My screen isnt turning on my laptop while the actual laptop is?
  • 300 Answers
It may be that the LCD is bad. One good way to test that is that if you have another external monitor and connect it to the external video output on the back of the laptop. Once you get it connected you will need to switch from the video output from the lcd to the external monitor. Usually there is a function key labeled Fn on the keyboard that you can use in conjunction with the function keys at the top of the keyboard. The function keys will have small icons above them. You can also refer to the manual for the combination. Once you find the combination you should be able to see the video on the external monitor. If this is the case either the lcd or the power inverter is bad.
Also, if you don't have a monitor, you can take the laptop in a dark room and start it. Once its been on for about a minute or you hear sound you can shine a flashlight into the LCD and see if you see the icons on your desktop. If so, it can be either the back light or the LCD, in which case the LCD can be replaced.
Hope this helps. Please remember to rate this information.
Thanks
Posted on Nov 17, 2008
Hi! My screen has gone blank on my wharfedale docking station and it isnt responding to anything! I'm not sure what's wrong with it?!
The first place I would look is to the screen lighting mechanism. To prove the display is actually working, you should be able to catch a reflection of very dim images on the screen in bright light.
Hope this is of some use to you.
~/Lee
May 24, 2015 | Computers & Internet
What should i do if my acer 4738Z laptop screen isnt turning on?
Hook up an external monitor to see if your desktop shows up. If it does then your LCD screen is bad. The scren is easy to replace. let me know what is the result.
May 20, 2011 | Computers & Internet
Hi there....i accidentally stepped on my laptop and the screen looks liks its cracked....the actual screen isnt cracked it just looks like it...kinda looks like you can see the inside of it...HELP!!!!
Yup, its cracked. The actual LCD (liquid cristal display) is inside the protective plastic casing and that is supposed to help keep it from being damaged. It has to be replaced..
Oct 27, 2009 | Acer Aspire 5500 5570-2609 Laptop
Screen isnt booting up, laptop opens all the way- broken?
The computer will not work without a hard drive.
Most laptops screens will go all the way back.
Enjoy.
Jul 08, 2009 | Gateway MT3422 RTL Notebook
My hp pavillion dv2000 screen isnt working PLEASE HELP
when you power up press F8 key then enter in enable vga mode .
Tehn go to control panel and then dispaly property then change screen resolution to 1024*768
then apply and ok.
Jun 22, 2009 | HP Pavilion dv6000z Notebook
Can see two or three lines on the screen of my lenovo laptop. I had the same problem earlier , but it was repaired at one of the ibm service centres during the warranty period. I tseems to have apperared...
sounds like a problem i have a lot, just get a new screen for it, scrap a old laptop or something, i may be wrong but isnt it usally caused by the little ribbion cables that connect the actuall lcd panel to the board on the lcd assembly getting damaged?
Jun 10, 2009 | Lenovo 3000 G530 Notebook
Screen black out
best way to trouble shoot a monitor is to plug into a different monitor do you have a desktop monitor you can try?also alot of laptops have a small button that turns monitor off when you shut it down around the base of the monitor make sure it isnt stuck.is it going into hibernation? try pulling the battery and unplugging it then plugging it back in.if it is stuck in hibernation that should work.
Apr 23, 2009 | HP Pavilion DV6500Z Notebook
Dell Latitude D620 Gray Screen
I don't know about that particular laptop but it sounds like a loose connection between mainboard and screen plus a bad inverter (regulates and supplies voltage to the actual screen from the main power source). Laptops typically have the inverter hidden somewhere in the frame that surrounds the actual lcd screen. Sometimes this regulator is part of a small circuit board, sometimes it is not (I suppose it might be part of the actual lcd in some cases, but i've never seen that). I would investigate things further in that direction and just hope your lcd itself isnt bad.
Jan 22, 2009 | Dell Latitude D620 Notebook
Radio Stream not working with Vista anymore?
ok,you had checked all the ways so the first thing is sound is not installed properly or not working properly in your laptop. So you have check the laptop sound in the sound properties in the control panel. i tell the steps
  1. Go to control panel and sound and multimedia panel and go to the sound tab and check the all the sound is work
  2. Goto the desktop and there is taskbar in that the you can see the sound icon ,then double click it , advance properties and check the sound tab that are volume, microphone, wave,radio and select it and change it
  3. change it and then it will not work then you have to reinstall the sound software in your laptop
try it and inform to fixya.com
Jun 06, 2008 | Computers & Internet
Computers & Internet Logo
330 people viewed this question
David Payne
David Payne
