SOURCE: hitachi 60v710 yellow tint to screen with normal in center to top
sounds like a magnetic field near your screen
SOURCE: My Hitachi 65F59 has a
SUGGESTIONS TO RESOLVE WHERE THE PROBLEM IS:
1. GO TO A BLACK AND WHITE CHANNEL OR PROGRAM AND TURN THE COLOR IN THE CUSTOMER MENU ALL THE WAY DOWN.
IS THE PICTURE BLACK AND WHITE OR REDDISH ETC?
iF THIS IS THE CASE I CAN TELL YOU HOW TO ADJUST THE SET MANUALLY--NOT WITH THE REMOTE BUT IN A DIFFERENT WAY.
I am here to help people and if this helps you rate this solution as very helpful as I do this here for free.
Make the check to see if you have a BW picture or not, if not respond and I will tell you how to adjust---it will take about ten minutes to do it.
REGARDS, SD TECH
SOURCE: i have 62vs69. i just put a new lamp in it. here
that is a problem on the color wheel you also need to replace it the wheel spins not accurate thats why the color is not correct.here is a link to give you a guide how to replace the color wheel.
SOURCE: how to change lamp in 62VS69 - Hitachi DLP
Here is a guide that will help you out
http://www.fixyourdlp.com/guides/hitachi/UX25951.php
