Question about Jenn-Air JXT8142ADS Kitchen Hood
When fan is on A flashes on screen
When the fan is running the level such as 3 flashes and alternates with the letter A - Is this a fault code?
This means the screens need cleaning. Clean them with mild soap and water and let them dry. Replace them. Then while the hood is off, hold the minus sign down. The A will come on and then go off.
Posted on Jul 16, 2010
Battery light flashing jump it ,it will start but not run
It could be you have a fault in the Diode pack in the alternator you need to get this checked at an alternator repair center.
Dec 03, 2014 | 2000 Ford Mustang
I have loss of power and when fan is turned on the idle drops killing the engine. What could be the culprit?
This seems to be pointing toward the alternator. When the fan is running, this can take a chunk of available current from the power supply. If possible, check the voltage across the battery when the engine is running. It should be up around 13.8 volts but doe this when you only have the engine running and no radio, fan or anything else switched on. If that's low, possibly 12 or lower, then the alternator needs either the connections checking for corrosion, the belt that it runs off tightening or replacing.
Nov 06, 2014 | 2004 Chevrolet TrailBlazer
The check engine light on a 2001 ford explorer flashes 3 to 4 times
The engine light is there to tell you that the CPU has found sensors/ servos that are out side the set parameters. Run the fault codes and repair faults found.. Check the radiator level at the cap as it may be a low water level sensor.
Oct 12, 2013 | Ford Cars & Trucks
From cold start, put heater fan on and lights flash on and off, when this happens altenator stops charging. has had new gen alternator but still faulting
Questions:
1. Which lights flash on and off?
2. How do you know alternator stops charging?
3. Who/Which Svc Dept. installed new gen alternator?
Step 1: Go back to shop/garage/svc department which installed new gen alternator - TELL THEM IT DIDN'T FIX THE PROBLEM!
You are describing an ELECTRICAL EFFECT... the CAUSES can be many!... not exclusively the alternator.
Feb 08, 2011 | 2004 Hyundai Santa Fe
W1213, pre-wash and main wash lights flash with the 3 lines --- fault code. I tried entering the service mode as I read online I should push and hold start, then turn on the machine, wait for the dot and...
You are in the service mode now. The buzzer LED displays a flashing rhythm of 2 flashes while the ROM ID is show in the display(this is what you are seeing), press the buzz button to advance to the fault register level. Here is the manual to the tech manual http://laundry.manualsonline.com/mdownloads/89c212d9-4843-4409-b17c-b3439c9b0d05.pdf
Dec 31, 2010 | Miele Touchtronic W1213 Front Load Washer
My washer flashes "h" and "f" then stops.
1st, unplug the washer from receptacle. Wait one minute and replug. This will (in many cases) reset the logic board because of some fault it sensed while the machine was running. Now try the machine to see if it operates normally. If still not working, look in your instruction manual to see if there is a section that shows problem (fault) code letters. Some manuals show this info and some do not. If you see a trouble shooting section, it ma y have this info. See what fault code letters match waht flashes on the machine.
Most codes are for imbalanced load while spinning, water inlet valve interuption, overload of machine (too much clothes), power interuption (temporary loss of power while operating, overfill of water level (again usually do to too much clothes or too much detergent suds), a backup of discharge water. If disconnecting power & reconnecting does not reset the machine, check each of the possible problems mentioned. If still no results, you need a service tech visit. Good luck. Macgivor
Sep 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Start light flashing wont start cycle, what does it mean
count the number of flashes- this indicates fault ie will flash 4 times stop, flash 4 times stop. To clear fault, hold start button for 3 secs. Try running another fast cycle- if fault reoccurs count flashes: Number of flashes:1=NTC fault, 2=Flood switch activated, 3=Heating fault, 4=drain fault, 6=water inlet fault, 7=flow meter fault, 8=water level fault
Aug 06, 2009 | Whirlpool Dishwashers
Codes for 1995 Mitsubishi eclipse
Engine-light-help.com
P1100 Induction Control Motor Position Sensor Fault
P1101 Traction Control Vacuum Solenoid Circuit Fault - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1102 Traction Control Ventilation Solenoid Circuit Fault - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1103 Turbocharger Wastegate Actuator
P1104 Turbocharger Wastegate Solenoid
P1105 Fuel Pressure Solenoid
P1294 Target Idle Speed Not Reached
P1295 No 5 Volt Supply To TP Sensor
P1296 No 5 Volt Supply To MAP Sensor
P1297 No Charge In MAP From Start To Run
P1300 Ignition Timing Adjustment Circuit - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1390 Timing Belt Skipped One Tooth Or More
P1391 Intermittent Loss Of CMP Or CKP Sensor Signals - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1400 Manifold Differential Pressure Sensor Circuit - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1443 EVAP Purge Control Solenoid '2' Circuit Fault
P1486 EVAP Leak Monitor Pinched Hose Detected
P1487 High Speed Radiator Fan Control Relay Circuit Fault - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1489 High Speed Condenser Fan Control Relay Fault - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1490 Low Speed Fan Control Relay Fault
P1492 Battery Temperature Sensor High Voltage
P1494 EVAP Ventilation Switch Or Mechanical Fault
P1495 EVAP Ventilation Solenoid Circuit Fault
P1496 5 Volt Supply Output Too Low
P1500 Alternator FR Terminal Circuit - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1600 Serial Communication Link
P1696 PCM Failure EEPROM Write Denied
P1698 No CCD Messages From TCM
P1715 Pulse Generator Assembly
P1750 Solenoid Assembly
P1791 PCM ECT Level Signal To TCM Circuit Fault
P1899 P/N Position/Transaxle Range Switch Circuit Fault - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1751 A/T Control Relay
P1791 Engine Coolant Temperature Level Input Circuit - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1795 Throttle Position Input Circuit To TCM - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
Mar 21, 2009 | 1995 Mitsubishi Eclipse
The cycle stops, beeps and flashes and H and F
f/h is a "no water entering " fault code. check incoming watersupply first, then check hte inlet watervalve screens for blockage
Feb 08, 2009 | Kenmore Elite 45986 Front Load Washer
My monitor fails to start and the power pack shows 12-22 repeatedly
Howdy, I guess you're talkin' about a : Sony PFM-500A2W Plasma screen ?? The fault-codes your talkin'about " 12/22 " + continue re-starting " is a common problem with those plasma screens. It gives an " low power " message on the PDP module . We started today a discussion-group at google.com to get a clear picture at the Sony. We allso placed a " fault-code " list , so users can see what those codes are standing for. The main target of the discussion-group is ..... sharing knowlegde and information about the Sony PFM-500A2W. Schematics Problem solving fault finding Where to get any kind of parts. Print layouts etc. etc. The followin' link shows the discussion group. Please give us some time to startup the group. So don't give up any hope ;-) http://groups.google.com/group/SONY_PFM-500A2W Best regards , EuroNet 2000 The Netherlands
Feb 07, 2007 | Sony PFM-500A2W 42 in. Television
Jenn-Air JXT8142ADS Kitchen Hood Logo
131 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
