Question about SanDisk Sansa e250 MP3 Player
Want turn on sansa e250
My sansa e250 does not cut on at all but when i plug it into da computer and it goes in charging mode it starts to freeze but when i take the battery out and charge it it doesnt freeze.but my problem is it is not cutting on
  • 8,596 Answers
Make sure hold/lock is not engaged:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Dec 17, 2008
Sansa E 250 bad track
On your e250, go to the "Settings" menu, select "USB Mode", and set it to "MSC". Then connect your e250 to your computer. It show up under My Computer as a "removable disk". Right click on it and select "Format". Click on the "Start" button, making sure that Quick Format is NOT checked. Wait for the formatting to complete, unplug your e250, wait for it to reboot (or force it to reboot if necessary), plug it back in, and copy your songs back onto it.
Jan 27, 2010 | SanDisk Sansa e250 MP3 Player
My mp3 sansa won't turn on or charge.
If it freezes up, wont charge or just wont turn on... slide the power button up for 15-20 seconds then turn it on. That should work everytime. good luck
Aug 13, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e250 wont charge when plugged into the computer.
Sounds like the internal battery needs to be replaced.
Hope this helps. Good Luck!
Aug 07, 2009 | SanDisk Sansa e250 MP3 Player
I turn on my sansa e250 it goes to refresh database, then blanks
There are two connection settings in USB: MTP and MSC. For some reason MTP is the default, but it doesn't connect properly on all computers. Select MSC and plug the player in again, the computer will recognize sansa e250 but not show the driver just yet. It is installing recognition software (just basic drivers - nothing heavy) and it doesnt tell you what its doing until its complete. WAIT FOR IT. Once it is complete you will see both the sansa e250 and the removable memory slot in your "my computer" now you're good to go.
Mar 30, 2009 | SanDisk Sansa e250 MP3 Player
Sansa freezes up
Is the Sansa still accessible from the computer? If it is, then your gonna need the latest firmware update.
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
If not, then I suggest turning off the sansa altogether and plugging it into the computer. Then it should automatically turn on when plugged into the computer, and hopefully not shut off. Then do as stated in first few sentences.
CrossCut
Oct 28, 2008 | SanDisk Sansa e250 MP3 Player
Sansa seems to be frozen at startup
is my sansa broke or wat. when i plug the usb cord in the sansa comes on and wen i take it out it goes off , but the screen don't come on......i suffered the problem of wen the screen do come on it stops at the sansa rhapsody part then start over back to the big sansa screen then sansa rhapsody..........someone please help!!!!!!!!!!!!!!!!!!!!!!!
Sep 11, 2007 | SanDisk Sansa e250 MP3 Player
Sansa won't charge or load.
Plug it into the computer (the cord you would use to charge it and transfer files), and hold down the power button for at least 15 seconds. The Sansa should then begin to turn on and start charging. :)
Aug 07, 2007 | SanDisk Sansa e250 MP3 Player
Sanse e200 freezing up for no reason!!!
Hi. It seems like your player decided to throw a hissy fit by deciding to experience internal system errors. Best that you reset the firmware. Here's how: Switch your Sansa E250 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E250 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E250 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E250 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E250 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E250 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred. Step 3: When the process is complete, unplug your E250 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E250 and 90-99% of the time, it would boot up successfully. Step 5: Enjoy using your Sansa E250, just like I do. (I love this player)
May 14, 2007 | SanDisk Sansa e250 MP3 Player
Hello. Seems like your player is encountering either a file or system error, causing it to freeze. One solution would be to see if your player would be detected by your PC, then attempt to format it. Another solution would be to re-apply the firmware. Here are the steps: Switch your Sansa E250 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E250 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E250 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E250 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E250 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E250 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred. Step 3: When the process is complete, unplug your E250 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E250 and 90-99% of the time, it would boot up successfully.
Apr 20, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
