Question about Toshiba e-Studio163 Copier
Toner bag it stated on the panel that the toner bag need changed, i did that now it states to call maintance 57 what do i need to do . this is a toshiba 3560 i think that is what the toner says anyway.
  • 4 Answers
Usuaslly when you change bag you have to go into service mode and reset counters..
Posted on Jan 04, 2009
Photo state Toshiba e studio 225 toner not recognised
Make sure you are using genuine toner with chip on it...If still persist, check/clean the harness and toner chip contact on the machine.
Jul 15, 2015 | Toshiba Office Equipment & Supplies
How do I clear the 'dispose of used toner' error message?
Clean well the toner box or better replace with a new toner box.
Sep 24, 2014 | Toshiba Dp3580 Dp2570 Dp2460 3560 2060...
My toshiba 3560 is no print how to solution plz help me
HHmmmm. many possible causes of that sir. the Developer reach the copy limit. the corona wire is cut off. the high voltage maybe filled with toner need to clean that. or the exposure lamp is busted. Good luck in hunting Sir.
Apr 17, 2013 | Toshiba T-3560 T3560 Genuine Copier Toner...
Toner dumping straight into toner bag
use original toner OR reset toner indication
Sep 12, 2012 | Toshiba 2860 Copier
How to empty the waste toner
pls state copier model. different model had different location of their waste toner bag or bottle. some are located at the back of the machine, on the side. other are located below the transfer unit. just remove it (bottle/bag).
Feb 22, 2010 | Office Equipment & Supplies
Red power light continuously blinking. no picture no sound.
It could be the lamp went out and needs replacement. The Toshiba website states when this happens to unplug the televison for 10 minutes then plug back in. If that does not work then try another power outlet. If that does not work then call for service
Sep 12, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba 3510c , error code cd70
CD70 indicates Used toner bag mixing paddle locked.
U need to check following:
1. Do the paddles in the used toner bag rotate? If not, replace a new toner bag.
2. Is the used toner motor rotating? (Perform the output check: 03-414)
3. Is the used toner motor lock detection sensor operating normally? (Perform output check: 03- [FAX] ON/[2]/[G])
Aug 11, 2009 | Toshiba E-STUDIO 650 Copier
Where do dispose of full toner waste bags?
It depends on where you live.
Do a Google search for " what's the best way to dispose of full toner waste bags?" And add your city,or state on the same line. It will return a list of places to recycle the toner.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 26, 2009 | Ricoh Aficio CL3500N Laser Printer
I replaced the toner in the Toshiba 3560 copier and after replacing the toner the machine still says to add toner. Any suggestions?
You may have a clog going into the developer. If you can get the developer out you can then vacuum it out.
Jul 22, 2008 | Toshiba Office Equipment & Supplies
Toshiba e-Studio163 Copier Logo
173 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
