Question about Samsung MW1030WA Microwave Oven
GE Spacemaker XL1800 Microwave
Alright...The microwave workes fine. But when i operate the unit, the turntable doesn't turn and the microwave starts making this raspy sound. I have to manually turn the rotating button off so it stoppes making the noise. What can I do to fix it?
  • 3 more comments
  • namguy Nov 27, 2007
    Wife cleaned the Spacemaker XL1400, JVM144OWA 001. Both lights under the unit are defective and need replaced. After cleaning the unit the turntable does not turn, doesn't make noises or anything. Recycled turntable switch off and back on a few times with no results.
  • daldi Jan 06, 2008
    Turntablr doesn't turn and makes a horrible sound when the unit is turned on. How can I fix this?
  • diason Jan 26, 2008
    I have the same problem as Mr B Good. I have a GE XL1800 microwave model# JVM18605D 002. Does anyone have pictures on how to replace this motor? Sorry.. girls just aren't as gifted as guys when it comes to mechanics. Thank you for any help you can give.
  • lynn_ishere2 Apr 04, 2008
    my model number is : JVM1850wd 002 and I have the same problem the turntable won't turn and terrible noise coming but if I turn the turntable off no noise and it works fine
  • gwpfeifer Apr 26, 2009
    i have a XL1800 that the turntable stopped working. the model # is
    JVM1860SD 001. any help be great.
Your turntable motor is shot. It's simple to remove and replace. you don't even have to take the microwave out of the shelf. To remove it take out seven screw around the perimeter of the bottom. Lift up on back of bottom to get over clips on the back. Remove the two screws holding the motor in and detach the plug. Find a electrical repair shop for you make pick it up and replace it. When replacing it take out plate and hold plate key down and align flat side of shaft on motor with the plate key.
Posted on Nov 03, 2007
  • Samsung Master
  • 9,098 Answers
It sounds like you have a failing turntable motor or coupler. If you'll post your exact model number we can advise you more specifically and even direct you to an exploded view of the innards. (XL1800 is not an actual model number - we need the model number from the tag instead).
Posted on Nov 30, 2006
  • Sarkis Ohanian May 15, 2013
    57 2709-10/01 sorry I have a problem where there is a sound coming from my microwave eventhough its working fine. Could you help me?
I have the same problem. Does anyone have an online source to order the motor?
Posted on Dec 15, 2007
3 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: UPDATE: GE Spacemaker XL1800 Microwave
JVM1850BD002 is a correct model number. This is a GE made by Samsung. It sounds like the motor or coupler is bad. More likely the motor. If you grab the motor shaft and try to gently turn it, it may grind or slip a lot. That's a sign of a bad motor. If the coupler is bad, it will be cracked or broken, causing it to slip on the motor shaft or the turntable itself. The coupler is reference 40, and the motor is reference 43 on this handy exploded view drawing: http://genet.geappliances.com/IPCNet/Dispatcher?REQUEST=IPCNETGETPDF&file=00000000/00016500/00016593.p01.pdf (copy & paste whole URL) Here is the GE part price info on these two parts: DESCRIPTION DRAWING PART NO. PRICE MOTOR-SYNCHRONOUS 43 WB26X10038 $46.00 COUPLER 40 WB06X10144 $8.75 If the motor is bad, you might be able to find the Samsung part number printed on the motor label and look it up at http://www.samsungparts.com They often have parts for far less than the expensive GE parts.
Posted on Dec 04, 2006
ginko
  • 19396 Answers
SOURCE: GE Spacemaker XL1800 Microwave
You need to take apart the oven and fix the turntable gear, then reassemble it, it is not a difficult job. Always work with power unplugged.
Posted on Aug 04, 2008
GE Profile Spacemaker XL1800 microwave turntable
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
On some, you have to cut the motor cover off with snips, then use a screw when reassembling it.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Oct 28, 2013 | GE WB26X10037 Microwave Stirrer Motor
see for the turn table obstacle of any screw or something else.
Aug 04, 2008 | Samsung MW1030WA Microwave Oven
GE Spacemaker XL1800 (jvm1850sh06) problem
Use a hair blow dryer to dry out the underside of the microwave. After you are convinced that it is dry you may operate it again.
That said, if it still is acting up read this:
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician.
Aug 06, 2009 | Microwave Ovens
GE Spacemaker XL1800 does not heat. All other functions appear to be working normally, the light comes on and the turntable functions. When turned on, it makes a humming noise slightly louder than normal,...
Possible bad heating element, You should remove the cover of the unit and look at the heating element with the power off. Until you get your problem resolved I would recommend not to even turn it on due to the fact that you are unsure what is going on and you smelt some burnt smell. Just for safety until you fine the problem
Feb 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
you need to replace the motor turntable, that will cost you around 30 bucks...its not easy to disassemble the unit you nee to send this to a shop im afraid
cheers
Nov 07, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
My ge profile spacemaker xl1800 turntable stopped it turns once in a while. What do I need to replace. Where can I find the part number?
It's probably a bad turntable motor or coupler.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
Nov 03, 2007 | Roper MHE14XKB Microwave Oven
Dec 01, 2006 | Samsung MW1030WA Microwave Oven
Samsung MW1030WA Microwave Oven Logo
3,691 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
