Question about Canon imageRUNNER 400S Copier
How do I fix a broken fixing film
Canon image runner
  • Canon Expert
  • 1,326 Answers
You don't have to fix the fusing film on a Canon IR-400, it dose not have one. It has a upper and lower fixing rollers. But it does have a Cleaning Web and it would show on the display that the web needs to be replaced or it codes out with a E005. Afixxing film is on a IR-200 & IR-210 & IR-2200 & NP- 1625 series
Posted on Nov 17, 2008
I have Canon image runner 2420 Copier and It show the error E000007-000 help me to fix this problem
This code is for a damaged fixing film on the unit.
You can just replace the fix film assembly FG6-6039-00R, they have refurbished ones avail. Also, replace the cleaning roller assembly FG6-5709 or just the cleaning roller on that assembly called a fixing heat sink roller FB5-4931-000 if you are brave enough (notice the name heat sink). If that roller gets any build up on it, say from using the wrong type of transparency (use Canon E type only), it can no longer remove heat from the fix film assembly.
Mar 25, 2015 | Cannon Office Equipment & Supplies
ERREUR E 000007
Dear
If it is from canon image runner series, the problem with fixing film assy.(heater assembly). In general the sleeve over the heater gets broken(teared off). either the sleeve (to minimize repair cost) or the fixing film assy. has to be replaced.
very rare SMPS/DC CON board gets defect.
thanks.
Feb 02, 2015 | Office Equipment & Supplies
How to solve E000007-0000 error in canon image runner 2420L
The problem is the fuser heating element is not getting the correct temp. Or the film has shifted to one side & the sensor is not seeing the white square on the film. Take out the fixing assy and check the film.
Also, on the fixing assy, the cleaning roller built up with toner can cause problems
Oct 01, 2014 | Office Equipment & Supplies
WHAT HAPPEN ON IR 2202 FOR THIS EOO2-OOOO AND HOW CAN IRSOLVE IT?
E002-0000 Low temperature during temperature control.
The target temperature is not reached during temperature control. - Check the connector of the fixing film unit. - Replace the fixing film unit. - Replace the
Aug 20, 2014 | Canon Image Runner 2022 Copier
How can clear the error message E000007-000 on the canon image runner
you can clear the code but your problem is the fixing film
its torn and has walked to the front of the device and the patch can no longer be sensed by the sensor
you need to replace the fixing film or the assy
to clear the code
service mode >copier>function>clear>err>ok
reboot the device
Oct 30, 2013 | Canon imageRUNNER 2200
Error code e000007 canon 2420
MY CANON IR 2420 WITH ERROR 000007-0000 HOW CAN ISOLVE THIS PROBLEM
Dec 06, 2012 | Canon Office Equipment & Supplies
Error E007 Canon Image runner 2020 Will not finish perinting a document with the above mentioned error
The error code E007 is a fixing film error code > it will have to be replaced to clear the code. That is if it a IR-2020, a IR-8500 does not have a fixing film.
Aug 20, 2010 | Canon imageRUNNER 8500 Copier
Error code e000007-0000 for a canon image runner 22006
You have a problem with the fixing film. It is not a case that you have to reset the machine and carry on. Replace faulty parts in fixing and then clear the code. Most probably you have a damaged fixing film.
Aug 22, 2008 | Office Equipment & Supplies
Canon image runner 1670F
The problem is :
During printing, the main thermistor detects less than120C°/248F for 1 sec or more continuously.
Replacing the fixing film unit.
See you,
Samir?
Jun 03, 2008 | Canon ImageRUNNER 1670F Copier
Canon 210S Image Runner
It is a fixing film position error. The fixing film is probably damaged or is just tracking off center. If the fixing film is ratched then replace the entire upper fixing unit. You can get just the film but its a job even experienced techs cringe at. Check the lower roller and bushings while you are at it. If anything is worn there it can cause the film to track off center.
Apr 24, 2008 | Canon imageRUNNER 210S Copier
Canon imageRUNNER 400S Copier Logo
218 people viewed this question
old marine
old marine
