Question about JVC LT-32E479 LCD TV
Jvc lcd tv model lt40x776
My lcd tv has a 3in vericial line on rightside of screen.sometimes you will see a partcial picture in it.But the picture seems to go with the middle of the screen not the right side where the line is.The line is a gray in color and some times for a very short time it will be white with
several different color lines through it.but for a very short time when first cut on
  • Anonymous Feb 07, 2009
    same problem just happened, white lines on right side of the screen.
    Champion:
  • 225 Answers
LCD monitors are divided up into smaller strips. Each strip has it's own video driver. That strip has either lost it's power source, or the board is bad. Might just be a loose solder joint, if you are lucky.
Posted on Nov 17, 2008
JVC jle42bc3001 LCD TV has a thin blank line running through the right/mid section of the screen. Obviously more noticeable when the picture/scene is light. Is this repairable?
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Nov 17, 2016 | JVC Televison & Video
JVC LT-50A330 TV. Sound but no picture. Screen is blue
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Apr 07, 2015 | JVC Televison & Video
Jvc lt-42pm30
Horizontal lines are usually caused by a bad LCD (screen)..
Sep 24, 2017 | JVC LT-42X579 42 in. LCD TV
I have a 37" JVC LCD TV Model # T370HW02 and the left half of the picture if filled with vertical colored lines for approximately 30 minutes after the set is turned on then the picture clears up and s
The problem with your TV is the screen tabs this is where the electronics bond to the screen a technician may be able to fix it with compression pads otherwise it a new screen
Apr 11, 2017 | JVC Jlc37bc3000 37 Lcd Tv 1080p
Yellow lines on jvc lcd tv
tried to re seat first the cable at the t-con board that transfer signal on the screen panel display which may have loose contact on the connector.
Aug 12, 2012 | JVC 42 in. LCD TV
CAfter the JVC model LT-42E910 is on for 10 minutes, the picture goes blank/black, but I have sound. I must turn off the tv and turn it back on every 5 minutes to get a picture. The tv is 4 days old.
It is a new tv.Take it back where u bought it and trade it in for another tv.This tv have those 2 LCD long inverter boards have problems.These 2 long LCD inverter boards are to help the tv LCD screen panel to have a backlight for the tv LCD screen to produced a picture.
Jul 07, 2011 | JVC LT-42E910 42" LCD TV
The bottom half of the screen shows lines with no picture
You are gonna have to tell me what is the make and model of the tv or atleast if its an LCD, Plasma or Projection tv(type is also required like DLP, LCD rear projection or CRT rear projection tv). Please get me this info so that I can help you resolve your problem.
Dec 05, 2010 | JVC Televison & Video
JVC LT 42x688 no picture just sound
Sorry, this has no easy fix. The good news is you do not need an LCD Panel. The bad news is the Video Processor has a problem.
This TV has x3 Boards. The one you should replace first is the one in the middle. If this doesn't fix it, try the one on the right. The Part #s are on the Boards if you wanna try ebay.
Dec 22, 2008 | JVC LT-40X776 40 in. LCD HDTV
JVC 32 INCH MODEL AV-32S585
is the bright line on the midle of the tv , if it's what u ia vertical problem also sometimes is the flyback , tv needs service ,
Apr 30, 2008 | Televison & Video
JVC LT-32E479 LCD TV Logo
255 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
