Question about Thermador SC302T Electric Double Oven
Thermador oven timer doesn't repeatedly chime for 5 minutes anymo
My thermador double oven's timer chimes 4 times after the end of the set time. It is supposed to continue chiming every 30 seconds for 5 more minutes (unless shut off) but it no longer does this. It only chimes 4 times and that's it so I sometimes don't hear it and am burning food.
  • curttam Nov 24, 2008
    I have the same problem. It has been remedies in the past, but do not remember what was done. Please advise
I just fixed my timer! Press and hold the OFF button for 10 seconds (until you hear 1 chime). Thanks to David at Bosch/Thermador!
Posted on Dec 04, 2008
Not the exact solution, but you need to hold down three buttons on the front control panel - don't recall which ones and based on model of oven. Call thermador/bosch technical support and see if they can walk you through it. Had this happen when a replacement controller board was installed. It is in there common knowledge base. the first level support person was able to look it up and tell me what to do. I'm actually looking for a complete list of these changes (F to C, adjust temp, troubleshoot, chime loudness, etc)
Posted on Nov 27, 2008
Set clock on an old thermador double convection oven
Turn the main knob counter clock wise until the display reads "clock", then turn the same knob clockwise to set the time. When done, push the select button.
Feb 25, 2012 | Thermador SMW272 Electric Double Oven
My thermador double ovens is not working the control board is not on. it is dead. It is about 8or 9 yrs old.
SUSAN!!!!!!!!! This is EXACTLY what happened to mine! The control panel doesn't show the time or temp or anything! I am going to watch for an answer!!!
Nov 18, 2011 | Thermador Ovens
My 36 " thermador oven,
The sensor on the burner is not sensing the flame. It could be the sensor itself or its' controller. You need to call for service.
Oven repair in Santa Ana, CA
Appliance repair in Santa Ana, CA
Jan 24, 2011 | Thermador Professional Series PO301...
My thermador double oven does not turn off for 30 minutes.
Welcome to FixYa.
Please clarify if I`ve misunderstood what you`re asking, but with all Thermador ranges and wall ovens ( including your SC302T model, most brands in fact ) the cooling fans will remain on for quite some time after actually shutting the oven off.
This is done by design to keep the electronics cooled to a temperature usually below 200°F so they aren`t damaged.
Heat after all is the thing which damages electronics more than anything else.
I do have use and care guides available via email attachments in "pdf" if you need one.
Thank you for choosing FixYa. I hope this eases your concern. Please let me know.
Regards,
Macmarkus :)
Sep 07, 2010 | Thermador SC302T Electric Double Oven
Probe light stays on so I can't cook
Hey i just got knocked out of the session can you please get back in to the session
Nov 26, 2009 | Thermador SEC272BPSS Electric Double Oven
Thermador oven display fc
Try turning off your circuit breaker for a few minutes. Then, after you reset it, push clear, then set your clock.
Sep 11, 2009 | Thermador SMW272 Electric Double Oven
My thermador oven tells me error code 14
Sometimes you can unplug the unit for at least 30 minutes and reset the unit and it wont do it again.Try that first. An error code on a thermador of 14 means latch switch problems.
May 12, 2009 | Thermador SMW272 Electric Double Oven
Self-clean turns off after 5 minutes with F2 error message
Hi MaryB,
F2 error code means that the oven temperature is too hot. You will have to replace relay board if faulty. Check and replace oven temperature sensor (RTD). If failure repeats, replace ERC (electronic range control or clock).For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Apr 15, 2009 | Thermador C272 Electric Double Oven
Cook timer keeps chiming
it starts chiming every min AFTER the timer counts down the allotted time?? thats normal operation its remonding you that the timer has completed cookin and to remove food from oven.. it will continue cooking with residual heat if not removed
Nov 25, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
Open Questions:
See all Thermador SC302T Electric Double Oven Questions
Thermador SC302T Electric Double Oven Logo
146 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
