Question about Gateway Wireless-G WGR-200 Router (7004809)
Cannot connect I just recently bought a Gateway WGR-200 in order to set up a Wi-Fi cloud for my also recently acquired Nintendo Wii. I'm having trouble setting up the router, as I bought it off of eBay and it came with no instructions. Could anyone provide me with a solid walkthrough? Thanks in advance.
  • Nathan Booth Dec 04, 2006
    I've filled out the fields on the set up page and I'm still having trouble connecting the wireless router and having a connection with my PC.
    I've set up my WEP security.
    I've adjusted the clock to the appropriate time zone.
    I've set up a Host and Domain name.
    Not sure what to fill out for my IP address, or what to use for the subnet mask in the LAN section of the set up page.
    I have no idea what I'm supposed to do with the DHCP
    Is there some sort of wizard I'm supposed to be running?
  • miguelitro9 Feb 17, 2009
    i don't know how to release the ip address
    President:
  • 2,961 Answers
Assuming you are on Windows XP click on site below for router setup. http://support.gateway.com/s/NETWORK/7004809/7004809slWindowsXP.shtml The Nintendo 'Cloud' is just a network name so that when you are in a building that has supported wifi, you search for the network and use My Cloud as the password for connection on Nintendo DS. The settings you may require for the Nintendo Wii will probably be your routers IP address, Gateway and DNS address (just use same numbers). Apologies in advance if i'm incorrect as i have only setup a nintendo DS on my own wireless network and as Wii are not yet available i have no knowledge of it yet.
Posted on Nov 30, 2006
SOURCE:
Do you have list of current Nintendo wi-fi connection-compatible software?
not sure if this link will help you outHow to get around the Wii Error Code 20110. Nintendo Wi-Fi Connection service for this software has been discontinued. Visit support.nintendo.com for a list of current Nintendo Wi-Fi Connection-compatible software. ... Anyway, it is still possible to play Mario Kart Wii or Super Smash Bros. Brawl online.
How to get around the Wii Error Code 20110 - St?phane Caron
https://scaron.info/blog/wii-error-code-20110.html... current Nintendo wi fi connection compatible software Google Search
Oct 26, 2017 | Nintendo Video Game Consoles & Games
How to set up wireless internet for wii
If it is the Wii console wi fi you are after then go to this site for instructions.
But keep in mind the Nintendo no longer provides support for online network games on Wii. You can still use it in off line mode.
http://en-americas-support.nintendo.com/app/answers/detail/a_id/2679/p/604
Nintendo Wi Fi Connection service for Nintendo DS and Wii has ended...
Sep 07, 2014 | Video Game Consoles & Games
We connect through our wii was working this morning not this evening
The WII is not getting the internet because the Wii is not recognizing your service. Try putting in the information manually. Also try entering your password correctly, you may have to change the settings on the Wii.
NOTE. As of May 20 2014, Nintendo recently closed down the Nintendo Wi-Fi connection services but you can still access the internet through Wii Shop to get games etc.
If you still have problems, Call Nintendo at 1-800-255-3700 to get help.
Hope this helps you.
May 01, 2014 | Nintendo Wii Video Game Consoles & Games
Can I use a Gateway WGR-200 wireless router with Windows Vista?
Absolutely. The WGR-200 is Wi-Fi certified and will work with virtually any wireless device, regardless of operating system.
Dec 19, 2010 | Gateway Wireless-G WGR-200 Router...
I dont know how to connect my internet to my wii
the wii has a built in wi-fi reciever so you HAVE to have wi-fi if you dont buy a wireless router hook it up to your computer you need to have high speed internet for this then once your wi-fi is set up go to wii options internet connection then click search for connection if you have it set up right it will show your connection name then you click on it and it will retrieve the signal from your connection and you can go online from your wii.
Dec 23, 2009 | Nintendo Wii Console
I con't update my wii error code 32002
"Wii error code 32002" The Nintendo Wi-Fi Connection servers could be experiencing a high amount of traffic. Please try your connection again later. If you have waited several hours and are still unable to connect, there could be an issue with your connection. Please review this information to correct the problem, click on the link below:
http://www.nintendo.com/consumer/systems/wii/en_na/errors/results.jsp?error_code=32002&system=Wii&locale=en_US&action2.x=27&action2.y=25
Nov 08, 2009 | Nintendo Wii Console
Cant connect wii to internet
The unit can connect to the Internet by utilizing its 802.11b/g Wi-Fi, which is built in, for wireless connections or via a USB-to-Ethernet adaptor for DSL connections.
For your wireless connection or Wi-Fi, the 802.11b Wi-Fi has a data rate of 11 Mbits per second and has an indoor range of 30m or approximately 98 ft. The 802.11g has the same indoor range, however the data rate is at 54 Mbits per second. If you have an existing wireless connection or are in a Wi-Fi hotspot, the unit will connect to your wireless connection automatically out of the box. If you do not have a wireless network, however, you will need to have your wireless network subscription done or set-up first. Once you have wireless Internet access, you then search for your access point, put in your security settings and you’re good to go. It would also be advisable to have a wireless router for this so that you won’t have to shuttle the connection between your PC and your Wii. wi-fi-usb-connector.thumbnail.jpgAnother option would be to connect your Wii via the Nintendo Wi-Fi USB Connector. This accessory allows Nintendo Wii users who do not have an existing Wi-Fi connection or a compatible Wi-Fi network to create one through their broadband or DSL connected computer. This is inserted into your existing computer’s USB port and the Wi-Fi USB Connector acts as a wireless access point for the Wii. This allows the user access to the internet and to play Wi-Fi Connection games from Nintendo Online.
nintendo-wii-lan-adapter.thumbnail.jpgFor your DSL connection, however, you will need to have quite a few things. You can use a WII LAN adapter to connect your Wii to your DSL modem. You can also use a router so that you can use your PC and your Wii at the same time. With the LAN Adapter though, to use or plug in the Wii, you must disconnect your PC. This can be quite tedious since you will have to plug in and out your PC and your Wii every time you need to use one or the other. A LAN Adapter is fairly cheap, but if you get a router, your PC and your Wii can go online at the same time, saving you the hassle of connecting one or the other when you need them. You can then hook up the existing ethernet cords to the back of the router and connect it to the Wii via a USB 2.0 cord.
i hope this helps
Nov 05, 2009 | Nintendo Wii Console
Wii wireless connction has error code 51040
rror Code: 51040 Please try the following troubleshooting for the Nintendo Wi-Fi USB Connector
  1. Verify that the Nintendo Wi-Fi USB Connector is installed correctly and that the PC is turned on (the USB Connector will not work while the PC is turned off).
  2. Try our interference troubleshooting steps.
  3. Are you using any security programs (firewall, anti-virus, anti-spyware, anti-adware, etc.)? If so, you may need to add the Nintendo USB Registration Tool software to a list of "allowed" programs or "exceptions." If this is unavailable, you may need to disable yousecurity program before the Nintendo Wi-Fi USB Connector can access our servers. See Nintendo Wi-Fi USB Connector "Firewall troubleshooting" for more information.
  4. Try uninstalling the Nintendo Wi-FI USB Connector software, and installing the newest version. To get uninstalling instructions and the latest version of the software, please click here.
Nov 29, 2008 | Nintendo Wii Console
Wii
If you go to wii options on the bottom left of the wii menu, hit wii settings and then keep moving to the right until you see the option "internet," click on it and select connection settings and search for an acces point. If you can't find one that is unsecure, go back and buy a Nintendo wi-fi usb connecter, (I got mine @ walmart), and then install the software into your computer and follow your instruction manual. then connect with the Nintendo wi-fi usb connectewr on the connections screen, then you should be good to go!
Oct 01, 2008 | Nintendo Wii Console
I have brought the nintendo/wi-fi usb connector. The computer/wii can see one another but i cant get internet access
you have to select a game and configure a connection through the game. it is like a ds you cant configure the connection on the homescreen you have to go into a game go to setting and find the wi fi connection tab then they will find each others signals and you will connect.
Jul 29, 2008 | Nintendo Wii Console
Gateway Wireless-G WGR-200 Router (7004809) Logo
212 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
