Washer doesn't spin at high speeds
I have a Kenmore fron-load washer, model 417.44052400. It does not spin out at high speed. I've checked the drain pipes around the water pump and there isn't anything blocking them. The unit does drain. I have removed the front door latch, disconnected the wiring, and reconnected the wiring. I am still receiving error code 47. Any other ideas on what could be wrong and how I can fix it?
    Sergeant:
    Champion:
  • 251 Answers
It is more then like the gear in the final spin is going out i suggest calling some one who services kenmore products
here to help
Shaun
Posted on Nov 17, 2008
Diagnostics ok but only spins slow
Water pump screen is plugged. Will not drain properly even though it goes into high spin.
Mar 14, 2014 | Kenmore HE3T Washer
Kenmore front load washer model 41744052400 will not enter into high speed spin at end of cycle. I can run the test for the different cycles and can get the high speed spin, but only in the test mode. ...
Try to get the repair manual for your machine, it's worth the cost. Meanwhile, with the power unplugged, undo any wire connectors that just plug in and check for corrosion. Check the capacitor, a dent will ruin it.
Nov 26, 2013 | Hotpoint WMA64 Front Load Washer
Kenmore Front Loading Washer - the spider arm broke and we had to change the entire tub assy which was done and the machine now works perfectly as for the washing and tumbling. The tub spins, tumbles back...
It is the brain of the washer that decides when the spin takes place and how fast - the brain knows how fast the motor is spinning because there is a speed sensor, probably on the rear end of the motor shaft.
There might be bad connections to the speed sensor or it might be broken but if that and the wiring is ok the fault is probably with the controller/brain, though it is possible the brain refuses to do a high speed spin because for some reason it might (mistakenly?) think there is still too much water in the tub.
Oct 01, 2017 | Kenmore 44102 Front Load Washer
Washer does not spin at high speed
The washer will not spin if it doesn't drain properly. Verify drainage. Also, the latch assemly goes bad on these all the time.
Oct 01, 2010 | Frigidaire GLTF2940ES Front Load Washer
Washer will not spin at high speed
check for any blockages around pump and air trap area.
Sep 14, 2009 | GE WBSR3140DW Top Load Washer
Wet clothes
the reason the clothes are wet is the washer is not shifting to high spin,does the washer have a speed switch(normal wash spin,high wash spin)if its not the speed switch than the clutch is bad,how old is the washer?mike
Apr 19, 2009 | Kenmore 24032\24036 Top Load Washer
Clothes come out soaking wet
Is the Delicate or Hand Washables cycle selected?
Spin speeds can vary by the cycle that is selected. Your washer is designed so that in certain cycles, such asDelicate or Hand Washables cycles, the spin speeds are slower. In these cycles, more water is retained in the load at the end of the cycle to keep delicate fabrics from shrinking and wrinkling. Select the appropriate cycle based on the fabric being washed.
Was an Extra Low, Low or No Spin option selected?
Select the highest spin speed for the fabric being washed. If extra low spin or no spin was selected, the washer may not remove enough water from the load.
Were you washing one bulky item, such as a rug or large blanket?
Consider adding more items to help balance the load during spin. Select $FL-drainspin cycle and restart the washer. Your washer is designed to detect an unbalanced load and automatically lower the spin speed. Unbalanced conditions are more likely to occur with a single, bulky item.
Are excessive suds present?
Use only HE High Efficiency detergent. Using non-HE detergent or more than the manufacturer's recommended amount of detergent can cause excessive suds. The excess suds can cause the washer to run at a reduced spin speed, which will result in very wet loads.
See also: Why HE High Efficiency detergent is required.
Is the drain hose kinked or is the drain clogged?
Make sure the drain hose is not kinked. Straighten the hose for adequate water flow. Remove any blockage from the drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose. See the Installation Instructions for details; find them by entering your model number in the Manual and Literature search below.
Is the end of the drain hose more than 96" (244 cm) above the floor?
The drainpipe (standpipe) height requirements are: 96" (244 cm) maximum and 30" (76.2 cm) minimum. Your washer will not be able to adequately pump the water out of the washer if the drainpipe (standpipe) exceeds 96" (244 cm). In this case, the water may flow back into the washer. See the Installation Instructions for details; find them by entering your model number in the Manual and Literature search below.
Is your outlet voltage low?
Check electrical source or call an electrician.
Dec 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Will not spin,
Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Code to restart washer Duet
Answer Is the Delicate or Hand Washables cycle selected?
Nov 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
79 people viewed this question
Top Washing Machines Experts
