You can try the steps below. You will need a repair disk or operating system disk to boot from so that you can get to a command prompt (black screen with white lettering). Type the commands below and after each one press ENTER.
bootrec.exe /fixmbr
bootrec.exe /fixboot
bootrec.exe /rebuildbcd
Reboot and see if the problem is solved. if not run the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
SOURCE: BOOtMGR image corrupt. system cannot
HI Stephen
You can defenitely try these steps but if these does not resolve your issue you might have to reinstall the windows. Please make sure you have all the cds for your laptop and also make sure the data has been backed up.
here are the links on how to fix the bootMGR message
http://support.microsoft.com/kb/314503
try to repair your system with these steps.
post if still the issue is not resolved.
thank you
Rakesh
Dell Laptop Expert
SOURCE: Bootmgr image is corrupt.system cannot boot
It is possible the Master boot Record has become corrupt. You can repair it using a tool for that purpose. Here is a KB article explaining your options and how to use the tool:
http://support.microsoft.com/kb/927392/en-us
First try the Recovery Console options which you access via the F8 key. As your system is booting up, right before, or right when you see your manufacturers logo, but before you see the Windows Logo, begin tapping the F8 key until you see a menu of white words on a black background. Once there follow the instructions at the top most section of the article.
If this does not work you will need the Vista installation or Recovery disk to continue with the more advanced actions. You can use ANY Vista disk, so if you have a friend or family member who has one borrow it and then boot from it. Sometimes you must change the boot menu in order to boot from a disk. If it doesn't boot then you must enter the boot menu and change it so your CD/DVD drive is first in line. If you must do this you will also need to go back and reverse the change so you can boot from your hard disk to see if it worked. It is easy to alter the boot menu. Usually, the key(s) you press are shown on the screen as you boot. Write this down and then reboot and press the key(s). Then, simply locate the appropriate section and make the alterations. You must use your arrow keys to move around the options. There should be instructions on use of keys and how to exit, or save changes and exit.
If you do not know anyone with the Vista disk you will need to contact your manufacturer and request one. Usually all they will do is charge shipping, but you will have to wait until it arrives to try this repair. Sorry about that. That is one reason I insist on a installation or restoration disk when I buy a pre-built system. The manufacturers want to give out as few as possible, and in doing so tell people they don't need the disk because of their hidden recovery partition. However, the hidden recovery partition does not allow for repairs, only putting the system back into factory condition which wipes out everything you have added, all of your changes, and system preferences. Also, if you have not backed up your files you lose them too.
This is the best I can do with the information given. Somebody else may have other idea on how to fix your issue. Good luck and I hope it is simple to correct.
SOURCE: Bootmgr image is corrupt error message at startup
1) start up on safe mode ... try to do a restore ... all programs - accessories - system tools - system restore
2) reload windows
SOURCE: bootmgr
Connect a USB CD-ROM and install a new OS - or if you can get the same Operating System (OS) disc from a friend use it to repair your system.
Its the only think you can do really.
If this was at all helpful please vote kindly
SOURCE: bootmgr image is corrupt
I will TRY to supply you with the image.
If you give me your address by e-mail, I will send you a FREE temp OS (Partition Magic) with the bootmgr image and instructions on how to nake it work again.
The temp OS does not store data onto your HDD and is used if your compuer is in a unusable state.
I will include the XP, Vista and 7 boot images.
