Question about Compaq Evo D500 PC Desktop
Reset BIOS password
I have a compaq evo d320, the previous owner had set a password on the BIOS/utility set up, I can login into it by just pushing enter 3 times on at password stage then utility loads, but I can't change anything in it, as if I'm locked out of changing any thing.
I tried a method of removing battery, it did kinda look like it had reset but then password page came up again upon entering utilties, plus it also said that the CMOS was invalid.
What else can I do to resolve this issue and thanks in advance.
  • 3 more comments
  • Patrick De Thierry
    Patrick De Thierry Nov 17, 2008
    I can't see a small bit of coloured plastic near the battery, I can't seem to see no switch I could switch at all. I tried the battery trick again but to no avail. Hmmm...if I could find this jumper switch then maybe I could get somewhere.
    Patrick De Thierry Nov 18, 2008
    Hey leecom72
    Yeah I have found the jumpers, tried moving it over for 10 seconds then moved it back, I restarted my computer, then I see the ram load then it loads all this stuff then restarts, it does that 3 times before loading windows again, when I try to intefer and press F10 to go into bios, it lets me in, but still cant change anything, and when it does load the windows everything is blank except for the wall paper, there is have nothing else showing. So i did jumper again, let it restart 3 times and load windows then all my stuff for windows is all back.
    Don't know what else I can do.
    Yeah it does ask for password
    No a eve d320
  • Tim Brock May 11, 2010
    try resetting the jumper settings. you have to open it up to do it, its somewhere on the motherboard.
  • Compaq Master
  • 4,806 Answers
Ok, this time try to reset the bios using the jumper (small bit of coloured plastic near the battery) move the position of the jumper and hit the on/off button, the computer should not start if you have done this right, move the jumper back to its position and start the pc, go straight back into the bios and set the date and time, hit F10 and ok or yes and you should have full control of the bios.
if there is no jumper, remove the battery again for 10 mins and make sure the power cord is removed from the back, hit the on/off button a few times to drain any residual power, after 10 mins replace the battery and do what i told you to with the bios
good luck
Posted on Nov 17, 2008
  • 4 more comments
  • Lee Hodgson
    Lee Hodgson Nov 17, 2008
    if there are two metal prongs near the battery housing then thats the cmos reset, you can short this by usind a flat head screwdriver to bridge them and press power on, if there are no prongs, remove all power from the PC and remove the battery again for 10 mins, put it back after that time, when the computer restarts it will say "cmos invalid, press F1 to continue or Esc or Del to enter settings", you need to go into the settings to set the time and date, all passwords should be cleared
    good luck and kind regards
  • Lee Hodgson
    Lee Hodgson Nov 18, 2008
    Does the bios still ask you for a password to chane the settings?
  • Lee Hodgson
    ok give a little time on this, the cmos should have reset when you took the battery out and cleared the cmos with the jumper, power had been removed from back! and left for 10 mins minus the battery, i will check to see if the bios chip has onboard memory and see what i can do about this.
  • Lee Hodgson
    is the pc a EVO D500? just to verify because i think i may have a soloution for you :)
  • Lee Hodgson
    Since HP provides no useful documentation for the
    D320 I do not know if the CMOS reset is a button or jumper. I will
    assume that it is a button.
    There should be a a small white button in a yellow
    circle next to the IDE connectors. Please press and hold this for 15
    seconds. This will help you reset cmos but this is a manual operation.
    Disconnect the power cord (again) then press the Clear CMOS
    button for 10 seconds. If it is a jumper move the jumper from the two
    pins it is on to the other position for 10 seconds and then put the
    jumper back on the original pins like i explained before.
    Keep me informed please
    Hope this helps.
  • Lee Hodgson
    Try this password if all this still fails: "Compaq"
How can i reset login password to my pavilion dv6
Common approach is to remove cmos battery for a few minutes to reset bios info. On compaq F10 bios, you can go into bios setup and go back to default setup, which resets to no password set in bios.
Feb 08, 2012 | Computers & Internet
Evo N610c bios password
BIOS passwords can be reset in two ways,
1. using software 2. using hardware.
I would first try resetting using software, here are two software's to reset or retrieve BIOS passwords.
!BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore.
CmosPwd - Cmos password recovery tools
Please let us know if it works.
May 29, 2011 | Compaq Evo N610C Notebook
Give me password for compaq evo n600c
You can remove your bios password by reseting your CMOS battery or jamper. You need to open your notebook remove first the battery and all screw at the back of your notebook. You can see there a CMOS battery together with the CMOS jamper. Just read it you can read CLRSCR which means clear cmos, just pull it with in 10 seconds and insert it back. Now you are done to reset bios.
Mar 03, 2010 | HP Compaq Evo Notebook N600c
Compaq Evo D310 power on password reset
you can reset it easily by using the jumper near the bios battery (usually) on the motherboard then go into the bios settings at boot time. hope this helps
Aug 17, 2009 | Compaq Evo D310M 845G P4 Motherboard
I have forgotten the power on password of my compaq nx6310 laptop
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Then it not want password.
Jul 16, 2009 | Compaq Evo N610C Notebook
Compaq Evo N800c BIOS PASSWORD LOST
the only way is to open the laptop up and there will be a small watch type battery, quite big but flat. it will be on the motherboard. take the battery off the otherboard for at least 10 seconds and then put it back in. this should reset the bios to factory default.
Jun 18, 2009 | HP Compaq Evo n800c Notebook
How to reset BIOS password for Compaq EVO N160 notebook
Do the following steps -
- Remove the laptop battery - Remove the CMOS battery - Leave it for idle for around 15 minutes - Put the CMOS battery in - Boot the laptop  with AC power - Then put the laptop battery in.
 - The BIOS pwd would have been reset now
- For troubleshotting the battery - Go into BIOS and run the Battery Caliberation tool
Hope this helps. Thanks, AK
Oct 27, 2008 | Compaq Evo N610C Notebook
Clear power on password
Removing the Time of Year battery will clear the BIOS password. It is located on the underside of the n610c behind the panel covered by the Microsoft COA label. A small phillips screwdriver is required to remove the two screws on the panel. Carefully lift the BR1225 battery with a small flat blade screw driver.
After 10 minutes re-insert the battery. The BIOS Password should now be cleared, as well as other BIOS settings, the time and date.
Sep 09, 2008 | Compaq Evo N610C Notebook
Compaq Evo D500 PC Desktop Logo
1,282 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
