Question about Goodman GMS90703BXA Heater
3amp fuse keeps burning out
The 3amp fuse keeps blowing out when I try to turn the furnace on.
    Genius:
  • 1,019 Answers
when a fuse blows, its telling you that theres a fault. this could be a loose or broken wire.
or alternatively, the fuse rating is too low. you could check the wires are tight. and also possibly try fitting a 5 amp fuse. check first that the fuse is rated correctly for the appliance. usually 3-5 or 13 Amps.
Mike @ compurepair.
Posted on Nov 17, 2008
    Problem Solver:
  • 5 Answers
That fuse should be a 3 amp fuse. There is either a problem in your wiring, your A/C contactor or the board.
Posted on Nov 19, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Champion:
  • 214 Answers
Try increasing the rating of the fuse (3-5 AMP.) If it blows up again, there might be something wrong w/ the circuit
Fan will not cut off even in auto position. It just keeps running
If the fan will not turn off when the thermostat is turned off the thermostat is not the fault. It could be the wiring from furnace to thermostat. Disconnect the thermostat wiring from the furnace to isolate the possible problem component.
Apr 12, 2015 | Honeywell Programmable Thermostat Heater
Amp fuse keeps blowing
The component being protected by the fuse is drawing excessive current - has to be a board or something because the motor always draws more than three amps. Check the units schematic for locating the possible offending board. Must be relatively new since you indicate it is multispeed. Still under warranty?
Feb 23, 2014 | Gibson KG7SA045C23A 45,000 BTU 80% Gas...
Amana AMH95 Blown control fuse
Control fuses only blow with a 24 volt problem. Make sure that you replace it with a fuse NO LARGER than 5 amps.You could have a thermostat wire pinched or some wire touching the cabinet inside the unit, but it is a 24 volt problem.
Jan 22, 2013 | Amana GMH950453BX Gas Furnace
My carrier furnace keeps blowing 3amp fuse when I turn thermostat to cool.
Hello, sounds like there is a short in the low voltage circuit. First inspect the wiring at the control board and make sure nothing is loose or touching metal. Also, inspect the wiring all the way to the outside unit and make sure it is not loose or touching metal on the outside unit. If you dont see anywires loose then you will need a meter to check the wires for continuity to the common terminal on the board with furnace and ac turned off.
Apr 23, 2011 | Heating & Cooling
No water no heat 3amp fuse keeps blowing but does not affect the rest of the house. Changed the fuse but it blow immediately - not even chance to fire the boiler up again. The electric point is not...
You have a short in the low voltage wiring somewhere...usually in the furnace wiring or the t-stat wiring...
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Jan 11, 2011 | Heating & Cooling
Goodman furnace
double check your wiring. R terminal on the furnace will provide 24 volts to the t-stat. W terminal in the t-stat will send 24 volts back to the furnace W terminal to turn on the heat. G terminal in the t-stat will send power to the G terminal in the furnace when the t-stat is switched to fan on. Y terminal in the t-stat will send power to the Y terminal in the furnace which in turn will send 24 volts to the A/C outside. The C terminal in the furnace should be connected to the c terminal in the A/C outside as well as to the T-stat. Check the fuse again
Jun 02, 2009 | Goodman GMS90703BXA Heater
Furnace start buts shuts off
It sounds like you have an obstruction in the exhaust vent. Thats why when you bybass the pressure switch it runs ok. Steve
Dec 15, 2008 | Goodman GMS90703BXA Heater
Goodman Furnace/AC unit not working 3a fuse blows even after replacement. once thermostat is turned on and clicks to start ac unit the fuse blows
3 amp is standard.the fuse is blowing to protect the transformer.It is telling you that there is a short in the low voltage wiring.Goodman also had an issue with the coil shorting on the contactor.To prevent damage.....i'd call a pro.It should be a fairly simple repair.
Jul 03, 2008 | Goodman CLQ36AR49 Air Conditioner
The whole system won't turn on
Go to Logitech support and check the faq's on your speakers. You must replace with the same fuse and it may be a 3amp slow blow fuse. If so replace with the same fuse or you will just keep blowing them out.
Jan 11, 2007 | Logitech Z-5300 Computer Speakers
Goodman GMS90703BXA Heater Logo
902 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
