Question about Mustang 120 Diagonal 16:9 Electric Projection Screen - White Case Projector Screen
Mustang electric screen down limit adjustment
Which direction relates to up or down motion?
Where to start to figure out why electric fan motor isn't working 1995 mustang
I like that where to start its an honest question .
Let me ask you this are you sure your fan is electric and not a fan clutch spinning off the water pump .You didn't say what engine
Most of the time their will be 2 electric fans .
If you give more details it would help to understand the problem better .thanks
May 29, 2015 | 1995 Ford Mustang
Sears door opener #139.53603 opens 12" then reverses
there are two adjustments one for up limit and one for down there is also a pressure limit, someone may have adjusted on it before you bought it.
Dec 21, 2012 | Home Security
How do you adjust headlights on a 1993 chevy C1500
if you look at the light, there is an adjustment screw at the top of the light that controls the up and down motion , clockwise will raise the beam, and a screw on the side that controls the side to side motion. the best way to center your lights would be to park the vehicle 25 feet away from a verticle wall. be sure to be very square to the wall and on level ground. make a tape line vertically on the wall in very close relation to the center of the vehicle, and another tape line vertically in very close relation to the center of each headlight. now place a tape line horizontally in very close relation to the center of the headlights. start with low beam adjustment. adjust the high intensity zone to 2 inches below the horizontal line and 2 inches to the inside of the vertical line directly in front of the headlight. for high beam adjustment, adjust so that the high intensity zone is centered on the center vertical line and just below the horizontal line. hope this helps
Apr 04, 2010 | 1993 Chevrolet C1500
How do you change the drop down limit?
This job is usually very easy. There will be 2 screws in the end of the motor that operates the screen. They may look like ordinary slotted head screws, Philips screws or even Allen keys sockets. They adjust the limit switches inside the motor that control where it stops at each end of the travel. They are usually fairly fine, so you need to turn them quite a bit to get a change in screen level. For example, a full turn may be 100 mm or 4 inches in your measurements. The easiest way to work out what is happening is to run the screen up and down and note where it stops. Then adjust one screw a full turn and run the screen up and down again and note whether the top or bottom has changed and in which direction it has changed. You can now do the fine adjust on each end. You will need to run the screen up and down several times to sort out where it stops as there is a bit of trail and error in getting the settings right.
Nov 22, 2017 | GrandView Tab-Tensioned Electric Screen...
2001 mustang gt,all access. work fully charged
I would suspect the starter solenoid has failed.
A starter solenoid (or starter relay) is the part of an automobile which relays a large electric current to the starter motor, which in turn sets the engine in motion. In many vehicles the solenoid also engages the starter pinion with the ring gear of the engine.
The starter solenoid receives a large electric current from the car battery and a small electric current from the ignition switch. When the ignition switch is turned on, a small electric current is sent to the starter solenoid. This causes the starter solenoid to close a pair of heavy contacts, thus relaying a large electric current to the starter motor, which in turn sets the engine in motion. The starter motor is an electric motor that initiates piston motion in a car's internal combustion engine before it can power itself.
Nov 27, 2009 | 2001 Ford Mustang
Trying to adjust head lamp in a 1995 chevy C1500 just had to buy a new lamp assembly
Oct 20, 2009 | 1994 Chevrolet C1500
Garage door wont close all the way
The over-force limit is probably being activated. YOu may have a spot on the track that is putting load on the closer. Try MANUALLY moving the door to verify easy motion through complete range.
ALSO verify you don't have a cord that hangs down and triggers the electric eye safety devices. A pull cord can do this but usually the door is reversed when that happens.
You may also need to INCREASE the tension limit on the head if you find the tracks and counter balance springs have no problem.
Sep 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a grandview elegant electric projection screen and when I retract it, it stops about a foot below the case and won't retract entirely into the casing. Help please.
Electric screens are just about the same as a garage door opener. They have a up and down limit setting. Usually screens will have the motor on the left as you look at the sceen, this is where the limit switch ajustment screws are. If they are labeled great, if not hopefully they are obvious to see on the motor or roller. Hope this helps.
Aug 05, 2009 | GrandView Elegant Electric Plug-In Screen...
Craftman 1/2 hp chain drive , stuck in down motion
The thing to do is remove the cover and watch the limit switch assembly. You should be able to see how it is supposed to work and determine what is wrong. A small gear on the end of the shaft turns the limit switch assembly to make contact and turn off the motor in each direction. Something may be broken or out of place. There is also a possibility your logic board is bad especially if you have had electrical storms recently.
Jul 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
93 mustang car door doesn't
Sounds like the door may be out of adjustment. Check first that there nothing is getting in the way of the door closing area such as the seat belt, and that the door seals are in the correct position. If all checks ok there, Then the door striker witch located at the "B" pillar ( body area direct behind door ) needs adjustment. I recommend finding someone with experience doing this as it will require the use of a impact driver to loosen the adjuster But if you have access to this tool then MARKING where the adjuster is before adjustment is a good idea as a starting point of reference. The adjuster need only be slightly loosened to adjust and will move not only in and out but up and down. good luck and have a happy holiday season Kam
Dec 10, 2008 | 1993 Ford Mustang
Mustang 120 Diagonal 16:9 Electric Projection Screen - White Case Projector Screen Logo
138 people viewed this question
Top Mustang Televison & Video Experts
Are you a Mustang Televison and Video Expert? Answer questions, earn points and help others
