Question about HP Office Equipment & Supplies
The printer is printing lines across each page (usually one of each toner color, sometimes only black)
  • debater Nov 17, 2008
    three of the 4 cartridges are almost full?
    Scholar:
  • 181 Answers
The toner cartridge is near to empty so the powder collected on the wastage side is getting leaked when ever you give a printout and that leaked powder creates a line on the paper. or there is a dust collected in the lower area of the printer by the leaked tonner. replace the cartridges or get refilled it properly.to make this problem clear.
Posted on Nov 17, 2008
Epson Aculaser C1750N printing black
When a color printer prints all black, it means the printer is putting either just black on the page, or all colors which appear black. The first step is to figure out if it's just black, or all colors. You can print a half page by opening the printer during a print. Then look at the page to see if there is any color in it. Try rubbing some of the toner across the page to reveal colors.
If the problem is black only, then try replacing the black cartridge. If the black toner doesn't fix it, then it may the the black laser or control module.
The all colors are on the page, then you probably have a bad control module.
Nov 25, 2014 | Epson Office Equipment & Supplies
Tip
When u print if u r getting the Horizontal or vertical line then follow these...
If the print is a dismal gray rather than a sharp black, you are probably almost out of toner. This can manifest itself evenly across the entire page or in splotches or stripes, depending on the printer.
Sometimes you can wring a little bit more out of a toner cartridge by taking it out and gently shaking it from side to side (never up and down, as toner can spill out). You can also try turning up the printer’s contrast adjustment, if it has such a knob (usually on the back side if it exists). Faded print can also result from a dirty corona wire, because a dirty wire inhibits a full electrical charge from being passed.
If the printouts are consistently varied in density, and you have to frequently remove the toner cartridge and shake it to redistribute the toner inside it, make sure the printer is sitting on an even, flat surface.
Horizontal black lines
A horizontal black line on the printout is probably the result of a dirty or damaged roller. There are lots of rollers in the printer, and you can use the space between the lines on the page to determine which roller is causing the problem. Measure the distance between the errant black lines on the page and then use Table A to determine which part might be causing the problem. Table A
Distance between lines
Faulty part
0.5”
Registration assembly
1.5”
Upper registration roller
1.75”
Lower registration roller
2.0”
Toner cartridge developer roller
2.56”
Lower fusing assembly roller
3.16”
Upper fusing assembly roller
3.75”
Toner cartridge photo drum
Regularly spaced splotches
If there are evenly spaced black spots but they don’t extend all the way across the page, the problem is probably a scratch or flaw in the drum or a build-up of toner on the fusing roller. If the spots are less than three inches apart vertically, it’s probably the drum, because the drum has a larger diameter than the fusing roller.
Vertical black line on edge of page
This can indicate an almost empty or faulty toner cartridge or (less frequently) some spilled toner inside the printer.
on Aug 28, 2008 | Lexmark X5470 All-In-One InkJet Printer
White lines when printing
Usualy white lines are a signal for you that is time to replace a toner cartirdge.
Your machine may inform you that you need to replace a toner cartridge, but sometimes the toner levels are low and the machine doesn't indicate that.
Another thing that you may try is to clean all toner cartridges using each corona wire.
If you need to replace your toner cartridge check this easy and helpful way to replace toner cartridge.
May 16, 2012 | Brother MFC-9320CW Color Laser Printer -...
Cp2025 horizontal color lines almost 3" apart.
you have to replace toner cartridges (unfortunately).
Same problems can be occured whit CP 1025 too
the problem is - cartridge image drum failed
Jul 14, 2010 | HP Laserjet Cp2025n Printer
Hi Everytning I print has a very narrow pink line straight down the centre of the page, also every so often the print has a black/yellow/blue/pink thick line running across the page. Thanks
The narrow pink line is coming from your magenta toner/drum cartridge. You may be able to open the from cover and look at the 4 toners. If you look at the magenta (like pink) cartridge, you might see the thin line on the drum surface.
The multicolored band that sometimes shows up on your prints is most likely the transfer belt unit. This is caused by an area of the belt that is not being cleaned very well. This probably tends to show up when you are running mutilple prints of a page.
So it looks like to may need to replace your magenta toner and look at getting a transfer belt unit.
May 13, 2010 | HP Color LaserJet 2600n Printer
HP 2600N PRINTS A BLACK LINE VERTICALLY ACROSS THE PAGE (FROM TOP TO BOTTOM) RIGHT IN THE MIDDLE EVERYTIME YOU PRINT SOMETHING . WHAT COULD THIS BE? I HAVE CLEANED EVERY DRUM, THE FILM ETC AND IT KEEPS...
You either have a defective black toner, a bad fuser or transfer belt. From my experence it is usually a bad toner cartridge. After you print a couple of pages, pull the black toner and see if there is anything on the drum. If there is try shaking the toner, sometimes toner does like dirt and clogs up. If you still have problem you will have to try another toner. I know that is not cheep, but I don't know any other way.
Mar 02, 2009 | HP Color LaserJet 2600n Printer
Printer Problem - Konica Minolta 7450
Horizontal lines
A horizontal line on the printout is probably the result of a dirty or damaged roller. There are lots of rollers in the printer, and you can use the space between the lines on the page to determine which roller is causing the problem. Measure the distance between the errant lines on the page and then use Table A to determine which part might be causing the problem. Table A
Faulty part
0.5”
1.5”
1.75”
2.0”
2.56”
3.16”
3.75”
Vertical line on edge of page
Sep 03, 2008 | Konica Minolta DiMAGE Z10 Digital Camera
Printer prints a line across the paper around three inch from the left hand side of the page.
Check your Toner Carts.
Is the line a certain color?
Black perhaps?
Lift the door of the toner cart.
If you see a streak on your toner drum, you will see a streak on your paperwork.
Look at your fuser as well.
Is there a problem with the big orange roller?
BEWARE! Don't touch the fuser roller its EXTREMELY HOT!
Let the printer cool down before inspecting.
Apr 24, 2008 | HP LaserJet 5500dtn Color Printer
218 people viewed this question
Ben Johnson
