Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
My portable harddrive fell from a low table
1. My Simpletech Portable Hardrive was functioning well and was seen as Drive F: in my laptop.
2. It accidentally fell from the table while it was on and connected to my laptop.
3. The laptop cannot read anymore the drive F:
4. I unplug and re-plug it, and it only shows for about 1 minute in the system tray and disappear. The red light is on but the blue light just blink once after replugging.
5. Can the harddrive be still fixed? or was totally damaged?
Help please, thanks!
Problem solved! i opened the harddrive and found that the green board of the harddrive was loosely connected to the usb board though, i lost my 3 yr warranty because i remove the warranty sticker unscrew the harddrive casing.
Posted on Nov 19, 2008
  • 849 Answers
I am afraid that the drive has gone, but you could try to fix it using disk manager application.
Posted on Nov 17, 2008
After a time, Computer not recognizing portable harddrive
Reformatting will be our last option and there are a number of steps that you can try to fix this.
  • Try plugging it in on a different USB port
  • Check the USB cable, try replacing it and see if it works
  • USB ports on your computer makes use of power, so if you have multiple USB devices plugged in, the portable hard drive might not be receiving enough power. Try plugging it in without your other USB devices, except the mouse of course
Please leave me a comment for this.
Jun 03, 2009 | SimpleTech Signature Mini 320GB External...
Simpletech external portable drive not working due to power surge
Then you should not connect the adapter, I think your HDD is fried, because these HDDs are USB powered, they do not need any extra power. That’s why HDD data cable comes with two USB 2 pins , one is for data and other is purely for power.
Mar 17, 2009 | Computers & Internet
SimpleTech portable hard drive 250gb
are you using a power source for the unit, it has to have its own power supply to work. if you have the cable connected for the power and the usb connected to the laptop/pc, go to the windows log and right click on the logo, a menu will pop up. click on device manager on the device manager settings you should see your drive probably with an x on it, click on the drive and go to the update drivers and make sure you're on the internet. and click update drivers, if there is a driver that windows can use it will install the driver if not, then windows will not load a driver. if still not working try this web site Solvusoft Microsoft Gold Certified Company and download the drivers from them. if this still does not work then replace the usb cable as it may be faulty.
Aug 08, 2017 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech 80 GB Portable HD Won't Read
It sounds like a problem with the board inside the case,- the actual hard drive is probably OK. Opening the case will void any warranty but there may not be much left anyway. There should be 4 screws in the bottom of the drive,- front 2 may be hidden under a sticker. Try installing the drive in your new case or an empty drive bay inside your computer. I have had external hard drive cases fail before and the actual hard drive was ok.
Jan 23, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Simpletech 160 Portable doesn't show up
because it is not properly connected.connect it well.
Jan 13, 2009 | Computers & Internet
Unresponsive harddrive
hi,
you have definitely got a dead HD (hard-drive) there, nothing you can do about it.
sounds like the force of the shock has damaged the HD beyond repair.
HD work by i high precision arm that reads data on a spinning platter, the chances are you have damaged the arm and the click is where the arm is trying to read the HD with no luck
sorry
Dec 28, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
SimpleTech 100GB SimpleDrive portable USB
Sounds like the file system on the disk is now corrupt. You may need to use a recovery programme to get your files back but nothing is for free.
Jun 17, 2017 | SimpleTech 100GB SimpleDrive portable USB...
Do not detect portable hard drive run by usb
Power issue will not be fixed without an external power supply like plug into a wall socket.
May 10, 2008 | EliteGroup ECS A535 Notebook
go into the control panel and click add/remove hardware... and manually add the device and then use the auto update to download the drivers
Jan 22, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
253 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Ricky Ostrom
Ricky Ostrom
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
