dryers
I put a new heater in dryer. but still no heat
I can suggest that you trace the wires from the heating element back to the control timer, There may be a heavy duty relay that turns the heating element on and the contacts could be burned not making contact or the relay coil could be bad this would cause the heating coils not to heat. Also some dryers had these contacts built into the control, If when you press the button to start the dryer and you hear the relay click on it should stay on until you open the door or shut the dryer off, If it is staying on then you may have a bad relay. Also check your fuses as the element runs on 220 and the motors run on 110. If the fuse that is bad is other than the side running your motor you will get no heat.
Oct 07, 2009 | Dryers
Control panel looks ok but dryer wont start
Sounds like an electronic problem on the timer circuit board.
Aug 11, 2009 | Siemens WT79020EU Electric Dryer
Kenmore elite smart sensor model 110.6506 wont run
Many different possibilities. Could be thermal fuse, timer / control, motor. Start switch, or door switch. Most likely need to call service unless you have means to troubleshoot and test parts.
Nov 03, 2017 | Kenmore Elite HE4 Electric Dryer
I think my dryer finally stoped
Inspect the start switch and the door pressure switch as well. if both switches check out OK, replace the timer/control device.
Jun 03, 2009 | Kenmore 700 6972 Dryer
Check all fuses and circuit breakers , if they are fine, then the problem is with the control timer. You need to have the control timer replaced.
See also the following website: What is wrong with your Dryer?
You can get replacements here.
Sep 10, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Press start button but wont stay on
the switch is fine
the switch in all dryers triggers a relay, that then latches and supplies current to motor and heater, until deactivated by door switch or timer switch
inside the control panel,
trace the wires from the start switch to the first device
c27eaf9.jpgmay be opaque.
ensure that the wires are all connected.
if all are connected replace relay
the local part store will have the relay it is common to most dryers
Cant give exact instructions, no experience with particular model
Aug 06, 2008 | Tricity Bendix TM310W Electric Dryer
Kenmore 63942 Dryer Logo
78 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
