Question about Maytag Neptune MAH5500B Front Load Washer
Maytage Neptune Model #MH5500BWW will not drain
When the cycle gets to 9 secs the machine starts humming, does not drain or spin. It then just counts down without doing anything else.
  • Anonymous Nov 21, 2008
    I have the exact same problem. How do I fix this?
I removed the pump and removed thread from a rug that had been washed the day before. The thread had bound up the pump preventing it from turning. Once the thread was removed and the parts put back together the machine worked perfectly.
Posted on Nov 21, 2008
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ... > ... > Home Improvement
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
Hi Experts, I have a 1988? Fisher & Paykel GW51F top loading washing machine, and last week during the spin cycle, instead of draining & spinning, it just hummed for a few secs (draining, I...
Hi just read your posting.Is this machine a Gentle Annie model?Does the machine drain at all?The web address to watch the video of your machine does not work.Please reply with correct address and the name of your machine and I am sure I can help you.Looking forward to your reply.
Sep 20, 2010 | Washing Machines
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
Oct 09, 2009 | Maytag MAH6500 Neptune Front Loading...
Maytag neptune top loading washer with spin problem. spin cycle starts, runs about 5 secs,stops for about 20 secs, runs again for about 5 secs and code of uC pops up on panel. model 6800. Any ideas??
Hey bob_marianne ,
Common problem with the FAV6800AW/FAV9800AW. If you have basic mechanical skills you can fix. It’s just a tight work area to work on the Clutch in this machine. See this post for the details and you can get your $1K machine back in service. Sorry to say a lot of these machines get tossed for a $50 dollar clutch. Let me know if you have any questions after you read the post.
Jul 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytage Neptune E3 code - Model MAH8700AWW - machine won't finish cycle
“E3” code – Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Possible causes of ‘E3’ codes: 1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause. 2. Hall Sensor fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Hall Sensor – PCB that is located on the back of the motor that senses motor rpm. It is not a separate part, but rather an integral part of the motor.
May 28, 2009 | Maytag MAH6500 Neptune Front Loading...
Maytage neptune
"nd" refers to a No Drain issue .check for restriction in pump, restricted drain hose loose wire at pump, bad pump.
The pump had a suds lock. Unplug the machine for a minute. Plug it back in and run a cycle on hot to get rid of the excess soap.
Dec 20, 2008 | Maytag Neptune MAH5500B Front Load Washer
Won't Run
The humming usually means the motor is trying to start but can't either because of weak windings or not enough electrical power. Need to check the motor control.
Mar 01, 2008 | Maytag Neptune MAH5500B Front Load Washer
need more information is it top load or front
Nov 19, 2007 | Maytag Neptune MAH5500B Front Load Washer
Wont spin or drain
The drain pump is jammed or clogged up. Remove the filter cover and check for bobby pins, coins or bra wires. If clean, remove drum to pump hose from the pump and check for any foreign matter. Try to turn the pump impeller by hand. It should turn freely. If pump is not free, replace it.
Nov 03, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
116 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
