Question about Whirlpool AWG329 Front Load Washer/Dryer
Spanner symbol fault - No conditioner wash
I'm trying to resolve a problem with our Whirlpool AWG329 washer/dryer. You can start any wash programme ie. select a number. The machine fills with water, heats up no problem and starts washing. The machine then does not accept a conditioner wash when it moves onto (5), the drum is still full of water, i then have to discharge the water. The programme selector turns to the spanner symbol. The manual indicates a technical fault with the motor or temperature sensor, I suspect it may be some thing else. I have cleaned out the dispenser tray and drain pump with no signs or items obstucting the impler. For some reason the machine will not continue to a condition wash. Any feedback from the site forum would be appreciated
jsrock516
  • 5911 Answers
SOURCE: How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Posted on Apr 22, 2008
michiganfan9
  • 179 Answers
SOURCE: Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Posted on Dec 30, 2008
Maytag317
  • 1136 Answers
SOURCE: Spanner nut removel
Hi, The proper tool is P# TB123A.
You can also use a coal chissle and a hammer. Be careful that part of the spanner nut doesn't break off and hit you with the chissel. It takes a preety solid hit to losen the nut.
Hope this helps. If it does, please rate my comments and how I did in helping you. You can order the wrench as well as any other parts on my web site
http://www.whirlpoolpartssurplus.com/cart/
Posted on May 09, 2009
SOURCE: WHIRLPOOL WASHING MACHINE AWO/D 5716 - CANNOT LOCATE PUMP
Remove the bottom casing covering the front of the machine just above the floor. Unscrew the circular cap SLOWLY- beware of vast amounts of water escaping though!
I had to use a low height roasting pan to catch water, and just unscrew the cap enough so as to control the flow of water, and enable to empty water away until its all gone. Incidentally, an old hairgrip was found to be the cause of my problem.
Confusingly, "clean pump" meant clean filter!
Posted on May 20, 2009
SOURCE: It is an awoe 8558. the spanner symbol is flahing
Hi, I have exactly the same problem. Did you ever get a solution to get the door open manually?
Posted on Nov 01, 2010
How to use whirpool AWG 300 dryer/washing machine
I have got a whirlpool awg 300 but why every programs I am using it is getting 7 hours longer? this make me waiste a lot of elettricity..thanks
May 09, 2012 | Whirlpool AWG329 Front Load Washer/Dryer
How do i start the dryer on whirlpool awg 349/3 1200
Methinks you need a manual for now AND for the future!
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Apr 24, 2011 | Whirlpool AWG329 Front Load Washer/Dryer
I don't know how to start the dryer on whirlpool 1000 AWG338
Methinks you need a manual, not just for this but for future assistance ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Also you can try the manufacturer's web site direct.
Good luck,
John C.
Apr 06, 2011 | Whirlpool AWG329 Front Load Washer/Dryer
The washing machine does wash the clothes but does not dry. the make of the washing machine is whirlpool awg 338
Have you tried to clean out the filter on the bottom of the machine maybe it is not emptying fully so it will nit dry!
Oct 30, 2010 | Whirlpool AWG329 Front Load Washer/Dryer
Will not spin
its prob the brushes that need replaced or your motor has a fault and needs replaced the spanner symbol means it needs a service
Jan 06, 2008 | Whirlpool AWG329 Front Load Washer/Dryer
Replacement For Whirlpool AWG329 washer/dryer
Not sure if this will help, but Whirlpool has a pretty neat tool that can help you configure your laundry-room layout: LAUNDRY-ROOM LAYOUT
Nov 18, 2007 | Whirlpool AWG329 Front Load Washer/Dryer
Why wont my machine start drying?
I called Whirlpool on 08706008989. The machine can only dry half a load of washing at a time. At the end of the washing cycle, the Programme dial should be at either the sun or half sun symbol. Remove half the washing, set the drying time via the drying time dial and press the 1/2 Load Dryer button - Voila dry clothes!
Oct 28, 2007 | Whirlpool AWG320 Front Load Washer / Dryer
Washing machine not starting
It sounds like you could have a short in one of 3 places – the start button, the timer, or the hot/cold water solenoid.  The start button is the least likely so I’d first check out the solenoid.  Does this happen when it’s set on hot only, cold only, and/or warm water?  If so, probably you’ll have to get at the solenoid by opening up the top.  Disconnect the wires to the solenoid and try again.  If the circuit blows, it’s not the solenoid.  If it doesn’t blow, replace the solenoid.  If it’s not the solenoid, it’s probably a burned timer and you’ll have to replace that.
Oct 14, 2007 | Whirlpool AWG329 Front Load Washer/Dryer
Spins twice then clicks through all cycles
open to see behind the panel which holds the switch. look for any wires disconnected
May 10, 2007 | Whirlpool AWG329 Front Load Washer/Dryer
Whirlpool AWG329 Front Load Washer/Dryer Logo
70 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
