Question about Sony DAV-C770 System
Won't read dvd's or anything, just says mechanics error
It says ready! and I put a dvd in and it doesn't read. It just spins, or sounds like it anyway lol, And then it tries to reload the dvd in I guess. I put a disc in Disc 1 slot, and it spins, doesn't read, then the display says *Disc 1* which is what it says when you load a disc in, so I have no idea what's going on, it worked yesterday, but now it won't read anything, not cd's and not dvd's. After about 10 minutes it will say *Mechanics Error* Is it time to just give in a buy a new one?
    New Friend:
  • 111 Answers
No try to open the cover and inspect anything stuck in loading mechanisum.check the all reed swiches and clean all if they are dusty.
shall we try to repair it.
nuwan..
Posted on Jan 12, 2009
I get a disc error...cannot read disc, on every dvd that i put in. Is it ready for the dump or can it be fixed?
It sounds like a laser problem! It could be just a dirty lens, you could try a lens cleaner!
Nov 02, 2014 | Samsung DVD-1080P7 DVD Player
Why my portable dvd playing won't play when i put a dvd dics in?
If it takes and accepts the disc but will not play it is either a mechanical issue (table not spinning the disc) or if not reading disc it is likely a dirty or bad optical pickup in the unit---
Nov 03, 2012 | Televison & Video
Jvc dr-mv100 won't eject dvd and doesn't sound like it's trying
Check and replace the CD loader mechanism. It is faulty. Do not loads CD onto reading deck properly.
Jun 06, 2012 | JVC DR-MV100B DVD Recorder/VCR
Doesn't load the disk
Someone needs to open it to SEE what is happening--if the unit holds more than one disc (model seems to indicate that) you likely have a mechanism problem with something jammed or even broken--mechanism could also be out of alignment which is a task for a pro.
Look and see what is happening is first thing needed here.
Apr 24, 2012 | Cyberhome CH-DVD 300 DVD Player
Dvd's won't play on my sony dvd player
If making a noise the issue could be in the mechanism and or the motor that spins the disc---unless it is a real expensive and fairly new unit it would be better to just replace it.
Apr 16, 2012 | Sony Televison & Video
Won't spin
Hello
The loading mechanism to your player is faulty. It doesn't engages the disc in to place perfectly. Replace the loading mechanism.
Mar 07, 2012 | Lite On LVW-1105HC DVD Recorder
I have an Orion FTDV2004A tv/vcr/dvd combo. I was playing a DVD movie. When I paused it, it would not start playing again. Now, every DVD I put in, says "reading" and then "incorrect...
Hello
Just power OFF the set by its main power OFF switch, and switch in ON, while listening very close to its mechanism side and see whether there is any sound of disc spin. If disc do not spin inside the mechanism, due to a faulty sled motor, the fault you descrbes here will occur. If disc spins inside, and still it does not reads the disc, the laser pickup unit is faulty and should be replaced. OK.
Nov 06, 2011 | Orion FTDV2004 20 in. TV/VCR/DVD Combo
When loading a dvd it displays, "NO DISK". Is it
Hello
There are mainly three motors for most of the DVD players. One to spin the disc we insert in, other to load the laser pickup unit to-and-fro inside it to read the disc and an other one to load the tray mechanism 'in-out'. According to your description, the disc spins inside, and you can hear its spin. So motor which spins the disc has no trouble at all I should say. Then comes to the second motor that moves the laser assembly inside it. If it do not work, the laser pickup unit won't move and no reading will take place and 'No Disc' display will be the result. The last chance is with Laser Pickup Unit itself. Just get this unit repaired by any well experienced service technician or by the authorised service center, because, there are special tools to open this unit. As it is a compactable one, more care should be given to it while repairing. Suspect the second motor I described earlier, and the Laser Pickup Unit. OK.
Jun 14, 2011 | RCA DRC628 Portable DVD Player
Dvd for acer notebook won`t burn
1. check ur dvd can burn dvd or just read dvd 2. your burning software my not compatible with yor optical drive
Apr 09, 2009 | Acer Aspire 5100 Notebook
Sony DAV-C770 System Logo
239 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
