Documents not printing
Whther it be in word or email, nothing is printing.
tried to re-install drivers. everything is plugged in - tried to change the usb port. the display on the operating panel goes blank. documents just go into queu. - waiting to print.
  • Anonymous Apr 28, 2009
    Replace the display if you can find one. That is the problem I am having.
    Scholar:
  • 181 Answers
Follow this steps 1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly
Posted on Nov 17, 2008
Bizhub C450 strange printing problem. Green data LED is flashing but nothing happens.
Did you try to change the IP address of MFP. Please change IP address of MFP and connect the PC you are sure not giving any problem. If its works fine then connect rest of the remaining PC's
Nov 15, 2014 | Konica Minolta bizhub C450P Laser Printer
Laserjet 1020 with mac osx
Ok, you may want to consider re-installing the printer driver or in any case download updated printer drivers. Just don't forget to reboot after installing:)
Oct 16, 2008 | HP LaserJet 1020 Printer
New Hp Officejet 5610 All-in-one - Printing?
You may have a couple of problems. First, you say you have more than one icon in your Printers dialog box for 5600 series printers. My guess is that you installed two different drivers, one for the 5600 and one for the 5610.
Try deleting the 5600 printer icon and making the 5610 the default printer. Run the test print again to verify it works, then open a Word document and see if you can print that.
This brings me to the second issue; what exactly are you trying to print? The issue in this case, may not be the printer but an issue with the document. Some documents have a security feature that prevents printing. Try different documents (Word, Excel, etc...) and see if the problem is across the board. Post the results here.
Thanks.
Sep 23, 2008 | HP Officejet 5610 All-In-One InkJet...
HI I HAVE JUST REPLACED THE INK IN MY CANON MP 760 PRINTER. ON THE PRINTER ITSELF HOWEVER, AFTER OPENING A DOCUMENT (WORD) TO PRINT, IT FAILS TO PRINT. THE PAPER IS STILL FED TROUGH AS THOUGH IT IS...
Check that is defined as default printer in 'installed printer' in Windows, and that you are not sending documents in printout to another non connected printer present in Windows under 'installed printers'.
Unplug completely computer from power socket and from USB for 10 minutes, to get rid of electrostatic problems on USB. Plug everything back and restart.
Check the USB cable, replace USB cable with a different one to check if it was the cable.
Uninstall printer from 'installed printers' in Windows (delete). Disconnect printer from USB, reinstall printer from printer software CD or downloaded driver. Connect printer to usb only after installing, or when explicitly required by software, this is important
Here is link to driver download, put your windows version in select OS box.
Apr 23, 2008 | Office Equipment & Supplies
Re-installation of printer software won't complete
i'd say you may have a corrupted system file..had your computer tuned up lately?
Mar 28, 2008 | HP LaserJet 1020 Printer
Bought used hp all in one 6110 will not print
What I would try is:
1. From Control Panel > Printers... uninstall all printers that are there.
2. Unplug the printer from the port.
3. Get the Vista drivers from HP's site.
4. Install the drivers.
5. Plug the printer back into the usb port. The printer need to be ON, btw.
6. Check the Control Panel and confirm that the printer is there and is check as the default.
I had a ghost copy of my HP in the control panel and my applications were trying to print to it, all that did was put documents in the Print Que.
Geno
Feb 09, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP DeskJet 840c
pls. change your data cable of printer connected to computer
if it is work pls. remarks
Jan 30, 2008 | HP DeskJet 840c InkJet Printer
Document printing hangs at 99%
same problem. everytime i restarted my pc and deleted the printed files from control panel/printers/lexmark x5150.
Dec 18, 2007 | Lexmark X5150 All-In-One InkJet Printer
My hp psc 1210 won't work with vista
I had a similar problem! Here is what eventually worked for me, after searching through postings for hours on end...
First, I made sure I had the new driver. Second, (and this might be different for you), my computer recognized my printer, but any time I sent something to print, it never made its way there. The little printer icon at the bottom said 1 document pending, then quickly said 0 documents pending, but nothing ever printed. When I ran HP diagnostics, it said everything was okay with the printer, and even printed a test page! But still nothing from any other program. So, eventually I went to control panel, then printers, then I clicked on the HP printer, then right clicked and went to properties. I changed two things in here, and I'm not sure which one was the solution. First, I changed the security settings (in the security tab) so that every user had access to all options for the printer. Second, on the advanced tab, I selected print directly to printer instead of the spool print documents option. And tada it worked!
May not solve anyone elses problem, but I didn't see this solution in any of the posting sites, so I thought I'd share it. Give it a try!
Aug 27, 2007 | HP PSC 1210 All-In-One InkJet Printer
101 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
