Question about LG LRFD25850 French Door Refrigerator
Crisper Door broken
I have the LG French Door Fridge (model number LRFD25850SW). There are two crisper drawers that pull out and when you pull it out the drawer lid opens (lifts up) automatically. Well the right clip that lolds the lid on is broken. I need help finding this replacement part. Here is all of the information that is on the lid. >PS< 3806JJ2044, AS.M.11 #2. Please help...
Thanks,
Ron
  • 5 more comments
  • Anonymous Nov 23, 2008
    We have owned our LG French Door for two years and are extremely disappointed with the quality. We have a long list of problems with this fridge. All of our crisper drawer's track's are cracked. This summer the poorly designed doors were closed but not given the extra push shut, (you have to check each time) and the entire contents of my fridge spoiled. Upon taking it all apart to clean I discovered about a dozen small parts and cracked pieces of plastic loose at the bottom of the fridge. All were parts from the cheap drawers tracks.
    The good news is we had purchased a Best Buy extended warranty. The bad news was it took two months of repeated service sits and incorrect parts received for Best Buy to determine we had lemon fridge and replaced it.
  • knovak1002 Dec 03, 2008
    I have the same problem. Can you let me know if you were able to find the replacement?
  • rtishchevs Dec 14, 2008
    Same thing - left plastic hook on the left flipping lid broke
  • Anonymous Dec 23, 2008
    crisper door broke
  • bigzinner Jan 21, 2009
    I found the Crisper replacement door on Repairclinic.com for $12.45 plus shipping
  • thronedoggie Feb 06, 2009
    Yep - me too.
    I tried repairclinic.com - couldn't find the part : (
    I contacted the LG parts distributor for the west coast - they're researching it.
    Anybody found a reliable source for this part?
  • David Nov 12, 2012
    Agree. I purchased the LRFC22750 and have had nothing but problems with it. Door alarm didn't work and as a result the cover and control panel melted. Since, various parts breaking and seal on the door is messed up so you need to be extra careful to give the door a shove to make sure it is closed completely.
Repairclinic.com had the parts I needed (crisper drawer lid and the longer drawer lid.
Posted on Apr 21, 2009
I have the same problem with my Kenmore Elite french door fridge made by LG. The plastic buttons in the drawer break due to the forces that they are subjected to. I used VersaChem's "Plastic Welder" to glue the buttons back together. The button is easily removed by gently prying on the rear of the button cover with a flat screwdriver, gently lifting the corner tabs over the drawer. Unfortunately, the button is not available as a part from Sears, and they want $44 for an entire new drawer. Knock on wood, as my fix is still working, though I've told the family to take it easy on the drawers when they pull them out.
Posted on Jan 03, 2009
Need drill, small bit, fishing line, split shot or bobber stop.
Drill small hole (so knot in fishing line will not slip through) up through tray as close to circular socket where broken tab would have inserted, on inside edge. Drill another hole close to end of broken tab on crisper door. Tie knot in fishing line and insert from top of tray. Now insert through hole on broken crisper door tab from inside edge so fishing line comes out towards center of drawer. Squeeze on split shot or slide bobber stop up fishing line snug to tab. Door should hang in place and work fine.
Posted on May 30, 2012
  • monsonmj
    monsonmj Oct 23, 2013
    Wife tired of tightening up the split shot. Took light metal rod (from old grill) and cut to just fit in the two sockets where broken tabs on door used to fit. Drilled small holes near top and about inch down (near each edge and center). Used small zipties to create loops around the rod.
I need a right hand crisper draw for a Samsung refridgerator model srf680cdls
Hello Kate Nicholas,
Your model srf680cdls... does not respond domestically in the USA... If you provide your ACTUAL PART NUMBER I could attempt to check CRISPER availability ... here (you appear to have an "AU" model.
Just looking around the large plastic body would appear to cost about $60 (USA)... I'm pretty sure we share the MANY of the same internal part numbers..
http://www.woolleys.com.au/?gclid=CPqQzujj184CFQYdaQod1n0AIw
BigWarehouse Spare Parts samsung crisper drawer
Sydney Only Samsung SRF680CDLS 680L French Door Fridge with Water and Ice...
http://www.ebay.com.au/itm/ws/eBayISAPI.dll?ViewItem&item=121998338668&catId=20710&item=121998338668&mid=503315&sdc_id=1081525136346&sortbid=15&rmvSB=true
Samsung 28 15 cu ft 4 Door French Door Refrigerator in Stainless Steel...
http://www.appliancepartspros.com/samsung-case-veg-assy-da97-08437d-ap5805507.html
Aug 23, 2016 | Samsung Refrigerators
Humidity-Controlled Crisper Drawers
If you will post the complete model number including the string of digits starting with P, (if it has these) I will look it up and see what I can find.
You can usually go to sears.com, click on parts, enter the model number from the fridge decal, and pull up a parts diagram of the fridge.
Thanks/mike
Nov 11, 2007 | Amana ASD2620HRB Side by Side Refrigerator
Why are vegetables freezing in crisper?
There is a control on refrigerator that controls the amount of cold air that is directed from freezer to refrigerator section. Locate that control and lower the amount of cold air going into refrig.
Oct 07, 2015 | Samsung RF265AA Bottom Freezer French Door...
Why is there ice in the bottom of the crisper?
Freezer /fridge water/ice in fridge
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Sep 07, 2014 | Samsung RF217ABPN Bottom Freezer French...
Water in crisper drawer of Whirlpool model number ET18TK
the water in the bottom of the fridge will be from condensate running down the back wall and not collecting in the drain ridge to flow outside to the dish on top of the compressor. It comes from overloading the fridge by opening the door too often and excess food trying to cool down. check and unplug any blockages in the drain and pull any containers away from the back wall as water will flow off the wall onto them and miss the drain all together. The drain ridge will be under 1/2 way down the back
Dec 25, 2013 | Cars & Trucks
The middle support that holds up the crisper drawers has broken
Check with KitchenAid regarding replacement of the part. You also can try an appliance parts supplier as the tab may be a frequent failure item.
Nov 17, 2013 | KitchenAid Architect KBFA20ERSS Stainless...
Water in Crisper, what causes it?
clean out the drain hole in the back so that the water can drain out side into the container on the compressor
make sure that the door seals are intact
Sep 09, 2017 | Samsung RF217ACWP - 20 cu. ft. French Door...
Freezing in left crisper drawer.
If you have had a DOE upgrade the fix is availiable from LG
Here is the service buliten # CREF20090877.
Contact LG @ 1 800 243-0000 for repair.
In the mean time remove crisper dware and look on the back wall of the ref. you will see a dime sized hole on the center tower. Cover the hole with tape and reinstall crisper.
Jan 19, 2010 | LG LFX25960 Bottom Freezer French Door...
Refrigerator crisper drawers are freezing veggies
Shut the air flow into the crispers if you can. If not, turn the refrigerator temperature warmer by just a few degrees. The air into the fridge from the freezer is channeled into the crispers.
Jul 01, 2009 | GE PFS22SISSS Stainless Steel French Door...
LG LRFD25850 French Door Refrigerator Logo
2,811 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
